Question about Pds Hot Buy Store: PIVA DIGITAL 5.1 Home Theater System model -2325 System
Proton Home Movie Machine PDS 2315
When I plug in all 5 speakers to the sub 1 or 2 of them will start to make a very high pitch sound that is rather annoying. I tried different power outlets and rearranging the speakers but nothing has worked. I even cleaned all the connections with no luck.
4 Suggested Answers
Jay_Jay84
SOURCE: pds-2315 surround sound remote control
I am looking for a universal remote that will work the PDS-2315 someone please help
Posted on Jan 19, 2008
SOURCE: protron pds 2315 seroundsound
i need the dvd
Posted on Dec 25, 2008
SOURCE: what is protron pds-2315 codes ?
I need the answer to this question also.
My remote got stepped on and need to get another one.
Posted on Mar 05, 2011
My klipsch ten inch subwoofer is making a high pitch whinding sound when the sub is turned on
my fuse keeps poppin everytime i put a new one when i turn it on how can i fix dat?
Aug 01, 2012 | Klipsch Synergy Sub-10 Subwoofer Speaker
I have all the speakers for the protron pds-2315 home theater system. I just need the dvd player.. Where can I find/buy just the dvd player for this system?
You could check the auction sites. I see the whole set on eBay right now for cheap. When bidding, strike at the last 10 seconds to prevent having to bid against yourself.
Jul 05, 2011 | Protron PDS-2315 Theater System
For some reason, I get audio for the visually impaired when i play a DVD. The original sound of the DVD plays but an additional narrative (describing each scene) plays as well. The DVD is a recent...
Generally, remote controls for DVD systems have a button labeled "Audio". This button changes which audio track you will hear during the movie. Common tracks include English, French, Spanish, Commentaries, and occasionally Audio for the Hearing Impaired.
It seems odd for the latter audio track to be default, but clicking the Audio button until you have the plain English track should work. I would consult the manual if you have it on hand to see if your system is capable of remembering which track to start on.
Hope this helps.
Jun 13, 2011 | Protron PDS-2315 Theater System
What is protron pds-2315 codes ?
Jan 01, 2011 | Protron PDS-2315 Theater System
I have a protron dvd pds 2315, hooked up to a Insignia LCD HDTV, the sceen is completely pink when I turn on the dvd player. I am using the 3 color coded video cable and a regular white/red cable for...
Turn on your DVD player, go to your set up button on the DVD remote, go to TV and select p-scan. It fixed my problem. My screen was all blue before I did that. Hope it works
May 07, 2010 | Protron PDS-2315 Theater System
Trying to get surround sound on TV
The Answer is, "it depends". On the back of the disc player, you will find two RCA connections labled "Main R" and "Main L". Connect these via RCA cables to your "Audio Out" R & L RCA connections on the back of your television. If your television doesn't have rear "Audio Out" connections and a menu option to select between internal speakers and external, you won't be able to connect.
Sep 27, 2009 | Protron PDS-2315 Theater System
How to hook up protron pds-2315
First of all, the PDS-2315 is not a DVR (this question is incorrectly categorized), it is a home theater system. Also, this system is not a receiver -- it is a DVD player (DVD/CD/HDCD/CD-R/CD-RW/Kodak PCD Playback) with a "full function" Karaoke feature with two microphone inputs. If you haven't figured out how to set it up in the past 11 months, this is how you do it.
1. Connect the supplied RCA cables (labled FR, FL, SR, SL, Cen, and SW) to the corresponding RCA connections in the back of the DVD player and the back of the Sub-Woofer.
2. Connect the DVD Player to your television.
A. Video:
There are several options here depending on your available Television inputs: Coax Cable, Component (yellow jack), S-Video and Composite (composite providing the best video resolution and coax the poorest). HDMI is not available. Use s-video or composite if you can. You will note that the composite RCA jacks are colored Orange, Blue, and Green. In a pinch, any RCA Cables will work - just don't cross the color codes between the DVD Player and the television. If you need to use coax you will need a coax to RCA adapter. If your television only has a component jack (yellow), it's a simple connection between the two.
B. Audio:
On the back of the DVD player you'll find two RCA jacks labled "Main R" and "Main L". These will be connected to your Audio Out connections on the back of your television. If you don't have Audio Out RCA jacks on the back of your television, but have an earphone jack, you can purchase an RCA adaptor to make that connection. With rear audio out jacks, you should have an option in your television's audio setup menu to select those outputs. (DO NOT CONFUSE "AUDIO OUT" WITH "AUDIO INPUT" because the will look identical.) If you don't have either of these connections, you will not be able to use the system to listen to television signals.
3. Connect the speakers. Each of the speakers is labled with their position (FR, FL, CEN, SR, SL). The speaker wires are color coded to the spring connectors in the rear of the sub-woofer/amplifier. Press the spring lever and place the wire into the opening. For proper biasing, place the color coded wire into the colored spring connector and the other wire into the black connector for the specified speaker. Connecting the speakers should be very easy. If the ends of the speaker wires become damaged, simply strip the wires back half an inch and connect as above. Place the speakers as specified by their position lables (FL, CEN, FR in front of the television and SL and SR to the right and left of the seating.)
4. Plug it in and power on. You'll need to plug in both the DVD player and the sub-woofer. Press the power button, hit the open/close button on either the DVD player or the remote control and put a disc in the machine. If you don't have a picture or a "Protron" title screen, hit the "P-SCAN" button on the remote (top left corner below the "STANDBY" button).
5. Hit the "SETUP" key and enter your system's information and you're done. Your system will work just like any other DVD player with theatre quality sound. --With the added feature of functioning as a Karaoke machine! Just add proper Karaoke CDs, a couple microphones, a bunch of friends and copius amounts of alcohol . . .
Feb 21, 2009 | Protron PD-DVR100 DVD Recorder
High Pitch Noise Coming Out Of My Subs?
sounds like it could be a warning sound that indicates either a short or a bad connection and is tripping the safety warning. check all speaker terminal connections and connections on the amp to make sure there is nothing loose or touching
Jan 27, 2009 | Fusion FEW12PK Car Subwoofer
Pds-2315 surround sound remote control
Jan 07, 2008 | Pds Hot Buy Store: PIVA DIGITAL 5.1 Home...
Pds Hot Buy Store: PIVA DIGITAL 5.1 Home Theater System model -2325 System Logo
108 people viewed this question
Top Pds Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Pds Audio Player and Recorder Expert? Answer questions, earn points and help others
