Question about Sony PlayStation Portable (PSP) Console
PSP umable to recognize memory card
PSP memorycardslot notworking
    Problem Solver:
  • 10 Answers
Memory card could be full
Posted on Jul 19, 2008
I have a memory a card, SAND DISK, my problem is why my psp can't recognize my memory card?
Maybe ur mem card is busted? Try FORMATiNG ur mem card in ur PSP! or insert ur card into the slot and try to press the card at one side....see if ur PSP register the card, sometimes the card contact point didn't touch PSP's contact pins!
Nov 09, 2010 | Sony PlayStation Portable (PSP) Console
My psp memory card dont let me put stuff in
you may have to format the card. Also make sure your card is not placed in the lock position.
    How to Fix a PSP Memory Stick
  1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
  2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
  3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
  4. Step 4 Copy your files from the memory stick to the hard drive.
  5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
  6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
  7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
  8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
Mar 25, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Breath of fire 3 on PSP gives a insufficient memory to save error with an essentially empty 4 GB duo memory card - why?
I had the same problem, solved by downloading a save game in gamefaqs and putting the save in the memory card, then just overwrite the save in the game.
The game does not recognize memory card above 2GB.
Hope that helps.
Mar 12, 2010 | Capcom Breath Of Fire III for PSP
Psp memory card is not recognized and will not
What you can do here first is to save all the data of your memory card to your computer and then after that format the memory card using the format option on your PSP....
Dec 30, 2009 | Video Game Consoles & Games
Psp usb problem..unrecognised memory stick..
DID U FORMAT UR MEMORY ANDIF U DID NOT FORMAT UR MEMORY THAN SEE IF U HAVE UR USB CHRGE ON DISABLE IT AND ULL B ABLE TO GET INTO UR PSP VIA USB CABLE CONNECTION
Jun 30, 2009 | Sony PlayStation Portable (PSP) Console
PSP not reading Memeory Stick.
If it is not a psp memory stick,or a compatible psp memory stick,IT will not work.Most memory sticks are not compatible with the psp.
Please take time to rate this fixya
May 12, 2009 | Sony PlayStation Portable (PSP) Console
Memory card
did you format new memory stick psp will not recognize till that is done. if your technically inclined and the psp is out of warrenty open up the unit and make sure contacts on memory stick recepticle are touching.
Apr 11, 2009 | Sony PlayStation Portable (PSP) Console
My psp cannot read the memory card...help me please...
is it a {sony} memory stick duo?if it is then it is your psp if not then its your memory stick
Jan 23, 2008 | Sony PlayStation Portable (PSP) Console
Psp
* Make sure you have inserted a memory stick, and enable the usb connection via settings=>usb connection
* Check the usb cable, or simply find another one to try if it works.
* If there is a memory stick inside the psp and the psp can recognize it, then you most probably have a problem with your cable or usb port.
* if there is a memory stick inside the psp and the psp cannot recognize it, as well as the computer, then you are most likely to have a failure with your memory card.
There are too many possibilities, maybe you can give me details straightaway, so more people can help you.
Dec 26, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
