Question about Sony Ericsson W900i Cellular Phone
Charging problem Does not register headphones or charger being plugged in unless i move the wire about while its connected?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Ericsson Master
  • 1,001 Answers
  • Advanced Technology,The buletooth headphone ensure clear speech within 10 meters and high-fidelity stereo music .
  • Protect the earbuds when you during runing and workuots have sweat.Compatible with iPhone 6/6s,6 Plus/6s plus, 5 5c 5s 4s,iPad Air, Samsung Galaxy S6,S5,S4,S3 Note 4 3, HTC M9 M8 M7, LG Flex 2 G3 G2, and Other Bluetooth Android IOS Smart Cell phones/Devices
Amazon com Charm sonic Bluetooth Headphones for Gym Runing Exercise Green...
Posted on Jan 12, 2017
Cant connect to hands free bluetooth when i search for a bluetooth its says it has not found a bluetooth handsfree
Posted on Sep 20, 2008
The batery in my sennheiser headphone only last 3 minutes after charging.the chargin lightin the charger dont come on
Obviously your rechargeable battery isn't getting charged. It's probably a good battery as it recovers enough to run for 3 minutes after you try charging it. (all that's happening is the battery is allowed to rest and it recovers a little bit of it's capacity.)
As to why it's not getting charged, it could be the charger or the wiring in the headphones or the wiring in the base or a few other possibilities. You didn't give us a model number or any other details so we can't get any closer than that.
Nov 28, 2016 | Sennheiser Audio Players & Recorders
Both ear cuffs dont work unless i move the rib looking thing by the iron like thing you put in the mp3 mate.i cant lissen to my county or lady gaga....-.-.please help as fast as you can,thankx.
Your headphone wires are broken, and creating an intermittent connection when moved around near the terminal plug. You will need to splice a new Stereo TLS plug to your headphones to repair them, or replace them (recommended).
Jul 04, 2011 | Coby CV-H47 Headphones
I have a blue jet 3 ultra n i just put 2 new batterys on it and all it will do is flash a red light in the top left corner of the battery light on the joy stick and the horn works but will not move what...
Check your battery wiring on the Jet the wires from the circuit breaker need to connect the positive of the front battery to the negative of the rear battery and the other wires connected to the positive of the rear battery and negative of the front battery putting the batteries in series to generate 24+ volts. If you have a voltmeter before you check the wiring set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. If your batteries are wired correctly you should be reading 27+ volts without the charger plugged in and your batteries fully charged. If you are only reading 12 volts then the wiring is wrong and needs to be fixed. Leaving the voltmeter in the charger port plug in your charger and you should be reading 27 -30+ volts at the charger port anything less than 24 volts indicates your charger is not charging Hope this helps
May 22, 2011 | Jet 3 Ultra Power Chair
It wont play music unless the wire is in the right position
This is likely a wiring fault somewhere along the wire itself or at either the connection to the earbuds, or the connection in the plug. Unfortunately there is no way to tell which or its location unless you disassemble the headphones.
If you cant repair yourself, replace as professional repair will be costly and new pair will likely be cheaper (unless under warranty)
Mar 19, 2011 | Skull Candy S2INBT Headphones
I have HDR65/RS65 Sennheiser wireless headphones. I disconnected them to move stuff around, then re-connected them. Now all I get is a 2 second cycle consisting of: 1 second of static that builds in...
Try connecting them to an MP3 player or connect wired headphones to the same source to make sure the sound source is working correctly. If that works, verify the voltage on the batteries is 2.4 volts after charging. Mine stopped charging fully and the headphones wouldn't work at all, but when I connected a couple of AAA batteries to it in series, it worked great.
Nov 15, 2010 | Sennheiser RS 65 Consumer Headphones
Garmin nuvi 260w is not charging with car charger
You have a short in the wire that runs to your unit. Other than holding the wire in the exact location until your charge is complete you would be better off replacing the charging cord. They should be available at your local shop for around $19-$29.00.
May 29, 2010 | Garmin nuvi 260W GPS Receiver
Phone not charging unless i hold it in my hand and squeeze the charger. Same thing happens with a new charger
Try to reduce the length of wire of your cell's charger.Cut the wire of your charger and reduce its length.Reconnect both wires the same way they were connected before and please make sure wires wont touch each other.Set your phone at charge and see if its charging,if not then connect the wires again but differently.
If you have the same problem with other chargers too then the problem is with your charging port.You'll have to take your cell to cell phone repairer.
Thank you!
Feb 17, 2009 | Samsung SYNC SGH-A707 Cellular Phone
S9 headset
I just hooked it up with a usb sync cable to my computer. It was installed and ready to use and the charging light came on. Seems like it is charging as the led went from red to yellow, and it does turn on now. However, it still does not work with the usb cable plugged into a wall charger. If this solution works for others having the same issue kindly post your results.
Sep 16, 2008 | Motorola Mobility S9 Headphones
Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Jan 28, 2008 | Radio Communications
Sony Ericsson W900i Cellular Phone Logo
66 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
