Saving appended files in Scandall 21 version 4.3.17
I am trying to append documents with new images and then save the file with all images together in the original file. I am using Scandall 21 version 4.23.17 and a Fujitsu scanner fi-5110C. The Scandall21 does not have a "save" command, only a "save as". It has a "scan to view-append" command but when I go to save the changes after scanning in more images they are not there? Any suggestions?
  • squaremom Jul 15, 2008
    Thanks for your help. Going to the 'save as' box and looking at it more carefully made me see that I had to choose the path and file name of the file I was working in and then check the "overwrite" box to save my file with the original name and place - alot of trouble for saving but it works. Thanks again for your response.
  • 6,487 Answers
Did you try the short cut command for saving which is Ctrl + S? so after using the save as and doing some changes on it try using the Ctrl + S, and check if the changes have been save.
Hope that helps..........
Posted on Jul 14, 2008
    Genius:
  • 1,847 Answers
When you are saving the file make sure you are saving the file in the desired format ... the save as type option.
  • Legin Varghese
    Legin Varghese Jul 14, 2008
    and try saving the file on the desktop.
Tip
Useful Notepad Trick !
This is real cool for people who use notepad to write down any info on a day to day basis.
Open a blank Notepad file
* Write .LOG as the first line of the file, press enter.
* Save the file and close it.
* Double-click the file to open it and notice that Notepad appends the current date and time to the end of the file and places the cursor on the line after.
* Type your notes and then save and close the file.
Each time you open the file, Notepad repeats the process, appending the time and date to the end of the file and placing the cursor below it.
on Dec 10, 2009 | Computers & Internet
Convert i to pdf file
Try this software: http://www.smartpdfcreator.com
Jul 10, 2010 | Microsoft Office Professional 2007 Full...
How do I scan a multi-page document into one pdf file? Every time I try, the machine creates a separate pdf for each page.
From the University of Texas. This document shows how to combine PDF files using Word or Word Perfect.
Combining Multiple PDF Files Into One These instructions assume you chose to label the first of your multiple PDF files "etd.pdf" as suggested in "Creating PDF Files in Word or Wordperfect for Windows".
  1. Open your "etd.pdf" file in Adobe Acrobat.
  2. Select Insert Pages from within the Document menu.
    [view step 2 illustration]
  3. A Select File To Insert popup box will appear. Highlight the file you wish to append to etd.pdf and then select the Select button. (this process will be easiest if you work your way from front to back through the dissertation, appending successive sections to the first file, "etd.pdf")
    [view step 3 illustration]
  4. An Insert popup box will appear. If you are following the suggestion under Step 3, select the After option under Location. Under Page determine exactly where you wish the selected file to be inserted. If you are assembling the dissertation section by section, you will want the file to be inserted after the last page of the current section. In this case, select Last. Select OK to complete this step.
    [view step 4 illustration]
  5. Check the updated "etd.pdf" file within Exchange to make sure this is proceeding in the order you want.
  6. Continue to add subsequent files in the same way.
  7. When you are finished, exit Exchange and save the file under its original name, "etd.pdf".
Hope this helps. I saw nothing in the printer's manual about doing this.
Also Adobe Acrobat will do it also.
Good Luck
Feb 18, 2010 | HP LaserJet 3330 All-In-One Printer
Scandall 21 Automatically Saves Scan As Temp Fil
go into the settings on your computer and change the setting to save all scans
Jul 20, 2009 | Fujitsu fi-5530C Scanner
Using adobe acrobat professional - copy a pdf picture and paste into a pdf.
You can't just do it. Acrobat is not a document creation program.
You can either convert the picture to a PDF file and then append or insert that file in an existing PDF or you can use other program, such as an word processor to create a page in which you include the image and then convert to PDF and append or insert that page in an existing PDF
Dec 10, 2008 | Adobe Acrobat 7.0 Professional
Create access mdb file by vfp code
Try this
#define dbLogical 1
#define dbNumber 2
#define dbInteger 3
#define dbLongInteger 4
#define dbCurrency 5
#define dbSingle 6
#define dbDouble 7
#define dbDateTime 8
#define dbBinary 9
#define dbText 10
#define dbOLEObject 11
#define dbMemo 12
#define dbReplication 15
#define dbDecimal 16
if file("C:\accesstest.mdb")
delete file c:\accesstest.mdb
endif
public oAccess
oAccess = createobject("Access.application")
oAccess.visible= .t.
newMDB = oAccess.NewCurrentDatabase("C:\accesstest")
newtable = oAccess.CurrentDb.CreateTableDef('testtable')
with newtable
.fields.append(.CreateField("Field1", dbLogical))
.fields.append(.CreateField("Field2", dbNumber))
.fields.append(.CreateField("Field3", dbInteger))
endwith
oAccess.CurrentDb.TableDefs.append( newtable)
dbc2Convert = "\\tpdfiles\data\dfreeman\tip\data\rta\rta"
open database (dbc2convert)
dbgetprop(rta,"table",)
After it runs you will need to close the MDB and reopen it.
Oct 15, 2008 | Microsoft Computers & Internet
Microsoft Word malfunction
try this:
1. you may not have user permissions to make changes to the document:
check with the document creator or save the file with a different name so you become the new owner of the new document.
2. check if destination folder has enough room:
if not change the location of the file to be saved.
3. you may be using incorrect characters given the file name when saving the file:
don't use "/" when saving the file.
Oct 03, 2008 | Computers & Internet
Scanning as file type Microsoft Office Document Imaging File, but sometimes it saves it as TMP file
tmp are temporary file type . Something has interrupted the scan before the file was completed and a tmp file has been created.
http://filext.com/file-extension/TMP
have you got enough hard drive space ?
make sure the recycle bin is empty .
Jun 22, 2017 | Fujitsu fi-5530C Scanner
About visual basic coding
The standard way of creating a database using VBA, which can be modified to suit your needs is this--> Note: the code (wspDefault.CreateDatabase("Newdb.mdb"...), can be altered to save the database in a folder  such as "C:\NEWDB\text.mdb". sub NewDatabase()     Dim wspDefault As Workspace, dbs As Database     Dim tdf As TableDef, fld1 As Field, fld2 As Field     Dim idx As Index, fldIndex As Field     Set wspDefault = DBEngine.Workspaces(0)     ' Create new, encrypted database.     Set dbs = wspDefault.CreateDatabase("Newdb.mdb", _         dbLangGeneral, dbEncrypt)     ' Create new table with two fields.     Set tdf = dbs.CreateTableDef("Contacts")     Set fld1 = tdf.CreateField("ContactID", dbLong)     fld1.Attributes = fld1.Attributes + dbAutoIncrField     Set fld2 = tdf.CreateField("ContactName", dbText, 50)     ' Append fields.     tdf.Fields.Append fld1     tdf.Fields.Append fld2     ' Create primary key index.     Set idx = tdf.CreateIndex("PrimaryKey")     Set fldIndex = idx.CreateField("ContactID", dbLong)     ' Append index fields.     idx.Fields.Append fldIndex     ' Set Primary property.     idx.Primary = True     ' Append index.     tdf.Indexes.Append idx     ' Append TableDef object.     dbs.TableDefs.Append tdf     dbs.TableDefs.Refresh     Set dbs = Nothing End Sub
Hope this helps! Please let me know if you have any questions.Thank You,Raph30
Apr 10, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Computers & Internet Logo
285 people viewed this question
David Payne
David Payne
