Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso washer CE error massage
  • lizreid Apr 07, 2009
    thank you for posting the helpful information!
    just the other day the washer started to flash the CE code. and would stop working in the middle of the cycle. GRRRRRRR!!!!
  • Anonymous Apr 25, 2009
    My Kenmore Elite Calypso Wash Motion Washer won't turn on
  • 30 Answers
Here is a link for the error codes on calypso, in most cases it is a blown fuse on the motor control board so I would first check that. Hope this is helpful and please remember to rate this solution.
Posted on Mar 10, 2009
  • david pickell
    david pickell Jun 04, 2009
    There may also be a blown capacitor(s) on either board. Look for any bulging capacitors and replace while you have the boards out. Also is is likely that corrosion on some solder joints is the original cause of the component failure. you may replace the blown components and the washer will work but still give failure codes. I had to resolder a few connections before the washer was completely repaired. so look carefully for dull joints and corrosion under the waterproof coating, and don't forget to re-coat with something that will water proof where you have repaired. I used a a thin coating of very hot glue to cover any exposed electrical joints. Good luck with your repairs.
  • robin Aug 15, 2013
    thanks very informative as I am ready to replace fuse so may as well check all solder joints while already have board out. How do I test the relay??
I had the same code + motor and pump did not work. I run couple of tests as described in service manual that is attached to the inside of front panel and I have detected that there was no 120 voltage going out from control board to the motor board. I have removed the control board and I have noticed that rely on the board is not soldered properly (high current line). I have re-soldered rely and my washer is back in business. Even if rely was bad - the price for it (T9AS1D12-12) is about $3 and seems to be easy to replace with some minimal skills (and soldering gun). The price for a new board is about $130 at Sears parts department. I think I save at least $300 for service call.
BTW. Many people had problems with this washer - but for me it worked just fine for 8 year with fairly heavy usage. It is nicely built and on board diagnostic is very good. So if you have some mechanical/electrical skill it is good to try service procedures before calling service.
Posted on Mar 12, 2009
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Kenmore Elite Calypso top loader and error code ce
Com error between control and motor. See page 51. Check for corrosion on the pins at the quick connect. Check for broken wires
Sep 16, 2011 | Kenmore Elite HE4 Electric Dryer
Where is the filter located on a kenmore elite calypso washer
reomovethe 3 screws across teh lower acess panel, youll see the filter clean out right behind there , be warned before unscrewing get a plastic bag, or a few towells you will getwet!!!!!!
Mar 17, 2009 | Kenmore Washing Machines
Washer won't start. shows CE on the display
That is a communication error between the control and the motor board.
Could be a corrosive buildup on the ribbon connectors and/or a bad wire or loose wire.
You can unplug the machine and trace all wires to look for a pinched or loose wire.
Unplug and clean all wire connections.
If that does not work it will be a bad motor controller.
Mar 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite calypso 24082 error code CE
On the ccu, the board on the right is usually the culprit, I have recently replaced one with that same error but I would first unplug it and remove and re connect each plug on the board looking for dark connections or dialysis, corrosion. If not fully insert each plug and try again.
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
3,963 people viewed this question
Dan Webster
Dan Webster
Sal De
