Question about InFocus ScreenPlay 61" Rear Projection HDTV
Vertical white lines across screen
I get white vertical lines across the entire screen no mater what input i put it on. Need help...Where can i find a service/repair manual?
    Genius:
  • 2,920 Answers
Whatever brand your tv is go there .com maunals it should show u what u need to know
Posted on Nov 03, 2008
On power up I hold the power button down, I can hear some sort of relay kick-on, sometimes a horizontal white line appears across the screen, then it kicks-off, and the red led blinks four times...
White line across the screen indicates that tv got vertical deflection failure problem that may be due to vertical output chip failure. If that kind of problem occurred, tv select protection mode and red light starts blinking 4 times.
Please check vertical output chip in tv main board and replace it to solve tv issue. This job needs soldering work so local tv repair shop will help you.
Thanks.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
White line across black screen (setup mode?) model
if line is horizentle check vertical ic supply and out put capcitor if line is vertical check yoke wirsand cap 560k at horizentle yoke and any print brunt
Jul 03, 2010 | Quasar SP-2725 27" TV
Relisys vertical bars
Sorry this wont help you much, but may put you out of your misery trying to repair it.
The LCD panel has failed. In particular the driver tabs that connect to the physical panel have failed and there is no way to repair them.
The only soloution is to replace the entire panel, a cost that would be close to if not more then a new TV of the same size.
I would put it on Ebay for parts (powerboard, logic board etc), and use the money towards it's replacement.
Peter
Mar 25, 2010 | Relisys RLT1720 17" LCD Monitor
Thin white line across center of screen Fisher PC-32S90
yes there's a lose connection of your tv. It needs to re solder.if you know how to solder .,solder the vertical section specially the vertical I but be careful of short circuite coz it may damage your tv set.
Nov 16, 2008 | Fisher PC-32S90 TV
White lines across TV screeen
if these lines are just at the top of the picture then i would suspect an electrolytic capacitor in the vertical circuit.
May 08, 2008 | Televison & Video
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Dlp white vertical lines
YOU NEED CHECK THE 3 CRYSTALS ( RED, GREEN AND BLUE). CLEAN IT WHIT "DUST REMOVER" ( compressed gas duster) AND REPLACE THE COLOR WHEEL.
Jan 17, 2008 | Televison & Video
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
InFocus ScreenPlay 61" Rear Projection HDTV Logo
412 people viewed this question
Top InFocus Televison & Video Experts
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
