Question about Technics SCEH790 CD Shelf System
CD PLAYER.SL-PJ26 Drawer does not open
Sound heard when open/close button pushed
This is part of a stack audio system & much loved
  • rulrich Jul 15, 2008
    Thanks
    Can we avoid this recurring in the future?.Any tips you recommend?
    Is ti safe to inspect gears & track?
    How dangerous is the laser once the machine is turned off
    Thanks
  • Anonymous Mar 30, 2014
    cd drawer will not remain closed even in tuner mode.
    Genius:
  • 1,847 Answers
The tray gears are struck or jamed. need to open the unit.
Posted on Jul 15, 2008
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
Technic sl pd665
Do you mean the cd player drawer is going in and out? If so that means the timing of the gears is wrong from pushing it in manually. It is better to use the button so that you don't mess up the timing. To repair dismantle it and try meshing the gears at an earlier or later spot. Test it to verify that it is back where it belongs.
Nov 03, 2013 | Audio Players & Recorders
How to turn on rca cd player
Hello
1. Press 'SOURCE' repetedely to select 'CD' mode.
2. Press "Open/Close" button to open the drawer.
3. Insert disce and press 'Open/Close' again, and the inserted CD will play automatically. OK.
Jul 29, 2011 | RCA RS2635 CD Shelf System
The CD Tray won't open on my Sony MHC-GX250
te same thing happened to me know i juat turn the stereo off to where the red light is blinking then turn it back on after the standby message disappears and then i quickly pree the eject button......tr it! and let me know!
Jun 24, 2009 | Sony MHC-GX450 CD Shelf System
CD door will not open. Does not respond to the open close button. Cd is incside player. Was put in correctly. How do I open cd drawer without breakin it.
the cd drive should have a tiny hole under the drawer. push a small screwdriver into the hole and it will release the drawer.
Mar 16, 2009 | Aiwa Audio Players & Recorders
Cd player keeps opening with cd in it
Some small item would appear to be obstructing complete closure
With the drawer open take a good look in side.
Also near the  open button you  should see a small pin hole[sometime on the back of the unit]
 This is the emergency eject device in case you get a jam and is operated with the end of a paper clip.
give it a poke with the drawer open  then again closed
See what happens
Oct 20, 2007 | Memorex MKS5001 Shelf System
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Technics SCEH790 CD Shelf System Logo
366 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
