Hello,My Philips DVP3200v/75 will not play videos.It will play for 9 seconds then turn off.When I push play again it ejects the the and the power turns off.Please can you help ?
  • Anonymous Oct 14, 2008
    I have the same prob
Took DVD back to shop and they replaced for another.
Posted on Jul 22, 2008
TV is on channel. VHS player has tape for playback loaded. Player is on but when PLAY is pressed 5 seconds later it turns off by itself. Model number is DVP3200V/37. Can anyone help, please.
Dirty magnetic head. Run a commercial tape head cleaner through it. You can get one at the box stores. Also, put your tape in a tape rewinder and rewind and fast forward the tape for about 30 seconds. Sometimes the tape ribbon gets wound too tight or is loose. If these fail, then you have to open the unit up and clean the magnetic head manually with some isopropyl alcohol and cotton q-tips. Also, look for capacitors on the power inboard chip that look burned and replace them.
Feb 04, 2010 | Philips VR621CAT VHS/S-VHS playback VCR
Disc is stuck inside goes on will not eject or
You will find a small whole in front of the disc. Quite small, say a niddle head size just take a pin approx 3 inches and poke it slowly inside. You shall feel the pushing of a soft touch feather button like on your keyboard and your CD will come out. Don't forget to push eject button before poking the pin. and kindly do rate my solution.
Jul 17, 2009 | Nintendo Wii Console
Philips DVP3345V powers off after 10 seconds.....
If unit has auto rewind \eject feature? Try getting it into F Forward mode befoe it powers down....
Aug 26, 2008 | Philips Magnavox DVD/VCR Dual Player
Wii
hello micky1965
Try holding down the eject button for at least 10 seconds after turning on the console. If that doesn't work (or you've already tried that). Try the following steps.
1. Unplug Wii from power outlet.
2. Plug in Wii again.
3. Press power button.
4. Press Eject button for at least 10 seconds.
5. If the disc doesn't eject try holding down the power button for 10 seconds and then the eject button again.
If that fails then either return the console to exchange for a new one or contact Nintendo consumer support. Info follows:
Nintendo Consumer Service Contact Information:
Telephone: 1-800-255-3700
Email webform:
| Nintendo - Customer Service | Contact Us! |
I wouldn't attempt to manually remove the disc (by trying to disassemble your Wii) as it may void your warranty. It could simply be a faulty console in which case Nintendo should replace it within 2 weeks (according to posts I've read). It seems to be a somewhat common problem.
If holding down the eject button doesn't work, there's really not much else you can do. Sometimes unplugging and replugging does the trick.
I've had problems with discs not ejecting and some combination of the steps I wrote above solved the problem.
riz.
althought i have a guide for opening inside the wii.?
Apr 08, 2008 | Nintendo Wii Console
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Vr540 philips
E2 is not an error code. It means that the video tuner is set to EXT2 (Scart input 2)
Press the VCR button on the remote control, and try again.
Nov 17, 2007 | Philips VR540 VHS VCR
Randomly Ejects Disc
not come across this b4 try some1 elses dvd rom in your unit m8 first dont sound like a board default
Nov 13, 2007 | Microsoft Xbox Console
Play station 3
Push and hold the eject button for at least 10 seconds to force an eject of the disc. After the disc ejects, turn the system off and then back on to resume play. Hope this helps. Good luck.
Jun 22, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
Electro Med Services...
