Question about Kenwood ProTalk UBZ-AM14 (14 Channels) 2-Way Radio
Hearing Aid Compatability
I just started working for a store that use Kendwood FRS radios and earclip headsets with push to talk buttons to communicate between Sales Associates on the store floor. This is also part of their security system.
I wear two Behind The Ear hearing aids (Phonak) that do not have “T” switches.
I have contacted my Phonak dealer also looking for suggestion.
I can be contacted at:
Sailors@Wind-Borne.com
Thanks
Rick O’Brien
    Master:
  • 623 Answers
Under ADA it is the employer's responsibility to make adaptations to your condition. Their radio provider should be able to provide you with hearing aid compatible headsets.
Posted on Oct 30, 2013
2 Suggested Answers
Agent Ken
  • 250 Answers
SOURCE: FreeTalk 3131 compatible with proTalk radios?
Hello Christian,
Some of the Kenwood ProTalk series radios may be programmable by the dealer to operate in the 462-468 MHz range used by GMRS and FRS radios. However the radios are not FCC approved for those channels and do not comply with requirements for FRS and GMRS radio equipment.
You are going to be better served by picking up a FreeTalk 3131XLS like your friends have. In terms of style and features this radios is very similar to the ProTalk but is type approved for use on GMRS.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jul 21, 2008
Headset is not supporting to blackberry z10
Hi try this out....Turning on, then turning off "Hearing Aid Mode" fixed the problem. The audio switches automatically between headphones and speaker normally now.
Hearing aid mode is under "System Settings" -> "Accessibility" -> "Hearing Aid Settings
Nov 09, 2014 | Skull Candy Radio Communications
Can get headset to work right
check your radios settings, this should be available in a menu on the radio... the user manual does not show a setting for non vox operation of the head set, (as this maybe a version difference it may be available in the menu) so if it is not available in the menu with the rest of the settings it is not an option.
Oct 22, 2013 | Motorola Walkie Talkie 2-Way Radio
Bought new dynex dx-740 earclip headset with microphone. earpiece works but computer not picking up microphone.
Have you installed the software for your headphone? Your computer might not pick up your device because it doesn't recognize the device.
Mar 06, 2011 | Dynex Earclip Headset with Noise-Canceling...
DOES IT HAVE A CALL BUTTON?
It has a PTT (push-to-talk) button. But if you are talking about a button to make a call tone (ringing sound) come out the other radios, the answer is no.
Best regards.
Apr 10, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Sqeal when talk button is pushed
Two known causes of squealing when the radio is put under a load (such as when the PTT is pressed) are a low or bad battery, or being too close to another radio.
Apr 21, 2009 | Audiovox 2-Way 14 channel FRS Family Radio...
I recieved a talkabout 250 and i have no clue how to use it please help
You would need two or more radios to be able to communicate with others. Then you simply press the push-to-talk (PTT) button when you want to talk (transmit) and release it so others can reply (receive). The radios must be set to the same settings to be able to communicate.
Apr 11, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
My DYNEX microphone wont work
Perhaps you have it connected to the speaker connection? Have you looked at the microphone to ensure there isn't possibly a mute button you have accidentally pressed?
Out of curiosity, how are the others hearing you ask if they can hear you? If you are using the microphone to ask, perhaps they are just yanking your chain?
Jan 24, 2009 | Dynex Earclip Headset with Noise-Canceling...
How to talk from one talkie to another
the radios may be on the same channel but are they also set to the same privacy code. if the speakers are working on the radios and if the recieve portion of the radio is good then this would be the cause of your problem. Most FRS radios will have the channel number as the big number on the display and the privacy code as a smaller number on the right hand side of the display. make sure that the privacy code nubers are the same.
Patrick
Nov 18, 2008 | Cobra Microtalk 100 FRS Walkie Talkie...
Dynex Earclip Headset with Noise-Canceling Microphone driver
ok umm....it is a noise canceling microphone, the earpiece works but when i talk into the microphone no one on the internet can hear me please help me with my dynex earclip headset
Aug 08, 2008 | Dynex Earclip Headset with Noise-Canceling...
Earbuds
If you are using vox (voice activated transmit) go into the menu and make sure you don't have the VOX setting too high. You should be able to put the headset on... hit the "push to talk" button on the radio and transmit you audio. Turn the other radio on and make sure the radio is "keying" (tx with no auio) then make sure there is audio. If you don't have audio but the radio is transmitting.. you might have the wrong type of plug on your headset for the audio..... there are 2 plugs... 1 for transmit audio....1 for recieve audio. It could be the wrong type of plug for the jack in the radio. Regardless.. the way the headset works is either you push the "push to talk button" onj the radio OR you use the VOX function... with the vox function you just have to talk into the mic to transmit. This is what your headset is designed for. You will have to go into the menu and set up the radio for VOX. If you still have problems follow my directions at the top of this page ( check mic jack and stuff) I think you just have to set the radio up for VOX operation and set the VOX setting. You should be able to push the push to talk button and talk through the mic on the headset. If you don't get any audio that way there is a problem and you should check the jack and plug on the headset.
Aug 25, 2007 | Motorola Talkabout T5720 (7 Channels)...
Kenwood ProTalk UBZ-AM14 (14 Channels) 2-Way Radio Logo
121 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
