Question about Intel 2.66GHz Core 2 DUO E6750 1333MHz 4MB LGA775 HH80557PJ0674MG
Core2 duo E6750 2.66 GHzd
Rust and corrosion  area has appeared on back side of the processor it is harmful indication
  • 781 Answers
You sure its rust and corrosion as cpu and heat sink are not made of metal that corrodes like this
Posted on Jul 17, 2008
Why my foxconn g41md -v motherboard does not support core 2 duo processor
It does support a core2 duo up to quad core but they have to be 1333fsb (front side bus). I suspect you have an early model of the cpu which isn't compatible with the 1333fsb such as a 670fsb. If you look at the back of your CPU you will see the model number. Google that and see the results. You will need to upgrade your CPU.
Apr 04, 2014 | Foxconn G41MD Core 2 Quad Intel G41 DDR3...
Intel core tm duo cpu e4500 motherboard
Intel = Processor (CPU ) manufacturer
Intel Core tm = Trademark. The Intel Core is a Trademark from Intel
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply - Processor for short.
e4500 is an Intel Core2 Duo processor.
Maximum frequency rate ('Speed') is 2.2GigaHertz.
2MegaByte of L2 Cache. (2MB of L2 Cache)
800MegaHertz Front Side Bus. (800MHz FSB)
Tells me Nothing about the actual motherboard. Look on the motherboard for a Model Number. May be in center of motherboard. May be on edge of motherboard. May be in-between one of the expansion slots, on motherboard.
Post back in a Comment.
Also post what the problem is, in your best description.
Computer does not turn on. (Power Supply does not turn on)
Computer seems to turn on, but get No Signal on monitor, or Sleep Mode on monitor, or Power Saver Mode on monitor.
LED lights light up, and fans spin.
Regards,
joecoolvette
Apr 23, 2013 | Computers & Internet
My core 2 duo E6550 does not work on my foxconn g41mxe motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186187
Motherboard supports Processors with a Front Side Bus (FSB) of either 800Megahertz, or 1066MHz.
1333MHz FSB support is done with OVERCLOCKING.
http://ark.intel.com/products/30783/Intel-Core2-Duo-Processor-E6550-%284M-Cache-2_33-GHz-1333-MHz-FSB%29
Intel Core2 Duo E6550 processor has a 1333MHz FSB.
http://www.manualowl.com/m/Foxconn/G41MXE/Manual/297328
I reduced the view size to 120 percent. Go to Page 27.
Press DELete key to enter BIOS Setup.
Use Down Arrow key to highlight - Fox Central Control Unit
Press the Enter key
CPU Frequency Setting should be set to 333 (333MHz)
Intel processors are 'Quad Pumped'
333MHz x 4 = Approximately 1333MHz. (1332)
http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&socket=Socket%20775&model=G41MXE&cputype=Intel
Note the version of the BIOS program also.
Regards,
joecoolvette
Sep 25, 2012 | Foxconn G41MXE Core 2 Quad Intel G41 DDR3...
Dg41 is the best
Please get DG41/CN/TX motherboards it the best. this is due to fact that it carries a better graphic resolution card, lates technology DDR3 SD RAM ram, etc.
Intel DG41CN Motherboard
  • Form Factor: Micro ATX
  • Compatibility: PC
  • Chipset: Intel G41 Express
  • Compatible Processors: Intel Celeron, Intel Pentium, Intel Core2 Duo, Intel Core2 Quad
  • Video Interface: PCI Express x16
  • Storage Controller Type(s): Serial ATA II x 4
  • Intel DG41TX Motherboard
    • Compatibility: PC
    • Compatible Processors: Intel Celeron, Intel Pentium, Intel Xeon, Intel Core2 Duo, Intel Core2 Quad
    • Front Side Bus Speed: 1333 MHz
    Regards,
    Pourmoi
    Dec 23, 2010 | Intel DG31PR Motherboard
    Compatible processor
    Here are the compatible processor for this motherboard.
    Compatible Processors Intel Pentium 4, Intel Celeron D, Intel Pentium D, Intel Core2 Duo, Intel Core2 Extreme
    Dec 03, 2010 | ASUS P5L-VM 1394 Motherboard
    I am using Acer Veriton Desktop PC Intel core duo E7500 2.93GHz I have installed Windows XP, however, some display, PCI, Ethernet drivers are not installed Can you provide the details of the...
    Please confirm that your model is Veriton 3600G. Below is the link to the actual specs and the page where you will find the drivers.
    Veriton 3600G Specifications
    Drivers & Support Docs
    While the first link will take you directly to the product specs, clicking on the second link will open the product selections page. Scroll down and locate "Additional Resources" area. Click on Driver and Downloads and a selector should popup:
    Ensure that you select the following choices:
    This will take you to the driver download page. If it does not display, ensure that you have enabled popups, and installed java and flash player.
    As a side note, you have pointed out that you have installed a core2 Duo while the original specs indicate that this system has P4 or Celeron processor. Be advised that installing an incompatible processor may result in a malfunction.
    Dec 02, 2010 | Acer Veriton 3600G PC Desktop
    Fix error code 146 dell xps 1330
    Error 146 pertains to hard drive error. If there is still a chance to back up your files do so as this kind of error indicates a faulty
    hard drive.
    Aug 16, 2010 | Dell XPS 420 (dxcwqj1_2) Intel Core2 Duo...
    Wanna Upgrade processor
    from some research it appears it only supports the processor that is in it now.
    Dec 19, 2008 | FIC P4M-915PD1 Motherboard
    Cpu enquiry
    There really is no difference, there are differences in the E numbers though. Those are specificallt about it's GHz's, it L1 and L2 cache.
    Though Intel Core 2 Duo is the same as Intel Dual Core. It's just a different name. This confusion is caused because of Intel changing the names of it's processors series. The Pentium brandname for example is gone. Intel Pentium Dual Core is now called Intel Core 2 Duo.
    I hope this answered your question.
    Greetings,
    DarkNeogen.
    Jan 25, 2008 | Intel Core 2 Duo E6600, 2.4 GHz E6600...
    Intel 2.66GHz Core 2 DUO E6750 1333MHz 4MB LGA775 HH80557PJ0674MG Logo
    106 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
