Question about Panasonic PT-47WX42 47" Rear Projection Television
CONVERGENCE BLUE OUT OF ALIGNMENT
Kindly assist me in my PT-47WX42 47INS on the 10th of July 2008 when i switched on my TV the blue ghostly image appeared at the bottom, i tried everything on the remote, but the blue cross is only moving from right to left and top to bottom as do does the red. i bought my TV in 2004, please if you have an after hours contact no i would love to communicate with you. Thanks in advance
  • DEVBALLY Jul 15, 2008
    I bought my PT-47WX42 PANASONIC TV.in
    2004 and this week July 10th 2008 when
    i switched it on the blue convergence
    at the bottom of the screen is appearing ghostly or showing scathered
    the remote is moving the blue cursor
    from only left to right and not top to
    bottom like so do does the red. kindly
    help me without i having to change
    any part. THANK YOU
  • 6,487 Answers
Check this link for some tips.. http://www.popularmechanics.com/technology/upgrade/2826881.html
Hope that helps................
Posted on Jul 15, 2008
    Genius:
  • 1,847 Answers
I don't think you'll be able to see the bowl properly. These problems are usually due to blown convergence ICs, which need replacement, along with perhaps some resistors and a check of the entire convergence board.
  • Legin Varghese
    Legin Varghese Jul 15, 2008
    Sometimes the TV will "click" back into convergence if you leave it on for a while (if it does this don't turn it off until after the Superbowl), however, it will go out again and will need repair and it's better to repair it sooner than later.
  • Legin Varghese
    If this answer was helpful kindly rate fixya..
    Post back if you have any questions.
    Thank for using Fixya...
  • 790 Answers
Hi you have defective convergence amplifier!
Thanks!
  • 1 more comment
  • carlos fernandez Jr.
    carlos fernandez Jr. Jul 15, 2008
    this is convergence correction amplifier problem! this parts need to replace a new one.. if you have a knowledge in electronics repairing i can teach you how to fix this...
    Thanks!
    dont hesitate to ASK me... I can give you step by step repairing method....
    Thanks!
    ok sir can you take a picture your unit to see what happen exactly! you can add picture here...
    Thanks!
Blue line Ghost Image on Panasonic Projection TV
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This set uses two Stk-392-110 convergence IC chips; both need to be replaced along with any of the 2.2. ohm light blue resistors around them; a bad resistor will be white in the middle; You can buy both for less than 13 dollars plus shipping on Ebay.
The chips are located on metal heat sinks with fins and are side by side. They are black(about 2 inches wide by 1 1/2 tall) and should have the STK-392-110 number printed on them in white.
Depending on your level of skill at this kind of work you may be able to do it yourself---if you need step by step instructions contact me---I have them in Microsoft word---start to finish repair including what you will need to do it.
If you are not able to do the repair yourself now is the slow time of year for TV repair shops----It should be fixable right in your home and the repair takes about an hour--I have done hundreds of these sets--some shops charge 300-400 but I do lots of them for 200-250 total cost. Make sure whoever you get changes BOTH of the chips!
Shop around and if they say "needs to go to shop" keep looking; any good tech can do this right in your home.
I do this here for free so if this helps you give me a vote here. If you need direct help contact me.
etower.766@netzero.net
Aug 27, 2009 | Panasonic PT-51HX41 51" Rear Projection...
I have a Panasonic PT-53WX54J that will not Converge
you need to replace or have professional convergence amplifiiers. If know how to desolder and solder you could repair yourself or in home professional tv repairperson will cost you $275-$400. The convergence adjustments via remote are half the battle the IC's loose clarity over time.
Aug 23, 2009 | Panasonic Televison & Video
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Ghosting - colored shadows - guns out of alignment?
*Screen Looks 3-D
*Colors wont align
Problem #2
Nov 08, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Ghosting in Red, Green and blue
*Screen Looks 3-D
*Colors wont align
Problem #2
Sep 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Convergence problem, blue ghosts
you need to replace both convergence ICs they are both STK392-110 you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Sep 01, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Ghostly image with more Blue in Picgture
Yes you need to replace both STK392-040 convergence ICs. You can get new replacements at the following link and they provide free instalation instructions with pictures so you can do the repair yourself in about an hour. They alos have free online instant messageing available to all there customers. heres the link.
May 26, 2008 | Samsung PCL6215R 62" Rear Projection...
Blue ghosting on Panasonic PT-47WX49E
your convergence IVs need to be replaced. Its an easy repair if you can solder. you can get the two ICs you need at the following link. they also provide free installation instructions and free on line tech support while youre doing the repair. You need two ICs they are numbers STK392-110. Let me know if I can be of further assistance. I am one of servicemanuals support techs and board rebuilder.
Apr 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Blue color gun off line
Milt,
What are you referring too when you ay the blue color gun is offline? Is the blue crt not lighting? Or just the convergence alignment off??
Bill
Nov 23, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Convergence images?
The blue picture tube of a projection tv is usually the weakest in ability to focus and in most cases loses its focus ablility before the red and green. Connect a cross-hatch generator to the rf inputs of the unit and check to see which areas are most out of convergence. The corners are usually the worst. HD will always bring out the slightest imperfections. If the unit was totally out of convergence, I would have suggested replacing the convergence IC'S.In my experience with rear projection, your problem is normal wear . You could conceivably improve the picture by adjusting the blue focus on the screen focus block. Scrivitron
Jun 15, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
