Question about Rolex Daytona 116520 Wrist Watch
Problem with my Rolex Datejust
Once I set my watch and turn clockwise it will work for approx 4 to 5 min then it just stops. At first I thought maybe I just wasn't moving enough because it works of of Kenetic energy but that wasn't it either. Do you know what the problem could be?
  • Anonymous Dec 23, 2008
    mines doing the same. trying setting it then re seting it. if u dont like doing this then take to a shop
    Master:
  • 505 Answers
1 maby the battery it low
2 maby needs to little oil on the hands
witch any watch repair shop should sell some
Posted on Jul 18, 2008
Watch keeps running but cant move hands to set time on rolex datejust
Debbie is the watch definitely genuine?
It is a common fault on fake Datejust's..is the crown completely out?
Mar 29, 2013 | Rolex Datejust SS
If the watch is not worn for a day, is it normal for it to stop or slow down? Vintage SS mens datejust, oyster perpetual.
mcdevito75 here, Yes it is normal, especially if your Rolex is an automatic watch. The motion of your Wrist / Hand keeps your watch wound thru the Counter balance on the movement, as the counter balance turns it winds the mainspring little by little, thus keeping your watch wound. Once you take off your watch, if long enough the mainspring simply un-winds and slows and will eventually stop your watch completely. You can keep your Rolex wound even when you take it off by means of a watch winder, a small machine that will keep your watch in motion, or by hand, by rocking the watch back and firth in your hand for about 30 seconds, say before you gpo to bed at night, this way there is always some wind to your watch.
Aug 15, 2010 | Rolex Datejust SS
Time so fast
If we are talking about 30/60sec per day then a regulation can be done.If you are talking of 30 mins per day there is a problem.Either way you need a Rolex watchmaker,if the watch is 4/5 years old then it may be time to service the watch.
www.rolexrepairs.co.uk are expert Rolex specialists and will provide a free estimate or give them a call.
Regards
Aug 09, 2010 | Rolex Datejust SS
How to set rolex datejust turn-o-graph 116263 time
Unscrew the crown, pull it out and set the time by turning it. After setting the time push crown back in and screw it back on flush with case. Rate me, plz.
Mar 15, 2010 | Rolex Datejust SS
Does anyone have a manual for a datejust rolex
No, there isn;t any downloadable manuals for Rolex watches, but operation of Rolex Datejust is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in date setting position,
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Feb 03, 2009 | Rolex Datejust SS
Rolex oyster perpetual datejust time/date setting instructions
Unscrew the crown pull out the crown to the first position, One click and rotate the crown clockwise. This is for Quick Set models
For non quickset
Dec 30, 2008 | Bulova Watch
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
Dec 12, 2008 | Rolex Datejust SS
Rolex watch stops only when I wear it
Kristy,
Stress won't affect your watch's timekeeping ability, but position will. When you lay the watch down at night, in which position is it? Also, during the day, is your arm in a static position for long periods of time? A Rolex chronometer (like the Datejust) should run approx. 36 hours after being fully wound -- without any movement. If the watch stops dead, then there is a problem with the movement and/or rotor. If it losses time, I'd bet on a static position problem. Let me know the answers to those questions and I'll try to help you get to the bottom of the problem.
Nov 06, 2008 | Watches
Setting the time
There are two positions for the setting crown all the way out is to set time,one click out to set date.To set the date you must first set the time by moving the hands around clockwise until you see the date change(midnight) then continue around to the correct time.Then push crown in on click and set the date
Sep 23, 2007 | Rolex Daytona 116520 Wrist Watch
Rolex Daytona 116520 Wrist Watch Logo
258 people viewed this question
Top Rolex Watches Experts
Samyfam
Samyfam
Are you a Rolex Watch Expert? Answer questions, earn points and help others
