Question about Sub-Zero 700TC Bottom Freezer Refrigerator
Door difficult to open
We have a 700TCI 2 Series fridge/freezer. The fridge door has become difficult to open. A vacuum appears to be created inside the fridge compartment. Excessive pulling force is needed to open the door - in fact my wife cannot open the door but I can. To establish that a vacuum is being created inside the fridge I placed a thin self-adhesive pad on the magnetic door seal surface. That made the door easy to open BUT presumably cannot be left in place. What is causing the door to be difficult to open?
  • accarver Nov 09, 2008
    Model 601 R/F. We have the same issue with our door, it takes about 30 seconds after closing the door for the vacuum to dissipate. The vacuum is so strong that we move the whole fridge if we try to open it too soon. The vacuum seems to be getting stronger with time, at least it takes longer before we can open the door. This unit is only 4 years old. We love this fridge and have had no other problems since we plugged it in.
Simple fix! A small puddle of water near the fridge led me (indirectly) to this fix. Our model is a fridge only, no ice or water dispenser and nothing spilled inside. Upon closer inspection I found a narrow tray along the back wall above the crisper drawers with a drain hose leading under the unit. Apparently it's a condensate drain, a plugged one at that! I cleaned it out, yuk, and soon discovered it serves a dual purpose... as a vent to help relieve the pressure from the vacuum created immediately after closing the door. It has renewed our love affair with this fridge. Hoo Hoo!
Posted on Dec 18, 2008
Fridge now constantly CYCLES ON AND OFF for 10 to 15 minutes
Perhaps calling in a refrigerator repair man so he can check the freon as that is what causes them to run alot more than normal
Jun 03, 2016 | Westinghouse Refrigerators
Model et18pkxfno1 serial eg4024334 type c18tfa97\r\nwater drips into refrigerator compartment somewhere from freezer (inside). Occurs daily. Tried to adjust temp in both refrigerator and freezer but...
The problem is that your fridge's drain line (which is located in the freezer) is iced over. So water can't drain out of the freezer when your fridge enters it's defrost cycle. The freezer and drain line needs to be defrosted by hand. Or you can unplug the fridge and open the doors for a 2-3 hours. Eventully, if no action is taken, the ice build up in the freezer will block the cold air flow to the refrigerator compartment .
Feb 19, 2011 | Whirlpool Refrigerators
Why is there no cool air going into my refrigerator when freezer door is shut but works when freezer door is open
Good day,
All cooling comes from the freezer compartment. There is a supply vent connecting the top of the freezer to supply some cold air from the freezer thru the opening on the top connecting the freezer compartment to the fridge side.
As well there is a second opening or return chute located in the fresh food section on the bottom lower half, that allows air to return the air back to the freezer, completing the air flow cycle.In almost all cases, the return chute going from the fresh food section to the freezer compartment has become blocked.
Usually iced up.
It will ned to be completely defrosted. Many times, the return chute is difficult to see and in many cases almost impossible to defrost easily.
If you can see the blockage, then it can be defrosted with the gentle use of a hair dryer.
However, if too difficult to access, you may need to open both doors and leave the machine unplugged for an extended period, usually 12 to 24 hours.
I know it's a pain, but sometimes necessary. Many times, rushing a refrigerator repair is impossible.
The reaon it works when you open the doors is, you have given the machine a secondary source of air from the room.
Jun 29, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Princess series model FN66011S The refrigerator does not change temp.it remains warm...freezer does freeze. Is this a fixable problem?
HI!!
The little fan inside the freezer is the one in charge of blowing cold air into the fridge area, the freezer control (thermostat), regulates how cold it should get, and the Refrigerator control regulates how much of this cold air goes to the fridge compartment. It is important to keep the door gasket clean at all times in order to have a good thight seal.
Check:
1.- That the freezer and fridge controls are set correctly, acording to manufacturers specs. (a common problem arises when by accident, the temp. controls are moved out of preset adjusment.
2.- That the fan is working and sounds strong, (If you keep the freezer door open for a couple of minutes, you should hear and see the motor kiking in.)
3.- Find the vent(s) in the fridge compartment and feel if cold air is coming thru when fan is working. If fan is working and blows no air, Take the freezer's back panel off, (4 hexhead screws) just enough to see inside and check if the evaporator (radiator looking component) is covered with ice, blocking the flow of air towards the fridge compartment, if it is, your defrost thermostat and-or timer are defective.
Your temp control for the fridge when you first start it, should be a bit higher than the one for the freezer. (the freezer should be in the low-middle range.) This control is nothing but a actuator for a door that controls the flow of air from the freezer. The bigger the number, the wider the door opens, and the colder the fridge gets.
Once the system is stable, let's say the next day, you can re-adjust your controls, (don't expect an inmediate change right away, change one digit a the time and check again next day) If you set your fridge too high and the freezer too low, the freezer may loose coldness and the problem would invert.
Good Luck!!!
Mar 20, 2010 | Refrigerators
Refrigerator the freezer is cold but other side is not, when I have the freezer door open cold air blows through the vent to the other side through the vent
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the tope of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working Ok then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Also worth checking the return air path from the fridge and making sure it is not blocked or frozen up. Also check the freezer compartment and cooling panel at the rear (behind the cover plates) and the fan for icing / blockage up as it sounds like there is a mini vacuum being created when the freezer door is closed or you have too much in the frezer so it presses on the back plate and stops the mini fan circulating air to the fridge.
Oct 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New 642 freezer door is very hard to open due to seal sticking
If the seal or seating area is sticky, wash it with warm water. If it isn't, this is just the sign of a good refrigerator. As the air cools, it becomes more dense and creates a vacuum inside the compartment. With a pliable new door seal which is sealing well, combined with a large door, this can cause a great seal with alot of pressure pulling on it. Smile, this is why your consumers bill will be much better with that new sub-z.
Oct 17, 2008 | Sub-Zero 642
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Mar 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
SMEG FAB28
This is a known problem with these fridges. The only fox is to replace the fridge.
Jun 16, 2007 | Smeg FAB28
Refrigerators Logo
378 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
