The problem might be your Vats security system. This causes the car to either "not start" or "shut down" while running, or start for 5 seconds and then die. (depending on the system) If the security light flashes, i guarantee that this is what the problem is. 1st trick, (if not starting) turn the key forward 2 clicks till right before it would normally start, leave like that for 10 minutes. ( no less ) After 10 minutes, turn key back then forward and your car might start. I did this in my regal for more than a year.
Cheap fix: Bypass the chip in your key. Temporary, but effective.
----- http://vats.likeabigdog.com/
Never worry again fix: Bypass the whole VATS/Passlock/passkey I or passkey II system entirely. Literally take it out, and throw it away. I just did this in my Regal. Took about an hour. Took longer to find the thing than it did to fix the problem. For a list of cars effected by this problem. See the NEWROCKIES link on the right side of their page.........
----- http://newrockies.ca?ap_id=judd0081
----- With this fix, you can take that whole Vats, passlock, passkey **** system out of your car all together. Good info on both sites
Ignition is in the RUN, START, or ACC position and security system diagnostics have all PASSED
SECURITY TELLTALE will be on if:
The BCM is performing a bulb check at vehicle start
Security system diagnostics have not yet completed at vehicle start
A security system diagnostic trouble code (DTC) is set in the BCM or PCM
SECURITY TELLTALE will be flashing if:
The tamper hall effect sensor has been triggered
Incorrect passlock sensor data to BCM for more than 5 seconds during vehicle start
No passlock sensor data to the BCM for more than 5 seconds during vehicle start
Incorrect password from the BCM to the PCM after 5 seconds during vehicle start
The ignition lock cylinder case, including the Passlock?"¢ sensor
The ignition switch
The body control module (BCM)
The security indicator on the instrument cluster
The powertrain control module (PCM)
The
2000 Dodge Intrepid is equipped with an alarm system that is triggered
when unauthorized entry is attempted. In some situations, such as having
the Intrepid valet parked or when it is being serviced by a mechanic,
the alarm system needs to be disarmed so it doesn't go off. Disarming
the alarm will prevent it from being activated until it is armed again.
Difficulty: Moderate
Instructions
