Question about Pioneer Audio Players & Recorders
Pioneer CDJ-500S error 9103. - Pioneer Audio Players & Recorders
  • 515 Answers
9103 error is a traverse assembly issue. Unfortunately, there is no easy fix for this. You will have to take it to a service center for repair. They will in turn replace the Traverse assembly, or find out why it's giving this error. If the traverse assembly is replaced, they will also have to calibrate the unit according to Pioneer specs.
- Davis
Digital Analog Therapy
www.repairnyc.com
Posted on Jul 15, 2008
Pioneer CDJ 100 Error E-8301 by every CD
I don't understand your question...please make it clear.
Feb 26, 2015 | Pioneer CDJ-100S CD Player
How do you replace a pioneer cdj 500s laser pickup correctly. Please give as much detail as possible as i have replaced one but its not reading the disc properly
Unfortuneately you should have replaced the whole laser pickup assembly, they come pre-aligned eliminating special test equpment that would be required when single part replacements are done.
Apr 09, 2012 | Pioneer Audio Players & Recorders
PIONEER CDJ 400 E-9101
E-9101 error is mechanical time out. You need to clean compartment to your player, dirt or dust may be there into insertion compartment to the CDJ
djajay
May 13, 2010 | Pioneer CDJ-700S Turntable
CDJ 100 s PROBLEM E-9103 and E-7201
E-9103 is MECHANICAL TIME OUT,
Solution : some object in compartment slot, remove it, or clean player compartment
E-7201 is disc cant be read in 20 seconds,
Solution : Disc has scratch, Replace disc
Disc is dirty, Clean disc
Dj ajay
djajay@inbox.com
Feb 03, 2009 | Pioneer CDJ-100S CD Player
Error on CDJ500s 72 01 and 82 01
well...then....
I'm in NEW england.
There are a few places that are listed online that service those.
I'm sure someone in the London area too.
Cheers back
Scott
Jan 27, 2009 | Pioneer CDJ-500II CD Player
Cdj-700s
Hi Je remy
I have a 700s too, it´s showing problems similar to yours. Mine is even worst, it almost doesn´t play no more (shows "NO DISC"). Sometimes, when i turn it off and on, or open the cover, it reads... When pause is pressed, it holds the music for some seconds, then it "slides" thru the music... Sometimes it display an error message (something like E-8something).
I think all these errors are caused by a worn optic reader, but i´m not sure. I´ve already opened my unit and cleaned the lens, but no bail.
Here in Brazil a new optic reader can be found for R$150 (around U$90). I´ve just found out the same unit in UK for 150 pounds, so i´m suspicius that those units sold here aren´t really new... I´m planning to replace mine, but first i must be sure that the problem is really caused by the reader.
I don´t know if u have already opened yours, but it´s pretty simple to replace the unit, just some screws to loose (12, if i´m not mistaken - 4 ouside, 4 holding the lens protective cover, and 4 holding two inox sticks where the reader slides over). 700s´ units are Part No DWY1067, and you probably won´t find those anymore. You´ll only find the DWY1069, originally found in CDJ-100s (technically almost same, but probably some newer technology), but they´re totally interchangeable.
Hope could be of some use.
If u want, can contact me at nandoseiji@hotmail.com
This is the unit seller here in Brazil:
http://www.quebarato.com.br/classificados/unidade-otica-optica-leitor-para-do-cdj100-cdj-100-cdj-100s-cdj100s-cdj-500s-cdj-700s-dwy-1069-dwy1069__181502.html
http://www.eletronicamaster.com.br/produtos.asp?produto=3991
Mar 28, 2008 | Pioneer CDJ-700S Turntable
274 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
