Question about Panasonic TH-42PWD6UY 42 in. HD-Ready Plasma Television
Philips 42PF7220A/37B Plasma Died
My 42" plasma TV does not power on - red power light comes on and blinks several times but nothing happens. I had a repair person come to my house and he indicated that I needed to replace the power board due to puffed out capcitors. Of course the prices was to replace was massive. Where can I order a replacement board? I can install it no problem. The repair guy say it's an L49-00117A.
Thanks, Lou
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
dsacco86
  • 1077 Answers
SOURCE: Philips 42PF7220A/37B won't turn on.
Most likely it's a power supply board related issue. It maybe something simple like a blown fuse on the board. The fuse replaceable. Radio Shack or Electronic supply place will carry replacement fuses.
The other possibility is the power supply board itself is damaged. It maybe a bad capacitor or a transformer on the board. Replacement boards can be found on the internet. A good place the start is Shopjimmy.com.
Posted on Aug 03, 2009
  • 7 Answers
SOURCE: red lines on plasma screen.
you may want to check out your buffers.
for cheap buffers check out hssparts.com
thank you
Posted on Dec 17, 2009
SOURCE: My panasonic 42" plasma wont turn on, but the power light blinks
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Posted on Apr 17, 2010
  • 418 Answers
SOURCE: Philips 42 PF7220A Table top stand is needed
310430816731 or 3113912877791 ; from encompassparts.com ; guest login. 34.00 -50.00
Posted on May 03, 2010
Power indicator light only blinks "red" 7 times and repeats. Is it a power supply problem? no OSD. nothing
I had similar problem with my panasonic tv, turned out to be a fan failure causing power supply to shut down due to overheating, Also could be a capacitor fault in the power supply.
pete
Mar 06, 2011 | Philips 42PF7220A 42 in. Plasma Television
I cannot get it to turn on. in the lower right
The flashing light indicates a failure with-in the tv, the amount of blinks will coincide with a particular fault scenario. Tell me how many times the light blinks and I can tell you the problem. However, the tv will need servicing from your local shop. This tv is too complex to walk you through fixing this problem with Philips plasma tvs.
Dec 28, 2009 | Philips 42PF7220A 42 in. Plasma Television
Red lines on plasma screen.
thank you
Dec 11, 2009 | Philips 42PF7220A 42 in. Plasma Television
Stupid TV
Ur power supply have burn capacitors,useally in the middle of the power supply board is the burn capacitors.Look for bulk up caps or split out.
Aug 20, 2009 | Philips 42PF7220A 42 in. Plasma Television
RED LIGHT BLINKS SEVEN TIMES
The most likely problem are two failed capacitors on the main board in the center of the TV The failed parts are easy to identify as the top of the cap will no longer be flat but will have bulged up. DO NOT attempt to remove the back of the TV unless you know what you are doing.
soldering on a circuit board will be required to fix this problem.
Aug 10, 2009 | Philips 42PF7220A 42 in. Plasma Television
Tv turns on then off
check the power supply for bad capacitors if they are good, replace the power supply board
good luck
Jul 30, 2009 | Philips 42PF7220A 42 in. Plasma Television
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Philips 42PF7220A/37 42" Plasma TV
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Feb 09, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Panasonic TH-42PWD6UY 42 in. HD-Ready Plasma Television Logo
168 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
