Wireless card suddenly cannot detect any signals
My Buffalo wireless card has worked wonderfully for nearly a full year. Now, suddenly, it detects no wireless sources at all. None at home, none at my office. Typically it detects not just my own wireless signal at each location, but several others. In fact, it normally detects several signals at virtually any location (I'm in an urban area). Now, absolutely nothing. I've uninstalled and reinstalled. Still nothing.
(Note: since the card last worked, I've had to send the computer (Thinkpad T61) for service - blown motherboard. The Buffalo card stayed home while the computer was away. I don't believe this to be a related concern: the motherboard actually blew and required service 2 consecutive times - on the computer's first return, the wireless card worked fine - until, of course, the computer blew up again (defective ac adapter, as it turned out)).
Please help!
  • 1 more comment
  • jimkwalton01 Jul 16, 2008
    my laptop quit "hearing" the network. It detects all the wireless in the area and sends packets out but received none back, even from the home router it has seen for years. I have downloaded the driver and installed again, no affect. Wireless is an INTEL PRO/WIRELESS 2200BG network connection
  • trapin Oct 06, 2008
    I have the same problem so I bought a new network adapter but still no luck. I cannot detect any networks close by.
  • Anonymous Jan 28, 2009
    i have a sierra wireless aircard that has work fine since october not the slightest sign of a problem and all the sudden i cant get it to find a signal! it just says searching then goes to no device detected then back to searching! tried to uninstall shutdown and reinstall and nothing! then tried resetting all internet options to default still nothing! please help!
  • 12,061 Answers
I would suspect ya adapter.. the ONLY way to sort it is to try it in another PC see if it works.. USB devices seem to be very flimsy and we get heaps of 'em in the shop.. 9 times outa 10 it's the USB device gone weird.. substitution is the only way to isolate the problem.
Posted on Jul 28, 2008
HP 550 - Unable to detect just a particular wireless network
Given all the circumstances, I can only guess that, for some inexplicable, apparant reason, your network card in your computer is the culprit. Try to get a friend who has the same model to swap cards with you, then you'll know for sure. The other problem could be something to do with the signal and some slight anomoly that is causing your card a problem in detecting it. A communications signal is complicated, and some wireless modems have better circuitry than others, depending on the model. But no matter how we speculate, this is just one of those Twilight Zone enigmas! Best of luck- tricky problem, for sure.
Apr 07, 2010 | HP Business Notebook 550
Linksys Wireless-N WRT150N suddenly stopped being detected
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 12, 2010 | Linksys Wireless-N WRT150N Router
Can't get wireless connection to work
Is the wireless card driver installed and working?
Can the wireless card detect your Netgear Router and does it have a strong signal strength?
The Wireless card needs to be configured with the Netgear Router's SSID and encryption settings before it will communicate with the Netgear Router.
Let me know if you have further problems together with error messages.
Jul 31, 2009 | Computers & Internet
Buffalo WHR-G300N. we are not a ble to connectiong the wireless, but it detecting
Download Latest Driver And Utility,Install WHR-G300N in Next USB Port and also check any other Software related WiFi.
Uninstall in safe mode del temp file then install.
Jun 27, 2009 | Buffalo Technology AirStation ...
Acer 6930 wireless won't connect anymore.
Hi acording your describle, you need do
1) please check the bios first, to set wireless to enable
2) check windows right buttom bar is there a wireless icon show there and click to see any detect wireless signal, if nothing to detect
3) check or compare to other laptop wireless configuration, check any incorrect setting.
4) if all sense ok, you need check the wireless card and wireless antenna wire connection, open a samll cover at back of laptop, there is a MINI PCI slot with a wireless card, take out and clean the card pins then put back.
5) still trouble please change another wireless card (same model)
it should be fix.
hope help you to fix it, please take a rating le me know how much helped you, thanks. for any question in any time please !
May 17, 2009 | Acer Aspire 6930-6455 Notebook PC
Cannot detect any wireless connections
Those types of devices if bent, while plugged in will stop working... Sounds like if you flex it as you plug in, it is briefly making connection. Is the device still under warranty? If so I would exchange it... One way to check whats happening on connection, right click "my computer" , go to properties, go to hardware then go device manager, then under network adapters, look for a red x. As the device is plugged watch for changes. If you see your buffalo device, and it has a red X, then I would try to re-install your drivers. If the device is not staying right after being plugged, I would suspect that may be physically broken.
Mar 14, 2009 | Buffalo Technology AirStation ...
WLAN not being detected in HP Pavilion tx1210 laptop
first of all is the wireless adaptor recognized under the device manager?
no, you need a new mini pci wireless lan card
yes, the wrong driver is installed, the windows utility is not enabled
Mar 02, 2009 | HP Pavilion tx1000z Notebook
Linksys router when cabled, doesn't work wireless to laptop
can it detect the wireless signal?
did you load the drivers for wireless card in laptop?
check the device manager for any ! or ? in it those need attentio
if you can detect the wireless network then you need to set the wepkey if its enabled. if its not and you have a signal then just click on connect in the wireless network manager
Jan 22, 2009 | Linksys Wireless-G WRT54G Router
Wireless router dynamode
if ur laptop detect full signal from ur router, click on the signal and let ur laptop connect to the signal..coz even ur laptop detect the signal,it doesnt auto connect,so u hve to connect it manually..
Apr 07, 2008 | Computers & Internet
Acer notebook wireless just connects when near to the modem...
The connection between the laptop's internal wireless antenna and its wireless card may been disconnected. Best to take it in to a computer shop for fixing. If you want to fix it, open the PCI-E cover on the bottom of the laptop, then reconnect the antenna wire. If that doesn't work, get it serviced.
Jan 02, 2008 | Acer Aspire 5100 3010 Notebook
Computers & Internet Logo
378 people viewed this question
David Payne
David Payne
