Saeco Odea Giro Plus Coffee Maker Logo
Posted on Apr 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I've got a saeco odea giro plus. 3 weeks old, the descaling ight came on. I followed descaling steps in manual. rinsed off brew group and place it back in unit. now the system will prime, grind, I hear it go to the next step, the pump comes on to start brewing the coffee and the pump starts to make a different sound (lower volume sound) and no coffee comes out. it will then show the red light that it's lost the prime. any ideas - is something plugged? If so can I disassemble unit and not void he warranty? thanks in advance. I miss my home latte's
nikolay nikolov
Level 2:
Habit-Forming:
  • Saeco Expert 153 Answers
  • Posted on Apr 29, 2017
nikolay nikolov
Saeco Expert
Level 2:
Habit-Forming:
Answers
153
Questions
Helped
75833
Points
231
Look at the brewing group where the top strainer is. The small holes are blocked with coffee. The water can not pass through them.
You will need to unfold the two screws at the top and then remove the strainer, grow and clean it and clean it if the holes are blocked.
Do this only
  • nikolay nikolov Apr 29, 2017
    Do this only if the machine is not rinsing when you start it,for first time.
5 Related Answers
Anonymous
  • 74 Answers
  • Posted on Jul 11, 2008
SOURCE: Red alarm light permanently on!
Hi.
First turnthe machine on.
Then take out everything watertank, dreg draw and brewingunit and have the door opened to the brewing area.
have them out for about 1 minute and then put it back together again.
if this dosent help please check if the machine respond to removing the dregdraw, beanlid.
It will do it by making the constant red ligth flash instead.
if they respond make sure that the watertank is filled to max.
if that is the case it is the watertank sensor that is broken.
Anonymous
  • Posted on Apr 10, 2009
SOURCE: My Saeco Giro keeps flashing red, what's wrong?
Hold the water button in for about 15 seconds.
EsWorld
Ernest R
  • 1618 Answers
  • Posted on Jun 30, 2009
SOURCE: machine stoppped working
Try this remove the brew unit and clean the screen on the unit, then insert unit, and open steam/hot water valve to prime. If that does not work then there might be a malfunction with the pump, I am assuming that the machine is only 2 weeks old?
Anonymous
  • 81 Answers
  • Posted on Jan 21, 2010
SOURCE: New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Anonymous
  • 81 Answers
  • Posted on Mar 28, 2010
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Why are the used grinding pads on my saeco odeo giro very loose and watery
I can personally confirm this fix from another similar question works: "I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough, it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount." My manual didn't have very good info about lubricating the brew group, so I referred to some Youtube videos demonstrating the methods. A sourced a 3rd party food safe lubricant from Amazon which I applied with Q-tips, but in retrospect they also sell Saeco "maintenance kits" which would have been cheaper & easier to apply, plus it includes a new O-ring.
Grinder problem
try to check the brew group
2answers
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
We have an Odea Giro in the office. When we got it I remember the coffee tasted amazing. After few months the taste started to decline and after some time we stopped to use it altogether. I wanted to...
you are supposed to go through the "before first use" instructions....which include filling the resevoir with water and brewing only water until its all gone. then start using the machine normally...remembering that the machine takes a few brew cycles to adjust properly to the coffee being used (this assuming this is the giro plus model which has the feature-"aroma something or other...)
also, descaling would help and removing the brew group and rinsing it out...
4helpful
The coffee grounds lihgt and the descale light flash after I push the brew button on my seaco odea giro.
Same problem here. I've googled and see that there are many people with the same problem but no clues about how to solve it:
My Saeco Odea Giro is flashing two lights alternatelly (Dregdrawer Light and Descaling Light). What's the problem and how can I solve it?
1helpful
2answers
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
1helpful
Machine stoppped working
14helpful
2answers
1helpful
Brew Group will not reset
Hi Neil,
Try to put the dregsbox and driptray on place, close the door and turn on the machine.
When the machine stop again, open the door and put the brewing unit on place.
Best regards
/Mirran
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
