Question about Yamaha R-V1105 Receiver
Yamaha R-V1105 no subwoofer output in some configurations.
I have been using this reciever for home theater use for years and just used my computer for listening to music so never really used it to just play music. I now have the computer and home theater setup in different rooms so hooked up my CD changer (Sony CDP-CX455) to listen to music in the main room.
So the problem is that with the CD player or with a iPod hooked to Tape/MD connection there is no output to the subwoofer. This is even with music that is guaranteed to trigger the subwoofer. I also found a weird quirk when I first hooked up the system in the main room. I couldn't find my optical out for the DVD player. So until I found it I just hooked up the orange digital out RCA looking cable from the DVD player. I made no changes to the R-V1105 at all. Using the orange digital out/RCA cable it would not go into Dolby Digital mode but instead stays in Dolby Pro Logic mode and also did not trigger the subwoofer. All I have to do is swap the cable and it instantly "see's" Dolby Digital and goes full 5.1 with the subwoofer. No changes made to the R-V1105 at all, just swapping a cable.
So that is the issue, I know the reciever is now ancient but I am not in a position to upgrade it at this time and would really like to listen to CD's and my iPod and have the subwoofer actually work. It really destroys the sound to not have that bottom end response in many different types of music. It's obviously capable of driving the subwoofer as it does it beautifully with DVD's as long as the optical cable is hooked up. Maybe a setting buried within all the menus? I have searched the manual and didn't find anything. I also tried hooking the CD player up with an optical cable off the DVD player real fast just to see if it made a difference and it did not. No subwoofer for the CD player even with an optical connection. Obviously this isn't even an option for the iPod run through RCA cables to the Tape/MD connection.
Thank you for any help or advice you can give me.
  • yet2356 Aug 20, 2008
    I have a similar situation. I have a Yamaha 795a and never really used it to listen to 'analog' sound. So it always worked fine with a digital input (ie DVD). Now when I play CDs in DVD player I dont get any sound from the sub. All other 5 speakers play sound, just a problem with the subwoofer. Any ideas?? Thanks
3 Suggested Answers
SOURCE: Problem with Dolby Digital mode
Hi Whitesox, thanks for the suggestions! I finally got to the bottom of the problem, and it turned out to be the new Toshiba DVD player I recently purchased (model SD5000). I never had to make any adjustments to a DVD player before to make it play dolby digital signals, but this new Toshiba essentially comes with Dolby Digital diabled as its default setting. You have to go into its setup menu and switch it's digital audio mode from PCM to Bitstream. What's strange is that even with the default settings on the Toshiba it would play in DTS mode correctly.
Posted on Jul 27, 2007
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Posted on Apr 14, 2009
How do i connect my subwoofer to my home theater
Easy. Your home theatre amp will have a sub or LFE output ( RCA plug ). You simply connect this output to the input ( usually the left side, or use a Y splitter and use left and right inputs, or the LFE input if your sub has it ). Then, you must turn the sub on in your recievers setup menu, and your sub should work.
Mar 03, 2013 | Sunfire True Sub MK II Subwoofer
Hello ! I'm not sure how to connect my kef psw 2500 sub to my yamaha amp. I've got a subwoofer out on my amp but there's 4 inputs on the sub and I don't no which one to use ! Please help as getting...
Just for clarity, I need to explain what the four inputs are on the KEF subwoofer. There is a left and right RCA input which is the input signal to the subwoofer and there is a left and right RCA output which is the High Pass output from the subwoofer.
On the back of the Yamaha receiver, you said you have a subwoofer output. This output is most likely the mono subwoofer part of the home theater system and can be used if you like. The left right signal input into the KEF is summed into mono so if you only connect one channel you will basically reduce the signal level by 1/2 (-3dB) but it will work fine.
Alternatively, if your Yamaha receiver has monitor out and monitor in, you can run the monitor output signals to the subwoofer and you can then run the high pass outputs from the subwoofer back to the monitor in. This will give you the subwoofer and provide a smoother signal matching with your audio system.
It is not always easy to connect the subwoofer up to an integrated receiver/home cinema system using the high pass channels of the subwoofer as you don't always have access to the analog output and input of the front channels. In this case, just use the Subwoofer output or just the monitor out only.
I hope this solution is helpful.
Dec 03, 2010 | KEF Audio PSW 2500 Subwoofer
Mar 31, 2009 | Yamaha RX-V363 Receiver
DOES RCA RTD205 HAVE A SEPERATE AUDIO OUTPUT.
No, it has no audio outputs. You can use it as a CD player using the 5 speakers subwoofer that come with it. No need to use the receiver and its speaker.
Mar 28, 2009 | RCA RTD205 System
KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Is sub out turned on on the reciever? Some have a setting that doesnt use the sub out, like 2 channel.
Jul 30, 2008 | Audio Players & Recorders
R-V1105 Yamaha reciever
You don't think I have enough problems. I was reaching out to the decent music fans out there that could help me without making a buck on every God Damn thing on this planet. Heres some free advice from a music fan to you, No thanks. That will be $20.00 bucks please.
Jul 05, 2008 | Yamaha R-V1105 Receiver
Yamaha NX-SW300 sub woofer
Yes, that type of connector is often used for a VGA signal for a computer monitor. But in this case it is an all-in-one connector Yamaha used in order to simplify the hookup of this home theatre system. Unfortunately, the subwoofer is only usable with the DVR-S300 receiver/DVD player.
Apr 03, 2008 | Yamaha YST-SW160 Subwoofer
R-V1105 Yamaha receiver
Your audio amplifier ICs are damaged,you gotta change it.
Nov 17, 2007 | Yamaha R-V1105 Receiver
Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Oct 30, 2007 | Audio Players & Recorders
Yamaha R-V1105 Receiver Logo
103 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
