Question about Whirlpool Dryers
My whirlpool model # LHI7801W0 will not start. i blew out a bunch of dust out of the unit but it still will not start.
2 Suggested Answers
revamos
  • 16 Answers
SOURCE: I have a Whirlpool dryer
one of two ways you have a two part front panel the lower part take a flat head screw driver to each side at the top of it and pop it open or at teh top were the clean vent filter is the are two screws remove and at front of dryer pop top open upwards then there are two screws at front to hold panel up
Posted on Apr 19, 2008
Amp fuse 30a keep blowing
You have possibly melted a couple of wires together along the radio circuit. Also the radio unit itself has 1 or more protection fuses actually inside the unit that have blown, usually at back of unit in little bay near the wire clusters.
Check your relays too, a blow out through jump starting can do all sorts of little burn-outs.
Oct 15, 2016 | 2006 Lexus Rx 330
My fridgidaire wall mounted air conditioner sparked from the plug then blew a fuse
call an electrician... faulty wiring ..dont risk trying to use it
a clogged dust filter could have overheated the unit
Jun 18, 2016 | Heating & Cooling
I need a service manual for infocus 2100 series
Check their website. You may be able to find the instructions on there.
Mar 15, 2014 | InFocus IN2100 - IN2116 Multimedia...
I have a gateway m series laptop. the cpu fan was making a bunch of noise. I don't know much bout fixing laptops but i opened the panel n took the fan out completely blew out the dust and put...
if your pc shuts down in 10 second with black sreen it means that your laptop memory was not detected. solution: reinsert your laptop memory (RAM) .. be sure to clean it especially at the contact points.
Jul 05, 2011 | Gateway Computers & Internet
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
Model #mh7130xe made grinding noise then in line fuse blew
Did you replace the fuse yet?
Did the new one blow?
If so, and if it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If so, and if if it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the new one did not blow, and the microwave still makes a growling or grinding noise, but does not heat, you probably have a shorted high voltage diode or a bad magnetron.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 05, 2008 | Whirlpool MH7130XE Microwave Oven
Colors not right on DV10
i had same problem so i opened up the casing of the projector and blew the dust off the inside components. it has been two days without the problem and the picture quality is better. probably an overheating problem due to all the dust. just be careful when taking it apart because there are a few cables to disconnect and a bunch of hidden screws, if it's still under warranty or you don't feel confident taking it apart, i'd send it in to get fixed.
Aug 09, 2008 | Optoma MovieTime DV10 Multimedia Projector
Magnavox tv
I think I'm having the same problem dont knowif its the cale or the TV I have an old one too,gets wavy kinda rolls vertically
Jul 05, 2008 | Philips Magnavox 27MS343S 27" TV
I have a Whirlpool dryer model number LHI7801W0. Drum will not rotate. Motor operates. I believe it is a broken belt. How do I get access to this area to investigate problem and/or replace belt?
Apr 19, 2008 | Dryers
Dryers Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
