Question about Panasonic Vacuums
Need to remove bottom cover of Panasonic MCV7314 vacuum to see if the belt is broken. I can't figure out how to remove and can't find a manual online.
I did a search for the manual for that model and found a pdf file online that had instructions and pictures. It was still slightly different and hard to get off. I took out two screws and then held in two side "clips" and wrestled it off. I dont think the manual mentioned removing the screws,but instead mentioned two laches that I never found. Here is the link. Instructions are on page 30.
http://service.us.panasonic.com/OPERMANPDF/MCV7314.PDF
Is there a charge for your assistance? I was not sure and that is why I didn't continue.
Posted on Jul 15, 2008
Brush roller not turning model nv 105-26. Having trouble removing bottom cover
Most likely the belt is broken. It could be the broken belt wedged causing it to be difficult to remove the bottom cover. Make sure all the screws are removed and gently pry on the bottom cover with a small screwdriver
Oct 02, 2017 | Vacuums
Simplicity F3500-- how do I get the bottom off to change the belt?
To change the belt on the Simplicity F3500, unplug the vacuum and turn it upside down. There are two tabs (one on each side) behind the beater bar that hold the cover on the vacuum. Press these tabs inward and lift the bottom plate away from the unit.
Then remove the brushroll and the worn or broken belt from the pulley on the side of the brush roll and the drive shaft. Loop the new belt over the driveshaft and the brushroll. Replace the brushroll in the housing and turn it by hand. Make sure that the belt is seated on the driveshaft and pulley with no twists. Also check that all of the rotating parts will move.
Then put the bottom cover back on by aligning the back hinges and then pressing the plate down until both sides click.
For pictures of the cover removal process, look at page 15 in the manual. The direct link is http://www.simplicityvac.com/about-my-simplicity/manuals/FreedomManual_Update0803.pdf . Most Simplicity vacuum manuals are available at their support site: http://www.simplicityvac.com/about-my-simplicity/manuals/ .
I hope this helps.
Aug 11, 2011 | Simplicity 7250 Deluxe Vacuum
Beater bar isn't working
Sounds like a broken belt. Unplug it flip it over and look at the bottom there is a cover over the bottom and the beater bars look for screws or levers to remove the cover then replace the belt. it goes around the beater bar and a drive shaft. check HERE for a manual and belts.
Jun 23, 2011 | Hoover Company Wind Tunnel U53019 Upright...
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
The brushes will not turn when on and cannot move them even manually
Drive belt has most likely broke and jammed inside the power head. Remove the bottom plate on the power head and replace the drive belt.
Oct 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
How do you change the belt for the brushes
Turn the vacuum upside down, there should be two thumb release pivot screws. Remove bottom cover, now you have access to the belt. Remove belt that's in figure eight position, then reinstall same as above with figure eight position.
Aug 12, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Morphy richads cyclonic broken belt how to fix
Flip the vacuum over. Remove the cover plate. Pull the brush straight out with both hands and put new belt on. Put cover plate back on. You are ready to go.
Jim
Jun 10, 2009 | Panasonic MC-V5745 Bagged Upright Vacuum
Lost instructions,need to change belt
The customer operation manual can be downloaded from the hoover web site hoover.com
the bottom cover comes off with 4 screws. install the belt on the motor, then roller, stretch to install roller into cavity. replace cover.
Feb 24, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Upright...OLD vacuum, broken belt
The rod must be your brush roll. it should just pull out, Have you removed the cover over the brush roll? When you do get the brush roll out, turnb the ends and make sure they turn freely, if nit, replace it also.
Sep 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt is broken
Most upright vacuums will have 2 screws on the bottom of the vacuum. Remove both screws and snap off bottom cover to get inside of the head. Remove old / broken belt and slide agitator off from the head unit. Stretch new belt with both hands then place around the agitator and pulley coming out of the motor. Place the agitator back into place (there will be some resistance from the new belt, but that is common). Put back on the bottom cover and place back the screws. You should be all set then. Hopefully this helps.
Mar 14, 2008 | Fantom Vacums CW600 Upright Vacuum
Vacuums Logo
66 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
