Question about Kenwood KAC-9152D Car Audio Amplifier
My amp wont turn on
I bought my amp about 5 months ago and it worked realy good but when i turn it up about 60 percent of the way it would cut off then afta about 2 weeks of that it just stoped workin 1 day.
  • bennetts3044 Jul 26, 2008
    the red light is on the amp but the woofers will not play. At one time they kept going off and on. When the woofers came off and on the red light would blink and it would cut back off.
  • Anonymous Jan 28, 2009
    i just got the amps hooked upp and none of my amps will play
    i checked the main fuse and it blew so i relaced it and still nothing,.,..HELPP
    Master:
  • 726 Answers
Smae as my cd player when its turned up over 40 volume the amp stops and the subs also
what it is just lacking power from the battery bacuse the altinator does not keep up you may need a capacitator or a dry cell battery that takes no water there called odyssey or stinger or pulse now if your amp wont turn on check the fuse for the positive and check the amp fuse check all connections are still good and the remote wire.
also make sure your using good gauge wire,
if still not working you my have over heated the amp and bang bang bew it up?
Posted on Jul 20, 2008
    Scholar:
  • 46 Answers
The reason it used to cut-off at 60% volume as you said before,
Is probably due to the "protection circuit mode" being tripped.
You can try resetting it by turning off your CD player ,removing the Batt( + ) and Gnd ( - ) terminals from the amp for a short period. Reconnect them Allow the amp to receive power but not switch on (keep cd player/remote power source off)
If you dont know how to wire the CD player to control the amps power status , the easiest way is to connect the 'power antenna' or similar low voltage throughput wire from the head-unit to the amp's Remote terminal.
My old amp did the same thing ,and would need to be powered off/on before resuming sound output, sometimes I had lots of trouble with the protect mode staying on , even with little or no sound output from headunit.
Posted on Jul 14, 2008
My 2003 Mercury Mountaineer has an electrical problem. It started about a year ago with the key fob not working, I have bought 3 and all won't work even after re-programing. now tonight I went to
Could be a windshile leak down the A-Pillar & water
gets into the delayed accy relay for the GEM Module
(Body Computer as ford called it for a few years) & you
get what you have now
Try Goolge as I did a few weeks ago for a relative
He had the same issue with the blower being on &
killing the battery
No real fix I found for the windshield leak
Seem a robot didn't put the rubber sealant
on correctly at the factory fo about 5 years
on several fords.
If it isn't water related then the GEM Module
controls all those body features
If you get a used one & match up the numbers,
you supposedly can avoid buying a reman gem
& the expense of having to reflash it to your factory
built combination
Jan 27, 2013 | 2003 Mercury Mountaineer
My t.v display and sound will not turn on after the t.v has been turned on.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 21, 2012 | Vizio 32" E321mv 1080p 60 Hz Lcd Led Razor...
Ducati 996 wont start
1st check battery is good -after 5 months unused it may need changing
Should have 12.8volts min when fully charged & no load
min 12.6 volts with ignition on
Jan 22, 2012 | 2001 Ducati 996 S
Loan of $10000 pmt in ten years with 15.25 as an interest and 5 as the number of years to pay the loan
To find the monthly payment with pmt use M = P(1+r)n r / [(1+r)n-1] . For this problem (if I understand everything correctly) P = 10000, r = 15.25, and n = 5*12 = 60. So your equation becomes
M = 10000(1+.1525)60 .1525 / [(1+.1525)60-1] = 1525.31. (this is assuming that 15.25 is the percent). Hope this helps.
Feb 22, 2011 | Office Equipment & Supplies
I bought my fender frontman 15 about 5 months ago, and yesterday i was playing it and it just stoped to work. Now the amp wont turn on... what can i do?
On the back of the amp, where the power cord plugs in, there is a cover that holds a 500 milliamp fuse. Check that.
Jan 21, 2011 | Audio Players & Recorders
I just had this model furnace fa4c insatlled about a month ago and it keeps cutting off. I found its tripping the circuit breaker. What can cause this.
realy only one major cause that I can think of short of the transformer intermitantly shorting out would be the Blower motor is causing your breaker to trip.....Have the motor checked out by doing an amp draw using an amp meter to determin starting amp and running amps....may be as simple as a start capacitor...Good luck.
Jan 04, 2011 | Heating & Cooling
My standby generator is just cranking but wont turn all the way
If it was installed only five months ago, it should still be under warranty. Call Home Depot and have them send out a repair person.
Jul 01, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
2000 nissan maxima wont turn over
has the car got an immobiliser switch in the car or it may have an electrical fault so it would need an electrical engineer to have a look at it hope i have helped you
Apr 01, 2009 | 2000 Nissan Maxima
Kenwood KAC-9152D Car Audio Amplifier Logo
186 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
