Question about Philips 60P8341 60" Rear Projection Television
Tv fix Yes i need help trying to locate and how to repair please.
  • Philips Master
  • 8,617 Answers
I have no clue as to what youre needing unless you respond to the origional post each time, as I have no way to distinguish one request from the other . CXan you please respond to this post with what your symptoms are and what you are needing to locate.Thanks
Posted on Jul 15, 2008
Yes, I need to fix the signal light sound effect of my cobalt Chevy 2007... it's on and off...need your help please...
with the help of the repair manual it will be very easy to solve the problem you are facing even in future if you face any problem you will be ablle to locate and fix it your self http://toolsnyou.com/
Sep 11, 2017 | Cars & Trucks
I have a Samsung LED TV model number UN50EH6000FXZA and the screen flickers. I am trying to figure out what jumper number to cut. Please help!
It might be your "ISL9860" chip on the T-con board, the video was called, "Samsung UN60EH6000 Series T-Con Repair BN95-00628" and is located at:
https://www.youtube.com/watch?v=iuHrnvAKlGw
Yes it's a bit different model number but see if it is close enough to your TV to be useful. He says that models UN60EH6003 and 6050 were the same kind of fix for the no video problem so perhaps your UN50EH6000 is also close enough to the UN60EH6000 model.
He did not mention anything about a sound but it was a no video problem he was fixing. If your voltages are OK on the T-con board then you may want to contact him directly through youtube to see if he has fixed your type of problem. Otherwise this is the first part I'd replace.
Watch the video all the way through because he also mentions some caps that may need replacing as well.
Phil
May 02, 2017 | Samsung Televison & Video
I Need help please.something came up on my ps3 i pressed yes without reading..yes i know and now it wont read any dvds i put in it.please help.
this similar kind of problems faced by my friend........... its easy to fix this problem.....using repair guide u can easily fix this problem without any tension.. all the best
click here to download repair guide
Dec 06, 2010 | Sony Playstation 3 (PS3) Console
Colors are not focused. blurred picture. was told it was converganc. manual focus doesn't fix it. please advise if it's worth fixing. Fred C.
Yes,Ur tv convergence are dead.Must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300-$350 for parts and labors.
Apr 12, 2010 | Hitachi 61SWX01W 61" Rear Projection...
Color on tv are off green red blue as if it was three D. HELP!!!!
Yes, its problem of convergence out chips failure, replace two big black convergence out chips in TV to fix the problem.
If you are handy with electronics stuff repair and can replace parts in circuit board with proper tools then you can fix this TV issue by yourself or ask local tech to repair it.
Thanks.
Jan 15, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Flat Panel Emerson Tv lc32oem82s
Answer your first question. yes, it is the same part.
To help you with the second question I need some info.
1. Do you have a multimeter?
2. A sodering gun with new soder and soder removal braid?
3. Sodering skills on circuit boards?
Jan 26, 2009 | Emerson EWL3706 37 in. LCD Television
No convergence on tv
Yes,U know how to solder?Follow ur tv name and model,buy ur convergence kit and replace.
Tries these websites.Tv Repair World.com,and Shopjimmy.com.
Sep 05, 2008 | RCA HD61W66 61" Projection HDTV
Ge Television Repair
The repair for the tuner shield is quite simple but it might not fix it at this point.
1. Remove the back cover.
2. Remove the PCB from the where is attach to.
3. Remove the tuner's shield from the top and bottom side.
4. Locate the grounds from the shield and apply fresh solder.
5. Once the solder is done, install the shield cover back on.
The red colour before the TV went black could be related to a dry or crystallized solder at the CRT video amplifier board.
Let me know if you require further assistance.
Jul 15, 2008 | Televison & Video
Please help me fix my tv
You will need 2 new convergence ICs STK392-110 also the 1.8 ohm resistor and the pico fuse usually burn with that model. the ICs are located on the small board located behind the speaker grille and access panel in front. Easy repair go to the following link and you can get replacement ICs and any other part you need. And they provide installation instructions as well as free on line instant meassaging for all customers when they do thier actual repair. Heres the link.
http://servicemanuals.vstore.ca/
Apr 08, 2008 | JVC AV-48WP30 48" Rear Projection...
Panasonic PT-47WX53 does not turn on
Yes, I did try to use the power button on the TV itself. That did not work too. Yes, there is blinking red light too. I searched through several sights and found out that it is an issue with the IC 4511. I could not find a place to buy the chip.
By the way, our local TV dealer asked for $400 to fix this issue. I had already spent $400 on a different repair on this TV, 6 months ago.
Any suggestion/advice would be very helpful. Thank you again for your response.
Feb 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
