Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Pounding noise after wash and final spin
After the initial wash, and final spin my Kenmore 3.2 cu.ft. Super Capacity Washer "thumps" as if it were out of balance until the drum stops rotating, although the load and washer are perfectly balanced. Other than that the machine works great. Please HELP.
  • Anonymous Mar 12, 2014
    The washer works and spins but the drum is setting lopsided. Now I am getting black marks on my clothes. What might be the matter?
  • Anonymous Mar 27, 2014
    Hi. I have a Kenmore Super Capacity 3.5 front loading washing machine and for some reason the door won't open. I recently unstacked the set to work on the house so without the weight of the dryer it seemed to shake more than before. First time I used it since unstacking, the door wouldn't unlock when done spinning.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Posted on Jul 14, 2008
    SOURCE:
    I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
    Front-loading washer Kenmore HE2 plus - spinning not ...
    www.shopyourway.com > Manage My Life > Questions
    My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
    Front Load Washer Won't Drain or Spin Video: Washing ...
    ? 1:54
    https://www.youtube.com/watch?v=wlMoT9rgvAg
    Jun 1, 2012 - Uploaded by searspartsdirect
    ... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
    Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
    www.kenmore.com > Laundry > Washers > Front-load Washers
    KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
    Jan 15, 2016 | Kenmore Washing Machines
    Kenmore washer 3.5 super capacity. Machine spins
    It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
    JimmyC
    Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
    Thumping Noise
    it must be due to the damaged belt inside the motor. check it out.
    thank you
    Mar 09, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Kenmore 90 series noise after spin
    You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
    Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Kenmore 3.5 cu. ft. I.E.C. Super Capacity High-Efficiency Washer
    took the plate of just under the door removed 2 screws then took the black rubber boot that hooks up to the pump and cleaned out the **** that was stuck in there, pluged washer back in after a little crunhin noise everything was back to normal
    Feb 02, 2009 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
    Kenmore Super Capacity Washing Machine
    If your washer is the one you have chosen a Whirlpool built kenmore unit than your washer doesnt have any bearing that fail, It could be the spin tube mounting block becoming stripped ( most common) or a clutch or brakes not releasing issue (not likely). Also make sure the machine is agitating it may just be filling with water and draining and making motor noises. In this case the motor coupling has broken. both the block and coupling are inexpensive parts and easy to install.
    Jan 14, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
    Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
    508 people viewed this question
    fordexpert
    Kristen Denison
    Kristen Denison
    Level 1 Expert
    Jim Chinnery
    Jim Chinnery
    Level 1 Expert
