Question about Frigidaire Washing Machines
No spining - Frigidaire Washing Machines
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
if this helps please give me a fix ya vote
Posted on Jul 14, 2008
Why Do Kids Need a Chiropractor?
all bodies are held upright by muscles pulling on various parts of the spine , hips and shoulders
\ if the spine gets out of alignment, these muscles work over time to pull it straight which results in headaches , muscle pain and other ailments
chiropractor moves and realigns the spine to reduce that muscle problem
growing skeletons need constant alignment as all the joints are soft and easily damaged it left unattended
Jul 19, 2016 | Cars & Trucks
Tip
What Does a Chiropractor Do?
Chiropracty is an increasingly popular way of treating muscular problems and injuries.Chiropractors generally focus on neuromuscular problems, using spine manipulation and adjustment in their treatment methods.Viewed by most as an alternative therapy, chiropractors consider the relationship between the spine and the nervous system.Chiropracty believes that by treating spinal issues, pressure can be reduced on neurological tissue thus creating broad health benefits.Chiropractors uses a method called chiropractic adjustment to make small but significant alterations to the positioning of the spine.Chiropracty is a very uninvasive treatment method that is usually very effective.
on Dec 16, 2013 | Medical
What is the spine corrector barrel?
The spine corrector utilized for individual needs, stretching, aligning and strengthening the spine. It also relieves stiffness of the shoulders and hips as well as relieving common backaches.
Aug 30, 2012 | Allegro Exercise & Fitness
Turntable won't stop spining
If it is a turnatable that starts spining when the arm is moved to the record, then more than likely the start/stop switch inside the turnable is broken and is fixed in the on position. Or the leaver mechanism has become detached from the arm when the record was playing and left the other part pressing on the same switch that turns the motor on or off.
Removing the bottom of the turntable should should show the trouble.
Apr 03, 2012 | Philips WMM142211 Turntable
Got a dc7600, need to add 2 more monitors, as video cards in my other computers will not fit (too large for slot)..if i can , i need a video card with two slots to attach both monitors or get 2 video...
Which part of the video-cards are "too large" -- the electronic circuitry, or just the "spine"?
If just the "spine" is too tall, then unscrew the spine from the card, and attach a shorter spine.
Or, if you are "brave", then run "*****" -- don't attach any "spine" to the video-card.
Just connect the VGA/DVI cable from the monitor directly to the video-card.
Aug 18, 2011 | HP Compaq dc7600 Small Form Factor PC...
The needle doesn't go up & down. Any suggestions? Thank you
Does the handwheel turn eazy or is it stiff. If it is stiff you need to take the top and bottom off and lubricate all moving parts. may take a bit of turning the handwheel and lubicating(it may tire you out). If the handwheel is not stiff I would check to see iff the motor is spining at all. If motor is not spining may be a bad footcontrol. If it is spining try cleaning the belt pullys and tighting the belt.
hope this helps
Mar 22, 2011 | Kenmore 15516 Mechanical Sewing Machine
Oreck won't pick up dirt.
Check the roller brush, dust channel and then the back spine tubes - two parts which also holds the cloth bag - which holds it at the bottom via a spring. Unhook this, and prise up the rubber rings that hide the push in locks. Push the locks in and the spines should separate.You may need to undo the power cord since it comes out the top near the handle at the bottom. Check both spines and remove clogs with a thin round stick. Put everything back together slowly and switch on.
Jan 12, 2009 | Oreck XL Ultra Bagged Upright Vacuum
The starter makes a tik tik tiking sound
the seloind is gone or the battery is down
Jan 08, 2009 | 1998 Dodge Intrepid
Printing spine labels for books on hp laserjet 1020
convert the doc to a PDF so that the sizes and fonts save. That should fix your issue.
Jun 05, 2008 | HP LaserJet 1020 Printer
Washing Machines Logo
56 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
