Question about Protron PLTV3250 32 in. LCD Television
Getting Power Board
Who do i get power board from i called and they are not letting me purchase.
    President:
  • 2,712 Answers
We have a maytag refrigerator model msf21d4mde01. We started losing power to the controls on the door, but it would restart after an hour or so. Note that the fridge was working properly during the outage,...
Hello;
My mane is Peter. I am a retired field service refrigeration technician.
In your owners manual it is recommended that you have a surge protector. You can purchase individual wall socket surge protectors for about $22.00.
Any appliance in your home that has a control board should have a surge protector. A power surge can knock out your control boards.
You should have a 12 month warrantee. Get the surge protector before the service technician comes.
The control board on the door P/N W10606407 Cost $115.00 - $150.00.
You also have a power board in the lower back that communicates with the front control board. Since you have power this board is probably good. Cost: $120.00.
If you do not have coverage at this time and also even if you do, contact Sears Home Services and buy a, "Protection Agreement". As for the, "SMART" agreement. It covers you for $500.00 per service call. If you have 3 service calls in one year you are covered for $500.00 on each call. If they can not fixit after 3 calls then they give you $500.00 towards the purchase of a new unit. Do not let them talk you into the more expensive, "Master Protection Agreement". You do not need that.
If you do not have coverage now, then buy the , "SMART Agreement" wait 3 weeks and then call for service. The service technician does not care how new the coverage is. The technician just wants to do the repair and move on to his next 10-13 service calls scheduled for that day.
I have a SMART agreement on my clothes washer, which I can repair, but the service agreement cost less that the control board parts.
Mar 23, 2015 | Maytag Refrigerators
Water diagnose light blinking 0n cm3 scotsman ice machine even after changing water level sensor
Is the sump tray full of water? or is it not filling up fast enough? Water level sensor lets control board it needs water or its full of water. If machine is not getting enough water or slow filling then check the water filter, if water is flowing good through filter good then pull water line off of the water inlet valve to make sure there is no trash blocking water at inlet. If not then make sure the water solenoid is getting power call from board to solenoid, if getting 115v to coil and slow to no water to sump then replace valve, if no power to valve then replace board.
Sep 25, 2014 | Kitchen Appliances - Others
Need to find power supply for 32mf231d
Earl, First, let me ask you...are looking for the power supply or the signal board? The reason I ask, the product shown, is the signal board. In some cases a bad power supply can ruin the signal board.You will know this when examining the signal board (will be burned). But you ask for the power supply. This power supply is difficult to find, that is why you ask to locate one. You may have already checked with shop jimmy.com. So, lets ask for a rebuilt power supply. Call Union Electronics at 1 800 648 6657. Call Andrews electronics at 1 800 274 4666. These places will rebuild or exchange boards. Have your TV model number and if you can the power supply in hand with the part number. The part number is on the board,, with white tape (will start with 313#). Another thing to try, is to locate a TV Repair shop. They may have a salvage area with a working power supply. As to say the same TV with a shattered screen etc. Thanks for asking me Earl....good luck, Matt.
Nov 25, 2012 | Philips 3138 158 66721 313815866721...
I have a frigidaire fridge model # FSC238F7DSBA I had a blinking error of " E F" on the control panel. I checked out the error codes as well as called frigidare customer service and they both led me to...
After replacing the control board did you unplugged the fridge.?There is no resetting button.Unplugging the fridge for 1 hour will reset it.If still the fridge doesn't reset then leave it over night unplugged.
Thank you
Oct 19, 2010 | Frigidaire Refrigerators
Hi I have a Westinhouse LTV-32w6 HD that doesn't turn on checked fuse at power board and it's fine any ideas ?
LCD tvs have power supply board problems very common are parts call capacitors are alway have leakages it bulges up on it tops or puffing up on it tops.These capacitors parts are dying about to be dead.That why,ur tv is not getting power,power light flashes,delay power on to tv like 2 to 5 mins or more.U know basic electronic and can do soldering?Check the power supply board for those dying about to be dead capacitors,that bulges up it tops or puffing up on it tops.Replaced these dying to dead capacitors,will fix ur tv power supply board problems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replament.
Sep 18, 2010 | Westinghouse LTV32W6HD 32 in. LCD...
Gets F11 code and stops running and sometimes DL code.
hELLO THERE This code that you are getting is caused from the keypad getting shorted electrically this could be caused by a faulty keypad or controle board
To do a test a to find out unplug the unit for 3 minutes and plug back in and if the error comes back on after applying power to the unit than you will know that your keypad or ekectrinics controle board is bad and needs to be repalaced board as it is called is bad bvut if a kll goes well than yo will know that it waas just a interuption of the power
between the board and the keypad ok
so please try these tests and let me know how they go for you
and let me know how this goes
Best regards michael
Feb 05, 2010 | Kenmore Washing Machines
Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Dec 30, 2009 | Samsung LN-T4665F 46 in. LCD Television
Power Shuts off after 30-45 minutes
I will say that the part that you bought could have been removed from another LCD and it might not be working properly due to components that become defective when they overheat.
It looks like there are not service parts or they are difficult to find.
Most power supplies I've repaired have components that failed after about 1500 hours of use.
The only way to get the LCD working is to repair the power supply to the component level instead of swapping it.
In about 95% of the time the power board is defective.
Let me know if you need further assistance.
Aug 16, 2008 | Akai LCT3201AD 32 in. LCD Television
Ilo 26" TV stuck on one station and will not respond to buttons.
all you need to do is buy a control board its a 15 dollar part try shop jimmy .com
Mar 03, 2008 | iLO 2600 Television
Phillips 37pf9975/12
the middle board = main power board
left board= )Y) sustain board
right board(X) sustain
lower board( input board) = SSB board
call andrews electronics for part price
Oct 08, 2007 | Philips 37PF9975 37 in. HD-Ready Plasma...
Protron PLTV3250 32 in. LCD Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
