I tried all my cd's, and the motor works. My system is an mc-80 or 85. It has never been used until a few weeks ago by me. I tried to get a cd to play and i thought that maybe it was just because it was a cd-rw, but then it wouldn't play any of my cd's. Is there a way to fix this problem, as in a self repair, or would I mess the system up. EVERYTHING else works lke new.
SOURCE: TEAC MC-D95
weak or exhausted optical lens or laser assemly,needs replacement or adjustment,see a doctor.
SOURCE: Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: loud noise from subwoofer on standby or while playing music
Hi There, Please advise us what happens when you turn off the sub woofer is the hum still there....??
From YUBEUT.
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
If the no disc comes even without a disc in the player you must check and see if there is a mechanical fault specially in the loading section that seems to trigger the CD mode to work.
Also check to see the main motor as it will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
