Our Panasonic model no. pt-52lcx15 has green and blue dots all over it. It started out with just a few and then the change bulb light came on so we replaced the bulb. Now the dots are getting worse. What should we do?
  • Anonymous Apr 26, 2009
    Blue and red dots appeared my Panasonic projection tv making it annoying to watch. Then, recently, a 'replace lamp' message shows up on the screen. I was going to try to replace it until I found out that the bulb is $130! I thought Panasonic is dependable...Does Panasonic still fix it free of charge?
Call panasonic. I believe there is a extended warranty specifically for this specific problem. I just called today and they are sending someone out here to fix it, and are paying for all charges.
Posted on Apr 03, 2009
PT-52LCX15 when you turn on the tv the lamp comes on for about 2 seconds and it turns off then the power light blinks 5 times then the yellow
If you google how many times the light flashes with the t.v model that should tell you what your problem is.
Might be your bulb.
Jul 30, 2014 | Panasonic Televison & Video
Green haze on panasonic pt-52lcx15
Your EEPROM is corrupted and needs to be reprogrammed. You need a EEPROM data corection tool. Part# LSUQ0100. It will come with instructions on how to restore your EEPROM data. Good luck.
Apr 19, 2012 | Panasonic PT-52LCX15
I have a Panasonic PT-52LCX15. 3 months ago I changed the lamp and now I have a blue -ish line along the left side of the screen?????
This sounds like a damaged optical light engine.
This set uses a L shaped engine--the lamp shines into it and heat from the lamp can cause the prisms/lens inside to warp slightly(hint: blue is the first part of the engine to get the light from the lamp--usually shows first).
If no extended warranty it is going to be an expensive repair--the engine is the most expensive part of the set.
Let me know with a comment here if you have questions.
SD TECH
Apr 13, 2011 | Panasonic PT-52DL52 52" Rear Projection...
How do you reset the bulb life counter after you put in a new bulb?
For models:
PT-44LCX65/PT-52LCX65/PT-61LCX65/PT-52LCX15.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down the SPLIT DVD/VCR CH UP button on the remote until a message appears on the screen that the lamp timer has been reset. If this does not work, use SPLIT DVD/VCR CH DOWN instead.
Good luck
Dec 14, 2010 | Panasonic PT-52LCX65 44" HDTV
MODEL # PT-52LCX15. GREEN AND BLUE SPOT ON SCREEN.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine.You can find it here: http://www.discount-merchant.com/PANASONIC-521A2C52-p/1177904.htm Have a blessed one!
Mar 22, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Green blue and red spots across screen. I changed the bulb a few months ago.
You need to contact a serviceman. Your light engine needs replaced. Panasonic requires prior tech authorization for parts order fulfillment such as this. PN: TZSC03045 It will be costly, roughly $800 with $250 core charge. Labor and trip fees are another thing altogether. I hope this helps.
Mar 21, 2010 | Panasonic PT-44LCX65 Television
Panasonic multimedia projection HDGT tv color spots displayed
PANASONIC..PT-52LCX15. STARTED TO A LIGHT COMES ON THE SCREEN. THEN TWO LIGHTS. FINALLY TV DONT COMES ON. I PUT ON THE TV, AND ON BOTTON START BLINKING AND TV DONT COME ON..I TAKE OUT THE TV LAMP..IT LOOKS GOOD NOT BURN. SHOULD I REPLACE IT??
Oct 18, 2009 | Panasonic Televison & Video
Panasonic PT-52LCX15- Have a Blue hue along bottom and on part of screen, replaced bulb 2 times, same and used a philips and now panasonic bulb and housings. Any suggestions? Projector? Time to call...
This is a 2005 model; it sounds like you have a burnt optical light engine: part number is
TZSC03047 Part is about 800 dollars and requires tech approval from Panasonic to buy. A number of these optical engines use an elaborate system of lens---the heat from the lamp can damage the lens and the color that is damaged separates enough inside to cause the blue streak somewhere on the screen. I hope you have an extended warranty on this set.
I do this here for free so if this has helped you give me a vote here.
Aug 27, 2009 | Televison & Video
Televison & Video Logo
256 people viewed this question
Top Televison & Video Experts
