Try draining the float bowl on the carburetor so that fresh fuel will flow in. Also, spray carburetor cleaner into the jets to remove any varnish from them. Add some fuel system cleaner to the tank so that when running, the cleaner will improve carburetor function. Hope this avoids a complete carburetor tear-down and clean!
The owner's manual should point out where the air cleaner for the engine is and also there should be a throttle control--usually both are grouped near the carburetor which is hidden behind a metal or plastic cover on the engine. Also, on engines of this type, the muffler is almost beside the carburetor. If you have a friend (with some tools) that is somewhat mechanically minded, you might be able to enlist some local help. One thing to try is to remove the spark plug, lay the base on some engine metal and run the starter--there should be blue, snappy sparks at the electrodes on the inner end. If nothing, is there a key of some sort that prevents running? Check your manual. If you get spark, try pouring a tablespoon full of fuel into the plug hole, replace the plug, and try for start--it should at least pop several times and may even start running. Good luck!
Thanks again drallim. This looks way too complicated for me, but I've recruited my father-in law to help.
Joseph
For temperatures above 32°F (0°C), use SAE 30W.
• For temperatures between 0°F and 32°F (-18°C to
0°C), use SAE 5W30 or SAE 10W.
• For air temperatures below 0°F (-18°C), use
SAE 0W30.
and you can get the manual here ... http://pdfservicemanual.com/home-appliance/2009-toro-power-max-826le-38622-snow-blower-thrower-owners-manual.pdf
Thanks for the advise, drallim. I'm not too mechanical and the thrower only came with the owner's manual, but not engine manual. I've been trying to obtain one over the net, but can't locate one. Where is the carburetor/float bowl?
Joseph
