Question about Whirlpool Dryers
Whirlpool dryer wed5700sw
Lint may be bypassing filter. at same time, lint rolls up and falls off filter when filter is pulled for cleaning. Dryer stopped drying today - clothes were hot and wet. Disconnected vent hose from wall and found vent stopped up with lint; I then turned the dryer on with that end of the vent line still unattached, and lint was blown out into the utility room. Not long after that, the clothes were dry. ?????? I should not have to connect, disconnect vent hose all the time to clear lint out of the machine?
Paul (unicornlvr@bellsouth.net)
  • unicornlvr Jul 14, 2008
    Yes, I can, and have, cleaned the vent system, but why doesn't the filter trap and remove the lint?
  • Anonymous Mar 31, 2014
    Vent clear
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
You need a dryer vent brush first,bought at home depot cheap,and clean the entire vent to the house,then clean where the vent hooks up to the machine,if your filter is where your door is pull out the filter and stick the brush in there and pull out lint,also use your vacume,remember you let some lint out when you let the hose blow out but theres a lot more there to clean,and also unplug your machine as you do this,if this helps please give me a fix ya vote
Posted on Jul 14, 2008
There is lint down in the "basin" below the lint filters and I cannot reach it to vacuum it out. I empty the lint screens after each and every load but this has built up in the bottom in the stainles
unplug it,remove the bottom panel,pull out the lint filter,you'll see the metal duct that the lint filter slides into,remove the 1/4 inch screws that hold it in place and remove it and vac it out,if you have a shop vac you can blow the lint off of the motor and blow all the lint in the back of the cabinet forwards and then vac it up,this way you don't have to pull the dryer apart to clean it,you should do this once a year so you don't have any problems with the dryer and your clothes will dry on time,also you should clean out the vent line,pull out the dryer,remove the vent line,if it's a long run stick a leaf blower into the vent line and blow all the lint in it outside,first make sure you don't have a cage or anything that will catch the lint,if you do remove it and don't put it back then go inside and blow out the line.this happens to every dryer even if you clean the lint filter every time.hope this helps and good luck with your dryer
Mar 30, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer will not start. when i press the start button, the sensor light comes on and the dryer will not start.
This problem is usually due to a blown thermal fuse. Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Let us know if the problem is not addressed above but indicate the exact model number of the machine for further advice.
Jan 27, 2011 | Whirlpool Dryers
Will not start
The problem is likely a blown thermal fuse.Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dec 18, 2010 | Whirlpool LER5636P Electric Dryer
My whirlpool 6th sense dryer model awz3413 turns off when clothes still very wet. Lint filter light comes on but filter cleaned and outlet ducting has been vacuumed. Could this be a senor or thermostat...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 25, 2010 | Whirlpool ET8CHEXSQ Dryer
No lint in the lint filter
Check air flow out of unit and ensure you do have some foreign object stuck in the blower wheel. UNPLUG unit, and clear out exhaust tube from dryer. Have a professional clean house vent if you cannot see where the vent exits the house. It is common on Whirlpool, top of cabinet vent opening to have objects fall into the lint screen opening and restrict airflow.
Mar 28, 2010 | Whirlpool LER5636P Electric Dryer
Dryer isn't drying as well as normal.Lint filter is clean.Doesn't seem to work any different on timed dry or auto dry.I have electrical exp. but no dryer exp.What should i check and how do I access it?
i belive you should check the vent hose from the dryer all the way to where it exits the house... that's usually the problem when dryers aren't drying as well as they shoud... lint wil start to cake on the walls of the vent and either create a complete block or slow the air down enough to keep it from circulating like it should
Feb 14, 2010 | Whirlpool WED5300S Electric Dryer
Keeps blowing thermal cutt-off fuse
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Sep 05, 2009 | Whirlpool Dryers
Whirlpool dryer not drying
your dryer is likely clogged up with lint .. that would be after the lint filter .. the pipe that carries the hot air out is usually completely clogged after that long .. it and the dryer itself (down inside) has to be cleaned about once a year to keep it tip top .. hopefully you can find someone that can take it apart and clean everythiing .. that should get you back to like new performance .. or you could call a few handymen to see what they would charge to clean the lint from your dryer and stack .. or if you are handy there is a special big brush with a string attached .. you pull that thru the stack to clean it .. use a vacuum cleaner to get inside the dryer vent (you can see in the vent when you take the hose off .. excessive lint buildup not only greatly reduces your dryers efficiency but is a fire hazzard as well ..
Aug 12, 2009 | Whirlpool LER5636P Electric Dryer
I own a whirlpool gold dryer about 4 years old. I empty the lint catcher frequently. I noticed however, that sand has accumulated inside the dryer, I hear the sound when the dryer starts tumbling. How...
not as hard as it will sound here we go
remove the lint filter
remove the 2 phillips screws at the filter housing top you will see these screws after you have pulled out the lint filter
unplug the dryer
remove the back panel
on the left side is the lint filter housing it is held in place with 4 1/4 inch screws remove them
lift up on the filter housing and pull forward you will find the sand inside the filter housing use a vac to **** it out and reassemble the dryer, no more sand
Apr 26, 2008 | Dryers
Dryers Logo
192 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
