Question about Canon imageRUNNER C3220 Color Copier
Colors are off registration
Recently my prints are off registration and noting i try is working. The color are not lining up as all 4 color prints off registration... Please let me know if there is anything i can do to correct this issue.
    Problem Solver:
  • 8 Answers
Try stripping out the ITB assy and washing the main drive roller and the lead roller...ONLY wash those two rollers and NOT the foam rollers.
If it's only one or two colors that are out then try replacing the internal transfer rollers for the colors affected.
If all else fails do a P-Print then do a DC claer and re-enter the settings from the P-Print.
Posted on Jul 22, 2008
  • 446 Answers
This problem can sometimes cause by uncalibrated machine upon replacement of major parts such as assemblies. or parts related to fusing, developing of drum related parts
mis registration of colors can appears if you machine isnt calibrated nor cleaned correctly, try going throug a resetting or set up procedure from your maufacturers manual
this would surely resolve your problems
Posted on Jul 14, 2008
My Konica Minolta Cf3102 gives me the machine status error P21 ? What does it mean and how can i reset it?
REGISTRATION ISSUE COLORS NOT ON TOP OF COLORS. You need to run the color registration procedure in service mode. requires print out to be looked at,
P codes will allow you to use the machine put degraded. Are your prints coming out with colors not on top of each other?
Try this site for the manual.
Service manuals electronic components datasheets and equipment schematics...
if the procedure does not work you mite have a bad regrestration assy which located under the transfer belt (Where the handles are for the belt
Jul 20, 2015 | Konica Minolta Office Equipment & Supplies
Ricoh CL7300 not printing the colors corrrectly
Look at the transfer unit. If the clear belt has alot of wear lines the belt needs to be replaced pn# B180 3780
The machine builds the alignment image on this belt and then reads it if the belt is cloudy it will fail.
Mar 23, 2010 | Ricoh Aficio CL7300 DT2 Laser Printer
My MP530 willnot print black printed text. How do I now if the ink head is plugged and what do I do about it?
Hi ...
I would suggest you try and clean the print head and that should resolve the problem. Follow the below steps to clean the print head:
Perform a Cleaning of the print head:
Caution: Cleaning consumes a certain amount of ink. Perform Cleaning only when necessary.
Note: The pattern varies depending on the printer and version of Windows being used.
  1. Click 'Cleaning' to perform print head cleaning from the Pattern Check window and proceed to step 3 of the print head cleaning instructions. If the Pattern Check window is closed, skip this step and proceed to step 2.
  2. To perform a print head cleaning from the Maintenance window, click 'Cleaning'.
  3. When the Print Head Cleaning window is displayed, select the target ink group for 'Cleaning'.
    Note: When performing Cleaning for all colors, check 'All Colors'.
    Note: When performing Cleaning for Black only, deselect 'All Colors' and check 'Black'.
    Note: When performing Cleaning for Color only, deselect 'All Colors', and check 'Color'.
  4. After selecting the target ink group click 'Execute' to perform the cleaning of the print head nozzles.
  5. When the confirming message is displayed, check the contents, and click 'OK'.
    Caution: Although the Nozzle Check window is displayed, do not perform any other operations until Cleaning is completed.. Cleaning will take about 40 seconds.
  6. Print a Nozzle Check Pattern and examine.
  7. Perform Cleaning again if necessary.
    Memo: If the pattern is still abnormal after two Cleanings, perform up to two Deep Cleanings.
Perform Deep Cleaning of the print head
Caution: Deep Cleaning consumes a larger amount of ink than normal Cleaning. Perform Deep Cleanings only when necessary.
  1. In the Maintenance window, click 'Deep Cleaning'.
    Note: The layout varies depending on the printer and version of Windows you are using.
  2. When the Deep Cleaning window is displayed, select the target ink group for Deep Cleaning.
  3. Click 'Execute'.
    Memo: By clicking 'Initial Check Items' before clicking 'Print Check Pattern', you can see the specific confirmation items in Nozzle Check.
  4. When the confirming message is displayed, click 'OK'. (The Power lamp will blink green and Deep Cleaning starts. The blink stops when Deep Cleaning is over.)
  5. When Deep Cleaning starts, check the contents, and click 'OK'.
    Caution: To prevent interruption of the Deep Cleaning process, do not perform any other operations until Deep Cleaning is completed. When the operation of the printer is stopped, Deep Cleaning is completed. Deep Cleaning will take about 75 seconds.
  6. Print Nozzle Check again.
    Note: If the printed pattern is still not normal, perform steps 1 through 4 of the Deep Cleaning process one additional time.
    Caution: If after two Deep Cleanings the Nozzle Check Pattern is still not normal, turn the printer off and let it sit for 24 hours or more before attempting another Deep Cleaning again. The wait time may allow dried ink in clogged print head nozzles to liquefy, and resolve the problem
If this does not resolve the problem, please reply back and we'll try the next step ...
Don't forget to vote if this helps ... Cheers :)
Aug 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
HP Photosmart C6180 colors no good - missing colors & muted. No longer aligns print when requested, per HP note at end. Already cleaned print heads,[OK], aligned printer numerous times-doesn't work....
try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Apr 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
LED reads color registration error
The black along the side of the paper is usually the black photoconductor , it also could be the fuser. If the color reg says can't be preformed it probly needs a new transfer belt. If the color reg completes and the colors still don't line up it might be the laser. It also could be dirty reg sensors.
Mar 24, 2009 | Ricoh Aficio AP3800C Laser Printer
My hp officejet 9130 will not print in color.
Try runing the printer test and see if colors print. If they don't your color cartridge is cloged. You can try to set the print head(copper strip on bottom of cartridge) on a damp paper towel for a while to try and unclog the head. You should see the colors on the towel. Dry head off and try again. Hp uses water base ink and it will dry up after setting for awhile. The printer knows it has ink in the cartridge, because it will try to print, so it has to be the print head.
The print head has two lines of holes or jet for each color and if some of them are cloged, it will look striped or missing colors.
Mar 05, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Skewed printing
Most probably you have to do the Color Registration Settings and the Color Calibration.
The Color Registration will fix the fuzzy printing and the Color Calibration the way how the colors looks. The Color Calibration it is done automatically after each batch of 40 or 80 pages and if you need you can do a manual Color Calibration BUT THE COLOR REGISTRATION must be done manually.
Go to Menu->Others->Service->Color Registration and print a test chart. Will print a page and you have to read the alignment of some lines Cyan Magenta Yellow Black with some numbers. Check the Advanced user guide for details. Basically you have to read the number / letters of each color where 2 lines are matching. Then you can enter those numbers into the printer for each color.
If the Cyan only is off then will be easy ...
Nov 03, 2008 | Kyocera FS-C5030N Led Printer
Epson Stylus color Printer prints strange lines and doesnt use all colors
You can get this sometimes in Publisher programmes, it's a glitch, but also check cartridge alignment. If your not happy uninstal printer driver, disconnect printer and re instal driver first then re connect your printer.
Oct 25, 2006 | Epson Stylus Color 760 InkJet Printer
Canon imageRUNNER C3220 Color Copier Logo
374 people viewed this question
old marine
old marine
