Computers & Internet Logo
Posted on Jan 16, 2011
When i command to zong send me internet setting .then i receive a message from zong network, my handset doesnot support auto configuration of internet setting .call 310 to get help on manual configuration but i cannot understand how i manual configuration of internet settings.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
75
Points
Facebook credit on car town
How to open mms
Hi There
It very simple to solve this problem.
  1. 1st u call your network service and tell to for "Handset Configuration for Internet" then they can send you the configuration massage to internet settings.
  2. When you received the massage you just open the message and save the massage and the automatically it come on default.
  3. And now your Internet setting is complete, then if you want to use MMS
  4. You go to camera setting and set your quality 0.3 then you able to send your mms msg..
  5. Reason is when you capture you photo to you mobile its come very large size decrease you camera picture quality.
Default Setting Picture size :350bk
After Change the Picture size : 100kb
Set you camera 0.3
Thanks
Prashant
tip
Gprs & Mms setting for Pakistan mobile networks
Hi friend i saw that many people have problem about there mms and internet settings.so i try to colect the settings of mms and internet of some networks which are usearound the world. i arrange them by the country name so select your country and get your mms andinternet settings
1.> PAKISTAN >UFONE You can get MMS & GPRS settings for your handset by; Sending your phone's model number in an SMS to 222 Example: P910i or 6600 or razr v3 Or by calling/visiting our Customer Services Centers. To call from your Ufone connection simply dial 333. To call from a PTCL landline, dial 111-333-100.
>MOBILINK Activate your GPRS & MMs connection now by calling 111
>Telenor VIA sms Send a text message to 131 with your handset make and model to receive your handset settings:
For Example:
For Internet Write "Internet" and SMS it to 131.
For WAP Write "wap" and SMS it to 131. For MMS Write "mms" and SMS it to 131.
For All handset setting Write "All" and SMS it to 131.
. MANUAL
You can also configure your handset for GPRS & MMS manually: 1. Configuration for WAP Access Point Name/Node wap
Login name Telenor Password Telenor WAP Gateway IP 172.18.19.11 Port (if required) 9201 Port (if required for HTTP handsets) 8080
2. Configuration for MMS Access Point Name/Node mms Login name Telenor Password Telenor WAP Gateway IP 172.18.19.11 Port (if required) 9201 Port (if required for HTTP handsets) 8080 Relay Server/ Messaging Server http://mmstelenor or http://172.18.15.1
.VIA CALL You can also dial 345 from your Telenor Mobile subscription and our staff will help you configure your handset for GPRS settings.
>WARID
please call Warid helpline 321 or visit out Business Centers to avail this service.
>ZONG To activate MMS send the following command; MMS <space> handset <space> model & sms to 131
on Jan 11, 2011 • Cell Phones
tip
Cellphone Gprs & mms Setting for pakistan networks
Hi friend i saw that many people have problem about there mms and internet settings. so i try to colect the settings of mms and internet of some networks which are use around the world. i arrange them by the country name so select your country and get your mms and internet settings <br /> <br /> 1.&gt; PAKISTAN <span> </span>&gt;UFONE <span> </span> You can get MMS & GPRS settings for your handset by; <span> </span>Sending your phone's model number in an SMS to 222 <span> </span>Example: P910i or 6600 or razr v3 <span> </span> <span> </span>Or by calling/visiting our Customer Services Centers. To call from your <span> </span>Ufone connection simply dial 333. To call from a PTCL landline, dial 111-333-100. <span> </span>Usage Charges: <span> </span>The cost of sending an MMS is Rs. 5.00 <span> </span>The cost of receiving an MMS is Rs. 5.00 <span> </span>Note: <span> </span>GPRS and MMS activation is FREE for all Prepay and Postpay users. <br /> <br /> <span> </span>&gt;MOBILINK <span> </span>Activate your GPRS & MMs connection now by calling 111 <br /> <span> </span>&gt;Telenor <span> </span> .VIA sms <span> </span> Send a text message to 131 with your handset make and model to receive your handset settings: <br /> <span> </span>For Example: <br /> <br /> <span> </span>For Internet <span> </span> Write "Internet" and SMS it to 131. <br /> <span> </span>For WAP <span> </span> Write "wap" and SMS it to 131. <span> </span>For MMS <span> </span> Write "mms" and SMS it to 131. <br /> <span> </span> For All handset setting <span> </span> Write "All" and SMS it to 131. <br /> <span> </span>.MANUAL <br /> You can also configure your handset for GPRS & MMS manually: 1. Configuration for WAP <span> </span> Access Point Name/Node<span> </span> wap <span> </span> Login name<span> </span> Telenor <span> </span> Password<span> </span> Telenor <span> </span> WAP Gateway IP<span> </span> 172.18.19.11 <span> </span> Port (if required)<span> </span> 9201 <span> </span> Port (if required for HTTP handsets)<span> </span>8080 <br /> 2. Configuration for MMS <span> </span> Access Point Name/Node<span> </span> mms <span> </span> Login name<span> </span> Telenor <span> </span> Password<span> </span> Telenor <span> </span> WAP Gateway IP<span> </span> 172.18.19.11 <span> </span> Port (if required)<span> </span> 9201 <span> </span> Port (if required for HTTP handsets)<span> </span>8080 <span> </span> Relay Server/ Messaging Server<span> </span> http://mmstelenor or http://172.18.15.1 <br /> <br /> .VIA CALL You can also dial 345 from your Telenor Mobile subscription and <span> </span> our staff will help you configure your handset for GPRS settings. &gt;WARID <br /> please call Warid helpline 321 or visit out Business Centers to avail this service. <br /> <br /> &gt;ZONG To activate MMS send the following command; MMS &lt;space&gt; handset &lt;space&gt; model & sms to 131 <br />
Sir i have sghf480i set im unable to send photo msge to my ferinds ?
You should check MMS profile setting. The proper setting should be configured before sending or receiving MMS. To retrieve the MMS automatically, you should set the settings at "Auto download" settings. To check,
    1. Go to Message from the idle screen.
    2. Go to "Settings" and then "Multimedia messages."
    3. Select "Receiving options" and "Home network."
    4. Go to "Foreign network" menu and check the status
    5. If it is set at "Auto download", you can receive MMS automatically.
    6. If it is set at "Manual", you should operate MMS retrieve function manually.
For more details, check out this link http://skp.samsungcsportal.com/PRIVOXY-FORCE/integrated/popup/HtgDetailGuide.jsp?cdsite=sg&seq=5310
Mar 10, 2011 • Cell Phones
2answers
I can receive SMS text from everyone but my wifes. I can send them to her and she receives them.
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Jan 26, 2011 • Cell Phones
Mms and internet settings for W200i
Hi, issues like this are related to your network service providers,
not your Cell Phone . In most cases, regarding the text messages, mms and internet settings,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number.
If you can't receive text messages, send and receive mms ,even internet settings when it's inserted on another handset,
Make sure you contact your service provider for help.
Hope that helps.
My samsung s8000h jet will not send or receive pxts on the vodafone nz network
there are really some networks that can't send picture messages to other networks except calls and text messages, not in only in your place it is happening, likewise on my place where i am in at present.for whatever reason, they are having different servers and frequency signals, however, you would want to check these steps. try to check you settings for receiving txt and mms messages. for mms,  1. select messages 2. scroll down and select settings 3. select multimedia messages 4. select receiving options 5. select foreign network 6. configure it to auto download 7. uncheck reject advertisement 8. select save and exit settings.
for text messages, 1.  select messages 2.  select settings 3.  select sending options 4,  select circuit switch 5.  select reply path 6.  select save and exit settings and check.
regards...
To activate gprs in htc p3350
Thank you for choosing Fixya.com
Please follow the instruction below very carefully and make sure that you have load of your sim enjoy.
For Globe Subscribers:
For a complete listing of compatible MMS & GPRS phone handsets — send NOKIA, ERICSSON or SAMSUNG (your handset model) to 2365.
To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1)
Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
Enter 1234 when asked for PIN to save settings.
Send an MMS message for only Php 5.00 to activate the service.
Note: For prepaid subscribers, please make sure you have credits first before trying to access GPRS/MMS. You won’t be able to use the service if you have zero balance.
For Smart Subscribers:
OTA (over-the air) configuration
a) To activate GPRS *and* MMS
- SET MMS send to 211
- wait for the configuration to be downloaded to your phone (up to 24 hours)
- once downloaded, you will have SmartMMS data account, and SmartMMS WAP profile, and your MMS is configured already to use SmartMMS WAP profile
- you will also receive a confirmation message that your GPRS and MMS have been activated
b) To configure internet access (full access)
- SET INTERNET (handset model) send to 211
- wait for the configuration to be download to your phone, in minutes
- once downloaded, you will have SmartPC data account, and SmartPC WAP Profile
- edit this account to include DNS settings. DNS IP addresses are -202.057.096.003, 202. 057.096.004. you only need one.
c) To configure WAP via GPRS
- SET GPRS T68 send to 211
- once downloaded, you will have SmartGPRS data account, and SmartGPRS WAP Profile. SET THIS AS YOUR DEFAULT PROFILE
d) To configure WAP via CSD (Optional - kasi MAY BAYAD ITO, per minute)
- SET WAP T68 send to 211
- once downloaded, you will have SmartWAP data account, and SmartWAP WAP Profile. SET THIS AS YOUR DEFAULT PROFILE
I suggest you clear all your existing data accounts and wap profile beforeyou do this. If you follow the instructions in this order, SmartPC will have a CID=2. Your dial-up number willbe *99***2#
or to simplify it:
Setting up of MMS and GPRS handsets:
To download SMART MMS phone settings, key in SET MMS and send to 211.
To download SMART GPRS phone settings, key in SET GPRS and send to 211.
Activating SMART MMS and GPRS:
To activate SMART GPRS, key in GPRS ON and send to 333.
To activate SMART MMS, key in MMS ON and send to 333
Upon receiving the configuration settings, select "Save All" to save the settings in the phone.
Activation of MMS and GPRS will require a confirmation message from SMART. A message will be sent to the sub once the feature has been activated.
For SUN USERS:
Sun MMS
On the home screen, press the Programs soft key, press More to move to the next page.
Press Accessories then select MMS Setup by pressing the Action button.
Provide the following data on the required field, press Ok when done.
q First field: MMS connection
q IP: 202.138.159.78
q Port: 9201
q MMSC Address:
q Message Expiry: 1 day
q MMS Download: Auto
Press Settings, select Data Connection.
Press the Menu soft key then select Edit Connection by pressing the Action button
Select GPRS Connection. Press Menu then select Add by pressing the Action button
Provide the following data on the required field:
q Description: Sun MMS connection
q Connects to: MMS Connection
q Access point: mms
When finished, press Done four times.
Sun GPRS
Press the Menu soft key then select Edit Connection by pressing the Action button.
Select GPRS Connection. Press Menu then select Add by pressing the Action button.
q Description: Sun GPRS
q Connects to: The Internet
q Access point: minternet
Press Done three times. On the Data connection, select Sun GPRS under Internet connection.
When finished, press Done.
Sun WAP GPRS
q Description: Sun WAP GPRS
q Access point: mms
Press Done three times. On the Data connection, select Sun WAP GPRS under WAP connection.
Sun WAP Proxy
Crate a proxy connection
Description: Sun WAP Proxy
Connects from: The internet
Connects to: WAP network
Proxy (name/Port): 193.113.200.195
Type: WAP
To Activate GPRS:
Create a text message, type "ACTIVATE" then send to 2300
please don't forget to rate our answers properly.
4helpful
2answers
7helpful
4answers
Gprs setting
to connect to the internet or set up email or to send mms you must activate the GPRS first from your network provider ...The best thing you can do is to contact the customer care of your network provider and ask for the activation of GPRS ...
they will tell you the procedure to activate it ....
they will tell the number to which the message to be sent to recieve the settings ....
so note that down and then follow the procedures told by them ...
you will receive the gprs settings(profile) also ... make sure of the charges with them there will be many plans & then get activated ...
after this you will able to connect to internet ....
if the customer people tell you that your handset is not compatible for the receiving of the profile settings then you must tell them to give the manual settings(includes ip address,APN,etc) so that you can only create the profile and input the information given by the customer care people...
if you have already subscribed the GPRS then call the customer care of your network provider & ask for the settings by telling your model of the handset ..
rate my solution
Grand Canyon Tech
Grand Canyon Tech
