Question about Car Audio & Video
How to setup the time on a 1992 dodge dakota - Car Audio & Video
  • 3 Answers
Here is one way it may be very redneck, but this is how i always knew how to set the time. What you do is unplugg the battery a few minutes before 12:00, then connect the battery, and your ime should be set correctly, but you can only do that twice a day.
Posted on Jul 14, 2008
How to wire ignition system of 1992 dodge dakota
Make sure distributer is at Cylinder 1 at TDC (top dead center).
May 16, 2014 | 1992 Dodge Dakota
1992 Dakota 4 cyl.
Front of Motor---Cylinders--- 1,2,3,4
Firing Order---1-3-4-2 Clockwise
Timing 12 Degrees BTDC
Compression 135 #
Timing is set with timing light
Marks are under trans housing dust cover
Mar 28, 2013 | 1992 Dodge Dakota
I need the routing instructions for the serpentine belt for a 1992 dodge dakota 6 cylinder
some time the diagram is under the hood or on the radiator support or fenderwheel
Dec 11, 2010 | 1992 Dodge Dakota
I have a 1992 dodge dakota the rotor button in distribtor was melted accross the top of what would have caused it to happen
An electrical arc. After being hit millions of times by 30,000 volts they break down. Time for a new one :)
Hope this helps, and vote for me.
Jun 24, 2010 | 1992 Dodge Dakota
Replaced timing change on a 1992 dodge dakota set the number one piston tdcbut when dialed in its at the #6 position what do i do.
#6 on a V8 is BDC on exhaust stroke.
Don't forget your working on a 4 cycle engine.
1-8-4-3-6-5-7-2
May 20, 2010 | 1992 Dodge Dakota
How to override the computer on a 1992 dodge dakota to set the timming
Timing is set by the Crank Position Sensor and Computer.
The Hall Effect Sensor in the distributor,is for injector timing. DO NOT MOVE THE DISTRIBUTOR
Mar 28, 2010 | 1992 Dodge Dakota
1992 dodge dakota does if have a chain/belt timing
If you have the 2.5 you have a belt. Gates number for that belt is T153. If you have a V-6 or V-8 It has a timing chain.
Hope this helps
Mar 11, 2010 | 1992 Dodge Dakota
1992 dodge dakota
Loosen the hold down bolt at the distributor and the distributor will twist allowing timing adjustment.
Apr 20, 2009 | 1992 Dodge Dakota
Heater control valve
Where is the thermostat in a dodge dakota 1992 located? Flushed it yesterday still just have heat blowinf ti side vents rather cool windsheild defrost. Maybe there is another problem?
Nov 19, 2008 | 1992 Dodge Dakota
Car Audio & Video Logo
64 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
