Question about RCA Televison & Video
Ihave dta800 converter box. ihooked it up right an ihad 20 channels and now ihave 6 channels. then they say i need a bigger antenna but i have a roof antenna.now maybe i need a smart antenna. can you help
  • 520 Answers
Most converter boxes block analog channels.
Posted on Jul 15, 2008
  • Bob Citizen Jul 15, 2008
    Use a splitter and an A-B switch to get all your channels.
How do I get the free digital channels on my tv?
One way you can get free high quality digital channels is an HD antenna. In recent years, the government stopped broadcasting analog (non-HD) signals, and instead pumped out HD. They advertised their "converter box", that made it possible for people receiving their TV channels from antenna, to get HD.
If you currently have an antenna that you prefer to use, you can buy a converter box here.
But, the solution that in the end will get you more channels is a new HD antenna. They range from extremely powerful roof antenna's, to average tabletop antenna's. A roof antenna has more distance, but can be more hard to set up compared to the tabletop ones.
You can buy a variety of tabletop ones Here
Or, you can choose outdoor Here
You can learn to set it up Here
If your TV doesn't have HD capabilities ("HDTV") than you will need a converter box, which can buy at the link above ( or here.).
Hope this helped!
Be Sure To Rate macapplezoo 100% Or Whatever You Think I Deserve!
Jun 05, 2011 | Televison & Video
I am in Los Angeles,Ca. Converter box signal problem
Just go to walmart and buy a good digital antena.Should work great.Just rescan all ur channels again.
Mar 11, 2010 | Digi Sansonic FT-300A tal To Analog TV...
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Scanning channels stops at 20%
the exact same thing happened to my dta800. i unplugged the ant. input at 20 percent and then plugged it back in when it resumed. i dont know why this worked, but i now get my 25 channels instead of the 4. this digital garbage is annoying all around. hope this helps. senor punko
Jun 19, 2009 | Televison & Video
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
Oct 10, 2008 | Zenith C27A24T 27" TV
The instructions for our DTA800 digital to analog converter box for over the air waves for TV signals say since the signal is too weak that we need a SMART ANTENNA. What is that and what do you...
Hey boykinpierce,
The phrase "Smart Antenna" is often used to describe a multi-directional antenna or antenna array. These types of antennas are able to detect and automatically adjust to any changes in the TV signal strength you receive, and can generally be obtained through most major retailers. They primarily are used in areas where digital signals are weaker or somewhat inconsistent, and will attempt to optimize the signals they do receive before sending them to a TV or digital converter box.
Please keep in mind that while some DTV digital-to-analog converter boxes may have built-in Smart Antennas, this particular model (RCA DTA800) does not appear to have this feature.
If you're still not quite sure what to look for, please remember that you can always speak with a home theatre sales agent at your local Best Buy™ store for more information.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 19, 2008 | Televison & Video
Connecting to an RCA DTA800 digital converter?
I got the new RCA converter box I followed the on screen info but i'm not getting a signal from my antenna so it doesn't show any channels
Mar 10, 2008 | Symphonic SC3913 13 in. Combo
Televison & Video Logo
59 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
