Question about Price Pfister Ashfield Single Control Lavatory Faucet ...
Just bought a new single handle faucet for my bathroom sink. When i installed it, the cold water run perfectly but the hot water has no pressure and just trickles out. I had the hotwater line pump into a bucket so i know there is nothing wrong with the plumbing in the house. i also swapped line feeds for the hot and cold so that the opposite line would pump the hot water and the problem is the same. any ideas?
    Scholar:
  • 159 Answers
Sound like a diverter, just take the faucet back to where you bought it and get another one or another brand, take care and good luck.
Posted on Mar 04, 2011
SOURCE:
Which is the good single handle sink faucet?
Eyekepper is a good sink faucet. The sink faucets come with Matching Esutcheon Cover Plate Chrome and many other amazing facilities. The faucets provide both hot and cold water and it comes with a lifetime breakage warranty and 30 day money back guarantee.
Specifications
  • Color: 6009-Chrome, Chrome
  • Finish: 6009-Chrome
  • Mounting: Deck-mounted/ Single hole
  • Number of holes: 1
  • Handle/ Lever placement: Centerset
  • Number of handles: 1
  • Main Body Material: Zinc Alloy
  • Spout reach: 3.1 inch
  • Spout height: 5 inch
  • Overall heights: 6.3 inch
  • Water Mode: Waterfall
  • Water Feature: Mix Hot and Cold
  • Water Pressure: Minimum 0.5 bar, 1.0 bar recommended
Pros & Cons
Pros
  • Beautiful design
  • Inexpensive
  • Convenient
  • Easy to install and use
  • Fine quality
Cons
  • Noisy activities
Apr 02, 2018 | Plumbing
I just had a new price pjister series 40 (Ashfield collection) single control lavatory faucet installed. Our contractor installed it yesterday and he is now out of town for a week. Since the sink and...
You have already checked the two obvious things now make sure the two supply lines from the shut off valves are not kinked or turned it such away as to close off the water flow. If that is ok then there may be some debris in the internal filter screens.
Keep in mind that this faucet design will not put water out at a high pressure if it did it would splash all over the place.
Mar 08, 2011 | Price Pfister 042-YP0E Ashfield Single...
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
Have hot water in the bathroom sink spigot, but the shower is the single handle and turned on all the way, water is not hot...too much cold mixing, How do you adjust it?
You need to take the handle off...ususally held on with a small allen screw on the bottom side of the handle. After removing the handle there should be a dial setting.
Feb 18, 2011 | Delta & Single Handle Shower Faucet
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
I have an American Standard single handle faucet in the bathroom.. When you open the faucet fully the flow rate is very small. The faucet was fine before. How do I adjust the faucet to so that the flow...
What is likely happening is a small piece of sediment has become lodged in either the mixing valve or in the aerator.
Begin with the easiest part first. The aerator is the threaded attachment from which the water comes out of the faucet. Remove the aerator from the faucet and run the tap without it installed. If the flow rate is good either clean or replace the aerator.
If this was not the problem then the solution becomes much trickier because the obstruction is likely in one of the lines coming into the faucet or in the body of the faucet called the mixing valve. This is where the hot and cold water mix inside the faucet.
Our next step is to create negative pressure inside the faucet in an attempt to remove the buildup restricting the flow.
If you don't have shut off valves under the sink you will need to shut off the water supply to the home, remove the faucet from the vanity/sink and perform the following procedure.
Shut the hot and cold water off underneath the sink and remove the supply lines at the shut off valves but leave them connected to the faucet. You will need to purchase two adapters for the aerator that will allow you to connect a garden hose from your closest water supply (kitchen sink) to the vanity faucet. You can find these at your local hardware store. You will also need a pail under the vanity to catch the water coming out of the vanity faucet supply lines. Connect the garden hose from an active water supply to the vanity faucet. With someones help have them turn the water supply on which will then run backwards through the vanity faucet and into the pail underneath the vanity. Be sure to open the vanity faucet taps to full so that water will run through the faucet. This should dislodge the obstruction.
Jul 24, 2010 | American Standard Ceramix Monoblock...
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Mar 24, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
Cold water only from single-arm shower faucet in master bathroom
Yes - This is an easy (though not widely known) diy fix! Remove the cover of the faucet handle (may pop off if crystal type or use a screwdriver to remove the screws) inside there is a scald guard safety mechanism - using a flathead screwdriver, turn the guard some the left. There should be a guide so that you do not turn the water up too hot. If there is not, you may need to consult a plumber or supplier in order to adjust the hot to a moderate temperature.
Hope this helps! ;)
Aug 27, 2009 | Kohler Home
Price Pfister Ashfield Single Control Lavatory Faucet ... Logo
291 people viewed this question
Top Price Pfister Plumbing Experts
Marvin
Marvin
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
