Question about Samsung SCX-4216F All-In-One Laser Printer
Printer hey there i have the scx printer its saying toner low what would that be i thought it was my ink so i changed the cartridge but still saying low ink so i know its not that and i lost my book that it came with. cheers connie any help would be great.
  • Felix Lopez
    Felix Lopez May 11, 2010
    Are you using original Samsung toners or replacement/compatible cartridges?
You will need to manually reset the toner cartridge.
If the Toner Low or Toner Empty message does not automatically clear after a new cartridge is installed, do the following to clear the message manually:
  1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
  2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
  3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
  4. Press ENTER. The operator panel will display [YES].
  5. Press ENTER. The toner warning message should be gone.
  6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
  7. If problem persists, there may actually be a problem with either the toner cartridge or the SCX-4216F.
Posted on Sep 12, 2008
Scx-3405fw/xaa printer error "replace toner cartridge"
Replace the toner cartridge or refill the toner and change the toner cartridge chip and reset the page and toner counter.
Apr 10, 2013 | Samsung Scx 3405fw scx-3405fw/xaa...
How to change ink on samsung SCX-4X16 series printer
1. open front door,
2. look for black toner cartridge inside
3. pull back toner cartridge
4. Replace cartridge whit new one on the same place
May 21, 2010 | Samsung SCX-4016 Laser Printer
We refilled the toner and the light is still blinking and it says toner low
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 17, 2010 | Samsung SCX-4216F All-In-One Laser Printer
Ink cartridge is not accepted
You have refilled the toner, So When you refill the toner, u must repalce chip also.
www.nakshatraworld.com
Dec 17, 2009 | Samsung SCX 4200 All-In-One Laser Printer
New cartridge saying low toner
Try these steps:
Let me know if it doesn't work as there is another possible solution.
Sep 01, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Toner low
There is no Toner with this printer.
It uses Ink Cartridges. (It may say toner as that what most people
say ink is these days) - correct me if I am wrong!
The different ink colours are seperate, so you only replace the one which is low. Print heads need to be changed after changing the ink 2-3 times but it does not say that anywhere (I think they would recommend changing it all the time but that makes this v.expensive running costs which beats the object of this printer)
Yes I do have one, so I know what I am talking about.
Just a shame as my experience has led me to believe that this drains the ink as it calibrates every time you turn it on! (Paid £400 for this when it first came in the UK)
I do not leave it on standby and ink lasts me max a month and I only use about 100 ~ 150 pages (**** really) hence why use a laser for B/W and this for every thing else.
Plus any one know where you can refill this cartridge using standard ink?
Aug 04, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Black Cartridge just changed, but still says K-toner low
The only way to clear the message is to wait until the the display shows XXXX Toner Out, then change the cartridge and the message will clear itself.
May 18, 2008 | Epson AcuLaser C4000 Printer
Printer prints lightly after changing a cartridge
i guess you have problem with the poor quality ink.
faced same problem.
i re-filled with best ink in the market and the problem was gone..
i hope that helps
Mar 21, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
325 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
