Question about Zenith R57W46 57" Rear Projection Television
Convergence IC replacement
Hi there - a local repair company has told us the IC's required replacement in our TV. They then told us that the parts were back ordered with no ETA; I have since found numerous companies online with replacement parts with the same part # but they are all a different manufacturer. My question is this; are parts with the same # truly the same? does the manufacturing brand matter if the part numbers are identical? thank you!
  • Zenith Master
  • 8,617 Answers
No as long as the STK number is the same they will work. Just be careful where you get the parts as alot of places online sell cheap chinnesse made ICs and they wont last. I usually get mine at the following link, and I havent had any trouble with their ICs.
http://servicemanuals.vstore.ca/
Posted on Jul 25, 2008
I have a older model mitsubishi 40" tube tv. After we turn it on it cuts off in about 15 minutes. It will cut back on but turns off in shorter and shorter time periods. I'm guessing it heats up a...
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Thanks and take care....
May 12, 2011 | Televison & Video
The picture has double images and looks kind of like it is 3D.
The tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergnece board,must have these parts changes on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I need an HDMI PCB
These parts come from yamaha so you will just have to wait, sorry. They get replaced commonly. Larry's Electronics.
Apr 23, 2010 | Yamaha RX-V661 Receiver
I have an Audiovox FPE2306. The TV will not power up from standby. I have taken it to a local repairman who was able to get the specs but the company would not cooperate and ship the replacement parts. I...
Hi there! I know what you must be going through. Spending all that money and no back-up support. My suggestion is to browse Google for either Audiovox LCD or LCD spares. Depends on which parts your repairer is looking for. If you require any further assistance please don't hesitate to contact me. Best Wishes and Good Luck,JUS004
Aug 23, 2009 | Audiovox FPE2306 23 in. LCD Television
Vertical lines on LG-DU-42PX12X
please change vertical ic oc decosition coil solderd
Aug 07, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Samsung projection convergence issues
turn off your TV for 30 mins. and try one more time...
Mar 20, 2009 | Samsung HCM5525W 55" Rear Projection...
Our TV (Mitsubishi WS65711) is 6 years old, and has recently started showing a blue ghost image on everything. It stopped for a while for a week or two, but started back up, and has continued ever since. I...
You have convergence problem in your tv as your local repair shop told you. You need to replace convergence IC . YOu can get from the link below .
Convergence IC can be obtained from the link
You need to replace both convergence ICs .It will cost you around $30
If you can replace it by yourself . If you take to repair shop they will charge you around $200 for this job. .
The IC number is STK393-110 .
You can get some idea on how to replace convergence IC from the link below
http://www.fixya.com/support/r704766-convergence_solutions
Hope this helps .
Feb 19, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Samsung HCL473W 1080i red shadow & words are curved at top/bottom
I believe you have convergence problem on your rear projector TV. It require to replace may be 2 IC output convergence or the convergence drive, after replace those component you need to readjust convergence which mean you move the RED GREEN BLUE to be 1 on top each other you must have the remote control and service manual to get into the service mode, if you thing you can get those part in your country the service manual I may help you with that, ask your husband if he like to challenge it. I hope that is give you some ideas
Cheers
Dec 17, 2008 | Samsung - Projection TV replacement lamp...
Philips Rear Projection Model 55PP8620 - convergence problem
Manufactures sometimes contract with other tv companies to build their tv. Regardless of the internal hardware you still have a philips tv. I beleive this set was made by Hitachi. And what you are looking for is a replacement board. This board is referred to as the small signal module. When contacting a rebuilt board, have the model# and the chassis# available. And contact PTSELECTRONICS.com or Andrews Electronics.com. The board you seek is in the rear lefthand side on the floor of the TV. You will see a pair of tall aluminum fins. Theses are the heatsinks for the convergence ICs. I would definitely replace this small signal module, as repair on the local level will require pulling the board in and out of the tv several times. The company will give a part number and then you may order this. Striving for success the first time!!!!
Sep 13, 2008 | Philips (867093110009) Projector Lamp for...
New LCD
What ever Sony is offering you, seems good for LCD. there is no easy repair solution for LCD Panel problem.
May 27, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Zenith R57W46 57" Rear Projection Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
