Question about Sharp Microwave Ovens
Replacement of bulb Sharp MW R340B - Sharp Microwave Ovens
  • Sharp Master
  • 9,086 Answers
A New Zealand model by chance?
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
How do I replace the inside light on my R-520 ks Sharp Microwave
I don't know the exact model but most MWs have a plastic panel that pops off easily. Some, however you must take the cover off the MW oven. Just a tad more difficult.
Dec 25, 2014 | Sharp Microwave Ovens
Get a replacement bulb for sharp carousel microwave table top oven .
A quick look at the manual doesn't specify the part #. It just says replace with the same type and not more than 30 watts. http://www.sharpusa.com/downloads/archives/product_manuals/mic_man_r1500_1501.pdf
Here is a link to an online parts place that you can enter with your model #:
Replacement Sharp parts Select from 266 models Microwaves
Dec 08, 2014 | Sharp Microwave Ovens
How do I find a replacement light for my sharp r-320fw microwave
Sharp Carousel Microwave / Light bulb replacement: http://youtu.be/36RE1bG0aVk
Check out this video, it may help you. Looks like they're a common bulb.
Sep 03, 2014 | Sharp Microwave Ovens
Westinghouse wmg281sf microwave Microwave (mw) less than 6 months old and after selecting start the mw makes a noise that seems to come from the light and during operation impedes the power source to the...
Hello mbz... Since the operation is impeded, the problem is more than the light bulb. This unit has an internal short, and should be under warranty for the first year. Return it. Joe
Thanks for choosing Fixya!
Dec 16, 2010 | Westinghouse Microwave Ovens
Find glass turntable replacement part
These are the glass trays listed to match the models you gave (NR961T is actually MR961T) and they are all shown as no longer available from standard suppliers:
MW-7600-04 MW-7600-06 MW-7600-11 MW-7600-13. MW-7600-12 should also work.
You can order one of the -11 or -12 trays by part number here.
It may take a week or two, and they may reply back that they were unable to find one, in which case they will not charge you.
If you can't find one, you can check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round". (I've seen them at Wal-Mart).
In some cases, two microwave-safe plates can serve as a makeshift replacement for a missing tray. You have to find a saucer that fits securely on your turntable support, though. Here;'s a photo of that, too.
Jul 17, 2008 | Welbilt MR755T Microwave Oven
Microwave Fuse
behind the MW panel
Unplug the MW
took 2 screws from the top plate than one screw for the panel
May 13, 2008 | Sharp R-1481B Microwave Oven
Microwave Ovens Logo
85 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
