I have a GE 1/2hp motor (Lead-R-Line model 5KH47HR1086) used on an evaporative cooler that has sealed bearings and a mounting "disk?" on each end. Is there any way to remove the mounts and repack or replace the bearings?
Technopro
  • 243 Answers
SOURCE: install front motor mount
Probably you have to loosen the rear mounting as well so that you can get a little bit more play in the movement to fir the bolt in.
Cheers
Posted on Oct 28, 2008
  • 366 Answers
SOURCE: how to remove left motor mount 1998 gmc jimmy 4.3 motor
take both frt skid plates off lift motor to ease pressure on mount undo mount center bolt raise motor abit more undo bolts to mount at motor
Posted on Feb 26, 2009
goofduck
  • 490 Answers
SOURCE: can my front bearings be repacked or are they sealed and need to be replaced?
no they can not be they must be replaced they are sealed bearings
Posted on Apr 22, 2009
csmock132
  • 4669 Answers
SOURCE: replace the engine motor mounts and the transmission mount. Would like to know how to do it. Thanks.
Check the frame mounts too. You will have to loosen the bolts and jack the motor up with a jack and a woodblock.
Posted on May 04, 2009
TheMobilian
  • 8220 Answers
SOURCE: evaporative cooler not getting water from water line
The pump is probably gone. the way it works is a float allows the water level to stay the same in the reservoir so check that. Water is pumped up to the hoghair and trickles down into it. A big old blower pulls the wet outside air into the room. We call that one a swamp cooler down here on the gulf. Go outside and spray some water on the unit to cool down the house till you can get the pump replaced.
Posted on May 10, 2009
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
How to remove a radiator form a 2000 jaguar
Removal
  1. Drain the cooling system.
  2. Reclaim the air conditioning refrigerant.
  3. Remove the motor and shroud.
  4. NOTE: Seal the line and the evaporator with plugs.
Detach the air conditioning line. Raise the vehicle.
  • Remove the lower radiator splash shield.
  • NOTE: The splash shield is equipped with hinges which should be treated with care on removal. Remove the radiator splash shield.
    Detach the securing clips.
    NOTE: Seal the line and the evaporator with plugs and Detach the air conditioning line.
    1. Detach the lower coolant hose.
    2. Remove the air conditioning condenser. Remove the securing screws.
    3. NOTE: Vehicles with manual transmission, cable tie the cooling radiator
    4. tach the automatic transmission/power steering cooler.
      Detach the automatic transmission/power steering cooler.
      1. Lower the vehicle. Remove the radiator foam trim.
      Remove the radiator.
    Sep 25, 2012 | 2000 Jaguar S-Type
    Replacement fan motor for weather king 14AJA36AO1 condensing unit
    You dont need all that data , most motors are belly band type 5" motors, the direction of rotation, hp, speeds, etc are whats material to you.you dont have to get that exact motor unless you wish , Any similarly sized, or larger hp motor will work,(never less hp though) GE makes universal replacement "tripsavers" that have a shaft you may cut if required, and reversible rotation, either CW lead end or CCW lead end, (leads being wires, not the shaft end)Unless you have a OEM specific design as in tabs mounted to the motor, you dont need the exact make, just parameters of equal or greater power and similar or reversible settings specifically. Just take that motor into a electric motor shop, sometimes will be called "X" armature, etc or a appliance parts house, Standard appliance, Jonstone supply, Graingers, Burke engineering, etc.I like GE replacement motors with poller bearings, rather than the Emerson needle bearings, or similar lesser quality motors.
    Jan 24, 2012 | Weather King 10AJA3601AH Air Conditioner
    The unit in question is a Master Cool portable evap cooler model #P500A. Everything operates perfectly accept the fan blower unit when turn on. Switch panel lights up but no blower operation. Are their...
    The bearing on the blower motor are probably rusted or stuck from winter storage but you can disassemble the cooler and try to re-grease the blower motor front main bearing to access the rear bearing you have to take apart the blower motor . i had the same problem with my two p500a models and they work perfect now . i couldn't find any replacement parts but if i do i'll post the web site here hope this helps you with your problem N0D0ZE
    Jul 22, 2011 | AdobeAir Adobe Air 550 CFM Portable...
    The fan is loud and the motor is running "hot". Is there a place to oil the fan's motor?
    This is a sealed bearing motor so there is no oil ports. You can blow out with compressed air and spray motor shaft with WD-40. Be careful not to spray any lube inside motor. If you can get to them blow out motor cooling ports .this should help motor run cooler and quieter. Hope this helps you. Thanks
    Jan 02, 2011 | Essick Air Credenza 696 400 5.2 Gallon...
    We have a champion mastercool evaporative cooler single inlet ASA 71 ordered from Home Depot. I am having a hard time finding a 2 speed 1 hp motor for it HELP!
    Hi, I am surprised Home Depot didn't have one as this is a very common motor. I don't know where you are from, but if you look on lone for Grangers supply, or Motion industries, they will have this motor for sure. They both are large suppliers of anything you need in this line of parts. This is a very common motor, totally sealed bearings and body with adjustable sheave, ( pulley ). Please let me know what you find. I will be here to help.
    Sincerely,
    Shastalaker7
    A/C, Heating, & Refrigeration Contractor
    Aug 14, 2010 | Mastercool 67680 Evaporative Cooler Air...
    Howling noise from freezer fan, GE side-by-side
    Replace the fan, Remove the evaporator cover in the back of freezer, and probably another cover for the fan. Unplug your refer first. Usually their are two screws holding the fan bracket to the wall or mount. disconnect the wires, and replace. Their is a newer model evap fan motor that does not have wiring terminals to disconnect, it is hard wired together and you have to practically remove everything in the freezer compartment to get at it. You have to cut wiring and splice the new fan motor in. Fairly tough job. Usually an evaporator fan motor bearing fails from the refer being moved or in storage for a few days at least with the doors closed and the unit unplugged. This allows all that moisture that was in the freezer to get into the metal parts of the fan motor and cause this problem. To prevent this always block the doors open if your refer is going to be off for a few days. This will allow the unit to dry out without damage. Sometimes it was just a bad motor from the factory. Good Luck, Appliance Specialists
    Dec 17, 2009 | GE GSF25XGR Side by Side Refrigerator
    Cooking oil in cooler motor?
    Not a good move; cooking oils leave a sticky residue as they evaporate; you can try this yourself in a skillet over low heat (or in the oven) for an extended time, motor oil does not. Heat generated by bearings can accelerate this and eventually cause the shaft to seize.
    May 06, 2009 | Mastercool 67680 Evaporative Cooler Air...
    Heating & Cooling Logo
    85 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
