Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony Vega Service Codes
When I turn my Sony Vega Model KV-32HS510 tv on, the standby light blinks seven times, pauses then blinks seven times again. Could you tell me what needs servicing???
  • 4 more comments
  • lynnkbird Aug 01, 2008
    Exactly same thing happens. Standby light flashes but set never turns on. Have tried pulling plug...waited 36 hours first time and it went back on. 48 hours second time and it went back on. Pulled plug when went on vacation and it won't turn on after 10 days! It's only 4 years old!
  • Anonymous Sep 09, 2008
    7 flashes and tv does not come on
  • Kencap Oct 19, 2008
    I have the same problem on Model KV-36XBR800 s/n9031358 Have been suggested the high voltage regulator, but where to find, cost, how to replace
  • Anonymous Nov 03, 2008
    Sony Wega KV-32HS510 TV Standy by light blinks 6 times - A technician friend of mine, gave me a can of air and said to clean inside the TV. Will this work? He says sometimes the circuits get real dirty, and that the tv won't turn on due to over heating, because of all the dust.
  • hpontap Nov 04, 2008
    Same Here, waited 36 hours, it fired up. Now it won't. Has a 2003 born on date, bought it in 2004. Flashes six times power on, seven times power off, or vice versa, you cant tell.
  • Anonymous Mar 31, 2014
    (sony trinitorn model, KV ES 34 M80) Our tv goes on standby mode as soon as we try to turns it on,some times the green light comes on three or four times and then red light continues blinking and doesn't turn on.But some times it turns on for couple minutes and then suddenly goes to standby mode and doesn't turn again and red lights blinking.Please tell me how to resolve this standby problem? Thanks.
  • 4,234 Answers
The 7 blinks indicate an over voltage condition. The high voltage section has exceeded 33,000V. This is generally caused by a bad regulator. I don't have a listing for your model, but there should be a multi-pinned IC attachd to a heatsink marked STRxxx located close to where the AC cord comes into the set. Post the actual marking here and I'll get you the part number and cost. That is the regulator that may be the problem.
Dan
Posted on Jul 15, 2008
Why does my sony weta model KV-32HS510 stand by indicator blinks 6 times?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 31, 2014 | Sony FD Trinitron WEGA KV-32HS510 32" TV
What is the life span for the Sony Wega KV-32HS510?
10,000 continous woking hours is calculated to most of the CRT based TVs.
It is only calculation, but the life span might be much more that that. I've repaired a Sony TV recently, which was released by Sony Corporation Japan. The model is KV1820, an 18" Trinitron TV, still works perfectly. Just see, it is an '80 model one.
Turn on my Sony FD Trinitron WEGA KV-32HS510 32" TV, you hear a click, and then it blinks 3 times pauses and repeats.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. This is the fault with 3 blinks. If you wish to get more, check the site linked here.http://electronicshelponline.blogspot.com/ Pull up previous posts, either by brand search, or view it in Mosaic / Timeslide / Flipcard option.
Aug 18, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Jan 19, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
537 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
