Question about Sony SA-VA100 System
SA - VA1
Hey,
I read your post about the Sony SA-VA1 speaker wires. Were you able to locate any?
I was just given these SA-VA1 Sony Speakers but I don't have the wire.
Thanks
  • kodjabashia Nov 03, 2008
    Same situation, Got SONY SA-VA1 speakers but without the R-ch audio cable. I called authorised Sony part dealers for UK www.semenedis.com on 0871 222 9333 and they said it is a special request and incl. p+p will cost over £60. Then I've tried other global sony websites such ashttp://servicesales.sel.sony.com/ecom/ac... and it is available oly in USA the part cost 13$ (if I got it right). PLEASE HELP!
    Problem Solver:
  • 19 Answers
Hey you might find a solution on this audio and wiring blog: www.audioholicblog.com
Hopefully this helps! Good Luck!
Dannyboy!
Posted on Sep 20, 2008
    Problem Solver:
  • 14 Answers
Sorry m8 - ain't had any more time to research the lead.
The answer round here seems pretty much to get yr wallet out and try the Premium assistace Plan (I'll keep the cash and buy the lead from Sony ;)
M
Posted on Jul 18, 2008
I need the wires to conect two speakers sony sa-va100r
Which two speakers?
http://www.retrevo.com/support/Sony-SA-VA100-Speaker-Systems-manual/id/22986ci669/t/2/
The speakers themselves appear to use standard spealer wire with bare ends. Just get a roll of lamp cord at the hardware store and cut it to the length you need.
Between the two front speakers they require a standard RCA stereo audio cable.
http://www.searspartsdirect.com/partsdirect/part-model/Sony-Parts/Audio-equipment-Parts/Model-SAVA500/0996/0311400/50017803/00001
If you're needing the flat cable the link above is a breakdown of the various components. Perhaps you could contact them and describe which 'wire' you need.
Some other possibilities...
1-777-117-11 CORD (WITH CONNECTOR)(15P)
http://www.encompassparts.com/products/?1-691-777-11
http://www.partstore.com/Part/Sony/Sony/175134713/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=SAVA100
Feb 01, 2011 | Sony SA-VA100 System
How do i hook up the wires from and to a sa wms 315 subwoofer
what r you hooking it to is #1 rca wires r the way to go when hooking up a subwoofer up .some subwoofers have 2 rcas on them one input and one output the in put is mono if what your going to hook it to has rcas on it then the left one is a mono output but if its an audio system then it mit have a subwoofer output on it
Jun 29, 2010 | Sony SA-VA1 Rear Speaker
The system worked fine but has an intermittent connection in the main power tower unit..you can shake the unit or bump it heavily and the sound from the main tower speakers goes and comes with a lot of...
They are prone to bad solder connections on the power regulators and output ics. should only be a labor charge. est $60 -100
Not very easy to take apart, need to remove several screws on rear of unit, remove front grill remove some screws on front. disconect connectors remove amp and power supply board, resolder bad connections and re-assemble. I've done several would take me 30-45 min.
Nov 12, 2009 | Sony SA-VA1 Rear Speaker
Need connector to a sony sa-va1 right and left speakers
Are you looking for connectors on speakers or need wires that hooked in speaker and home theater system?
Please intimate model number that is written on main home theater system to provide you info about speaker wires.
Jul 11, 2009 | Sony SA-VA1 Rear Speaker
Dead??
Hiya,
Ok check the mains at the primary side (beware major shock hazard) make sure you are getting 220 (or 110 depending location) into the transformer. If thats there, test across the 8 or so leads out by checking them one after another. In other words test wires next to each other. Make sure meter is set to AC. If the highest reading you get is 4, then faulty. If you are getting higher readings, around 12 and 30, then revert back, will have to back a little more precise
Jul 10, 2009 | Sony SA-VA100 System
THE SEARCH FOR SONY SA-VA1 SPEAKER WIRES
HEY COWBOY, I ALSO JUST PURCHASED A SET OF THESE TODAY FROM A D.I. STORE IN SALT LAKE (JUST LIKE GOODWILL BUT MANY TIMES BETTER) I TOO NEEDED THE CABLES AND FOUND THEM ON EBAY. HERE IS THE ITEM DESCRIPTION MAKE SURE TO ENTER IT INTO THE SEARCH BOX EXACTLY LIKE I AM GIVING IT AND IT WILL TAKE YOU DIRECTLY TOO THE ITEM.HERE IT IS....Sony #177553111 SAVA SA-VA 1 27 29 55 57 59 SPKR CABLE IF YOU HAVE ANY PROBLEM PLEASE EMAIL ME. i also bought the cable it was i believe 24.95 and 7.95 shipping i think. i used to own this set and they are a very nice tower speaker and sound very good i was fortunate to get mine today for 15.00 minus the center and rears. later jim
Feb 02, 2008 | Sony SA-VA1 Rear Speaker
Sony SA-VA100 System Logo
278 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
