Sony Dc Universe Online Logo
Posted on Jan 16, 2011
It keeps saying "unable to
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1152
Points
tip
How to Set up WiFi Using your iPod Touch & Droid
<p>Modern mobile devices such as Android-powered smartphone Droid or Apple iPod Touch portable media device seem to do your best if you connect to the Internet. You can download new information, the browsers can surf the web and online applications can enjoy the full functionality. Setting up a WiFi connection on any device will allow full access to the Internet via a wireless network. Both devices have the possibility of links built into their operating systems to configure. <br /> <p><br /> <p>IPod Touch <br /> <p>1. Select "Settings" on the front. <br /> <p><br /> <p>2. Select "Wi-Fi and wait a moment as iPod touch detects WiFi networks nearby. <br /> <p><br /> <p>3. Select your WiFi network from the list when you get home, or a WiFi network around when you are away from home. <br /> <p><br /> <p>4. Enter any encryption keys or passwords required to log on the network and the iPod Touch can take a few moments to connect. <br /> <p><br /> <p>5. Look for the WiFi icon in the status bar at the top. It looks like an inverted triangle with a rounded tip, composed of multiple curved horizontal lines. If this icon is present, you are connected to the network. If not, try connecting again or select another network. <br /> <p><br /> <p>Droid <br /> <p>1. Tap the menu button at the bottom and select Settings. <br /> <p><br /> <p>2. Select "Wireless & Networking," then "Wi-Fi settings" and leave the droid few minutes at a nearby WiFi network available. <br /> <p><br /> <p>3. Select your WiFi network from the list when you get home, or a WiFi network around when you are away from home. <br /> <p><br /> <p>4. Enter any encryption keys or passwords required to log on the network and the iPod Touch can take a few moments to connect. <br /> <p><br /> <p>5. Look for the WiFi icon in the status bar at the top. Dot appears with several curves, horizontal lines radiating. If this icon is present, you are connected to the network. If not, try connecting again or select another network. <br />
on Jul 21, 2011 • Computers & Internet
tip
Check Your Playstation 3 Error Code
<span style="font-weight: bold;">Error Code - Meaning/Suggestion/Possible Fix:<br /><br /><span>0710102 - DNS Error: No DNS server available.</span><br /><br />80010001 - Major Error, Game ability stopped.<br /><br /><span>80010006 - An error occurred during the start operation. - Corrupted folding install.</span><br /><br />80010007 - An error occurred during the start operation. - During the (internal) hard drive disk swap tests. suggests a failure with the hard drive.<br /><br /><span>80010017 - Can't start Blu-ray Game</span><br /><br />8001050B - Will not play demo game from the hard drive. When a Blu-ray disc is inserted. - Cause unknown".<br /><span><br />8001050D - An error occurred during the start operation; PS3 game swapped using the eject function and then play pressed quickly. - Insert PS3 game again.<br /></span><br />80010510 - Will not play games installed on the hard drive. - Cause unknown.<br /><br /><span>80010516 - An error occurred during the start operation: PS1 game swapped using the eject function and then play pressed quickly. - Insert PS1 game again.</span><br /><br />80028EA5 - Unknown. User cannot connect to Playstation Network ("PSN"). Contact Sony for resolution.<br /><br /><span>80028EA6 - Connection Error: Turn off PS3, unplug router and modem. Turn on modem and allow it completely boot-up and synchronize. After the modem shows that it is "online", then plug in the router and allow it to completely boot. Lastly, plug-in and turn on the PS3.</span><br /><br />80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic.<br /><br /><span>80028F17- PS2 Disc Boot Error. An error occurred during the start operation: PS2 game swapped using the eject function and then play pressed quickly. - Insert PS2 game again.</span><br /><br />80028F18 - PS2 Disc Error. Unsupported disc: eg. Utility discs, BB discs, IQ Remix game etc.<br /><br /><span>80028F19 - PS2 Disc Error. Fsck: the internal PS2 disk was corrupted. You may be able to use the HDD utility disc to fix it (use with caution), otherwise, contact Sony.</span><br /><br />80028F1A - PS2 Disc Error. invalbnnetcfg: network config error.<br /><br /><span>80029023 - Exchanging Key Information: exchange has timed out.</span><br /><br />80029024 - Cannot obtain an IP address. DHCP failure. Check network connection, modem and/or router.<br /><br /><span>80029301 - An error occurred during the delete operation: attempting to delete PS2 data from virtual memory card.</span><br /><br />80029513 - Copyright Violation when attempting to install game.<br /><span><br />80029516 - Sign in to PLAYSTATION-Network: needed for some games or PS3 processes. Sign-in is required for current operation/request.</span><br /><br />80029564 - Downloaded game will not install: Cause unknown.<br /><span><br />80029945 - Can't playback burned BDr movie: Error in picture.</span><br /><br />80029946 - Attempting to play burned Dual layer NTSC disc on a PAL PS3. The workaround is to transfer files to the PS3 via TVersity.<br /><br /><span>80029C68 - Corrupt data. Usually on an external device.</span><br /><br />8002A10D - Unable to Add friend in XMB. (Normally because you have reached the limit of (100 friends)<br /><br /><span>8002A4A6 - Cannot load game to play online.</span><br /><br />8002A515 - Error Signing in.<br /><span><br />8002A548 - Unable to remain logged in. Either due to game or server.</span><br /><br />8002A705 - Unable to connect to server/host. If you are using a router, check port/DMZ configuration.<br /><span><br />8002A71A - Possible NAT Error. Can log into Game Server but can't join game and can't host game. Turn off the PS3 and wait for 5 minutes.</span><br /><br />8002B241 - DVI has no audio.<br /><span><br />8002F994 - Too many people currently downloading the update. Server(s) at capacity. Wait and retry</span>.<br /><br />8002F997 - Trying to Update the XMB Firmware: Copying to a file and installing from a USB drive failed.<br /><span><br />8003041F - An error occurred during the copy operation. (Using media server)</span><br /><br />8003051E - Game will not Save.<br /><span><br />80030920 - An error occurred during the copy operation. The file may be corrupt or there isn't enough memory. Try copying data from original source.</span><br /><br />80031150 - System Settings Fail to Save. Possible Blue Screen Setting information is corrupted.<br /><br /><span>80031601 - Error Creating Account.</span><br /><br />8013013D - A connection error has occurred: Causes may include the actual SSID of the wireless access point/router or signal strength. If the connection drops, try enabling DMZ functionality on your router (if supported) for your PS3. Otherwise check WPA key. The PS3 wireless interface [currently] does not support WPA2 - only WPA, WEP or none.<br /><span><br />8013013E - WEP Key error: Change WEP key to *only* numbers and try again, or switch to WPA.</span><br /><br />80130203 - PS3 connects to the internet (you can go a website via the PS3's browser), but cannot connect to the Playstation-Network. Typically this means that the required ports are not open/accessible. Check your router's configuration.<br /><br /><span>8013030 - System Error: Due to failed update download.</span><br /><br />8013030F - Access Point was not detected. Check your router's configuration and make sure that SSID broadcast is enabled.<br /><span><br />80410418 - DNS Error.</span><br /><br />80410A0B - Internal error: "Hardware Fault". Send unit back to be replaced/fixed.<br /><span><br />80710016 - The Playstation Network is down.</span><br /><br />80710092 - "An error has occurred. you've been signed out from the Playstation-Network". Connection dropped? If your PS3 is wireless (least preferred), the association between the PS3 and the access point may have been dropped. You may need to "reboot" your PS3 if your PS3 and router are unable to establish an association.<br /><br /><span>80710101 - Connection error.</span><br /><br />80710102 - IP Address conflict. PS3 cannot connect to your router with it's current IP Address information. Try rebooting your router and PS3. Occurs when two devices on your network have the *same* IP Address.<br /><br /><span>807101FF - An error occurred during communication with the server. This is a DNS error. It occurs when your PS3 tries to perform a DNS lookup to connect to the server.</span><br /><br />8071053D - Hard boot the PS3. Turn off the PS3 via your controller (this is stand-by mode), Turn off the PS3 switch on the back of the PS3 and remove the power cord. Next, turn-off/unplug your modem (and router if applicable) for about 5 minutes. Then turn on the modem and wait for it go "online". If you have a router, turn it on and wait for it go "online". Then turn your PS3 back on and make a new network connection.<br /><br /><span>80710541 - The connection to the server timed out. This is usually due to: high traffic (between you and the server), high traffic at the server [itself] or you have a "poor path" to the server. Depending on result: Press the 'X' button to repair and restore default.</span><br /><br />80710723 - Possible Port Error: Try opening ports. Configure your router to pass the following ports to your PS3:<br />TCP ports: 80, 443, 5223<br />UDP ports: 3478, 3479, 3658<br />Another option is (if your router supports DMZ functionality) to configure your router's DMZ functionality to pass traffic to your PS3.<br /><br /><span>80710A06 - An error occurred during the install operation. Error when downloading game from the Playstation-Network. An error occurred.</span><br /><br />80710B23 - Playstation-Network is down or Playstation-Network is too busy to respond.<br /><span><br />80710D23 - Turn the PS3 off for a bit. For 30 minutes give or take. Make sure that you either unplug or actually turn off the switch (located on the back of the PS3). "Stand-by" mode is when you see the red LED on the front of the PS3. If you see the red LED on the front of the PS3, your PS3 is *NOT* off.</span><br /><br />81019002 - Error copying saves from location "A" to location "B" not open to connect to store but PS3 can connect to internet.</span>
1helpful
How to clean rootfs in nokia n900 ?
use purge for installed apps. And dpkg -l ' grep ^rc (this command will show you a list of apps configuration files still left in the system from uninstalled app)
dpkg --purge <appname> (This will remove it)
Performance Chip
tip
Full format for Nokia phones
If you have a S60 OS nokia phone....<br />If you encounter situation like below on your Phone<br /><br />1 Blank screen phone unable to reboot.<br />2 Phone only able to boot-up to "Nokia" word screen.<br />3 Install some program but not able to uninstall it after that.<br />4 Error messages such as "Child Installer" keeps popping-up.<br /><br />Do a Full phone formatting ! as steps below,<br /><br />1 Make sure you have at least 3/4 charge of battery power left.<br /><br />2 Backup your contacts list and personal files to MMC memory card.<br /><br />3 Switch-off your phone.<br /><br />4 Press and hold 3 keys;<br /><br />Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the phone.<br /><br />Remember, do not let go all of the keys and hold keys until you see a formatting word screen show!<br /><br />5 After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.<br /><br />All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.<br /><br />
on Feb 12, 2011 • Cell Phones
Can't connect my iphone4 to dlink it says dismis
lets try removing the security configuration if any from the wireless network then try connect the iphone again.
I've just finished scanning a corrupted USB and wanted to recover the data from the scanned results. Then, I was led to a page where I entered my license key (that I just paid for 5 minutes ago) and...
If you have popup blocker or antivirus or antiadware running they may be blocking the communication. Try turning them off. After that if it doesn't work, call their customer support.
1helpful
Whenever I try to print something it says "unable to print 36". Ive restarted the printer and tryed to print something and for a couple of minutes it says cleaning then a few minutes later it...
Remove the printer cartridge and check for any jams. If you don't see any large pieces of paper jammed in the printer, they may be smaller pieces so take care to notice anything small that shouldn't be there.
Place the cartridge back into the printer.
You may also want to unplug the power, wait a moment and plug it back in to clear the error and see if the issue corrects itself.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
