Question about Panasonic CT-36SL13 32" TV
Panasonic ct36sl14 hello this set is dead no power at all...what parts could this be? thanks
  • blhug2 Nov 05, 2008
    dead head set! no power!
The small fues in the back
Posted on Sep 20, 2008
Hello, lighting hit and my plasma Panasonic tc-42px24 will not turn on. completly dead. was told it maight be supply board??? thanks
Power surges wreck havoc with power supplies since they are first in line and bear the brunt of the rushing power. Try replacing the power supply board on the cheap by getting a used one on ebay to minimize the expenditure in case that is not it. Always a possibility,
Sep 09, 2015 | Panasonic Tc-42px24 42 in. Plasma TV
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic TH-42PZ77U HD Plasma tv has 10 blinking lights
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 02, 2010 | Panasonic TH-42PZ77U TV
Internal ceramic fuse repeatly blown.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. See: http://www.microwavedisplay.com/doorsw.txt in this case.
If this unit has an inverter some parts are difficult for the average do it yourselfer to replace, such as parts which are spot welded, not using removable connectors.
In such cases, it's best to replace the entire inverter.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on them.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
You can order Panasonic parts from
Encompass or by calling 866-779-5835.
Jan 09, 2010 | Panasonic Microwave Ovens
I need Panasonic CT36SL14 service manual
tv powers up but no picture or sound. DVD works great has great picture and sound.
Apr 02, 2009 | Panasonic CT-36SL14 36" TV
Panasonic DMRES30V DVD.
I have not but have decided not to try any more and will just buy another.
Thanking you.
Nov 24, 2008 | Panasonic DMR-E85H DVD Recorder
Powers off after 2 seconds
Very carefully thats how you remove broad.I use STK392-180s ,and after you replace these parts you have to realine covergence ,you must then have service setup code for teachician and the remote control that came with tv if you dont you will not be able to set convergence.
Jan 14, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Tv is completely dead
Only 10 years old??? Ok its most likly at the end of its usefull life, unless you want to put some cash into the set, as there are no user replaceable parts inside this TV, so you really should let a trained tech estimate it for you. But once you fix it, you most likly will start have problem after problem. Do yourself a favor, and buy a new one. The problem with this set is most likly the flyback and other componets or the power supply capacitors are bad.
Sep 30, 2006 | Panasonic CT-32G11 32" TV
TV does not turn on
I'm looking for the same info... my CT-32sx12f is completely dead too. I was wondering if the IC regulator or the flyback is bad. Fuse is fine. Anyone have any wisdom or experience on these sets they can interject? Thanks!
Sep 05, 2006 | Panasonic CT-32SX12 32" TV
Panasonic CT-36SL13 32" TV Logo
187 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
