Question about Sony PlayStation 2 (PS2) Console
Please any one help me
Am sorry i worded my last question wrong
it is blowing the fuse in side my playstation2 every time i turn i on i haveno clue why
Unplug your ps2 and take it to a qualified sony company they should be able to tell you whats wrong and fix it
Posted on Jul 15, 2008
My Suzuki Boulevard keeps blowing the ignition 15 amp fuse shortly after replacing it.
Hi, Greg gotta love that first name your left turns are definitely a clue to a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short in your case I would jump right to the ignition switch. For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day. keep blowing fuses Fixed
Fuse Panel
Classic Cycles Motorcycle Technical Resources
https://www.tradebit.com/filesharing.php/search/0/2005+suzuki+boulevard+c50 $10
Feb 25, 2016 | 2005 Suzuki Boulevard C50
15 amp fuse blows and no running lights. What's wrong?
Hi Anonymous, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and connect it to the power side of the, circuit breaker or the blown fuse receiver, start by tracking the out bound wire towards the ignition switch and beyond if necessary, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Apr 06, 2012 | 2006 Harley Davidson FLHX Street Glide
Still Blowing fuses
there could be something wrong with moisture. I had a drink spilled down the back of mine and I had to clean the board cause it kept blowing fuses.
Aug 18, 2017 | JBL EON 515
1998 Ford explorer keeps blowing the fuse for the right turn signal. Have replaced 3 times now but it only lasts about an hour before it blows again. Please help. Thanks. Dawn
check for a ground short, also check the bulb sockets that flash on that side of the
vehicle, one of the sockets could be bad
Nov 15, 2011 | 1998 Ford Explorer
1999 cadillic catera only blowing cold air on passerger side of car
there is actuators that open the vent doors for both sides of the car and they get stripped out .every time you turn the car on they close and re open 2 the last setting when its turned back on so they are used alot. With the knowledge of what was wrong but no clue where they were it took 2 of us 8hrs to find and remove them, we just tied the vent doors open because the whole dash would need 2 come out 2 fix properly, the one you are looking 4 is behind the radio near the floor on the passenger side, Keep in mind I had 3 that were bad so it shouldn't take as long 2 do 1
Nov 11, 2011 | 1999 Cadillac Catera
Hyundai sante fe 2001 V6.. I replaced the heater controls (as there was a problem causing fuses to blow when you turned the fan control on), So thats problem 1 solved, Now.. When i turn the key it...
No I think there is something else on the circuit which is bad, and you replaced the wrong thing. In other words the heater controls were not blowing the fuse and the fuse box is doing its protection job, at least was until you melted it from putting the wrong fuses in it. Adventures such as this show why it sometimes saves time and money to simply pay someone who knows what they are doing to do it right the first time. Electrical systems today are so complex that someone with all the info and tools at had is required to fix them.
On the back of the panel you will find one side of the fuse is connected to 12 volts, the other side has some connectors, or has one connector wire which takes the 12V to a set of connections. You have to disconnect each of those connections, one at a time, and replace the fuse until you find the one which actually has the component which is drawing too much current for the fuse. Then you either live without that component or go buy another one.
Sep 16, 2011 | 2002 Hyundai Santa Fe
Blowing high limit fuses
Check the blower wheel attached to your motor.
It may be free-wheeling causing too high a temp thet is blowing the fuses.
Feb 22, 2009 | Amana ALE230RAW Electric Dryer
My heater works on my side,blows cold on passanger please help
have you checked the coolant level on the car to make sure its full?
Jan 21, 2009 | 2004 Jeep Grand Cherokee
Washing machine fuse blows every couple of washes
the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then. it shouldn't since it wasn't blowing everytime on the 15 amp circuit, but never put a 20 amp fuse in a 15 amp socket! the fuse can handle the load[ no pun intended], but the electrical wire would burn not blowing the fuse, thus causing a fire.
hope this helps.
wg
Feb 17, 2008 | Creda W100FW Front Load Washer
Amp blows fuses "immediately"... HELP
for this to cause a problem with amplifiers there is something internally wrong with it. Most of the time the mosfets take a shit from the hot...cold....hot....cold atmosphere its put in by all of us audio people. If it still has warrenty that would be the easiest route to go. Send it in to them and have them fix it for FREE lol!! well sorta. Hope this helps you understand why you are blowing fuses.
Apr 18, 2007 | Power Acoustik TS1920-2 Car Audio...
Sony PlayStation 2 (PS2) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
