Question about Maytag Atlantis MDG7400AW Gas Dryer
Dryer takes a long time to dry clothes
Is it possible for me to change the heating element myself if that is the problem? I am not an expert.
    Genius:
  • 1,122 Answers
Listen,a dryer either heats or does not heat no in between,either your dryer vent is clogged up and into the dryer or your outlet is not giving the proper voltage.let me know what you find,thanks-mike
Posted on Jul 15, 2008
Dry takes a long time to dry cloths
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 28, 2012 | Kenmore Dryers
Needs two cycles to dry clothes!
May 19, 2012 | Kenmore Dryers
Indesit IS70C tumble dryer not heating
May 10, 2012 | Indesit IS70C Electric Dryer
Clothes dryer doesn't heat
Nov 26, 2011 | KitchenAid Dryers
Clothes not drying. need 2+ cycles to get clothes dry
Mar 30, 2010 | KitchenAid KEHS01P Electric Dryer
Dryer heats up but doesn't dry clothes take 3 hours after restarting 3 times to dry 3 articles of clothing.
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
Oct 15, 2009 | Whirlpool LER4634J Electric Dryer
My dryer does not get hot enough to dry the clothes.It takes about 80 minutes to dry on high heat.
If this is an electric dryer, it would appear that you have a broken dryer element, which would account for the extended drying time.
You can access the elements from the back of the dryer by removing the rear panel. Be sure to unplug the dryer first, to avoid getting an electric shock. You will need a multi-meter to check the continuity of the two (2) dryer elements. Just put the meter into the Ohms setting and check across the two element contact points to see if you have continuity. If you find that one of them isn't giving you a zero "0" reading, that is the bad one.
Go to searsdirectparts.com to enter in your full model number and you can see the exploded line drawing for your dryer and the parts list and prices for the replacement part.
The reason the dryer is taking longer to dry, is because without both elements, the dryer cannot get hot enough to dry the clothes within the normal time, as only one element is having to provide all the heat in an attempt to dry the clothes.
You should replace the element as soon as possible, as having only one heating element working will cause that remaining element to fail sooner as well, since it will be staying one for a much longer time than normal.
Hope you find this Very Helpful and best regards!
Aug 26, 2009 | Dryers
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 03, 2009 | Kenmore Dryers
Not heating properly, many cycles to dry loads
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Bolsh E-NR WET2820GB
In order not to mistaken the connection draw it the connection or take some picture to compare your work will be perfect.
Jan 03, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Maytag Atlantis MDG7400AW Gas Dryer Logo
96 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
