Question about Zanussi FJS1225W Front Load Washer
E90 code on a zanusi jet syatem turbo dry 1600
E90 code coming on but code not in book
  • mccalmont4 Jul 18, 2008
    thanks for that perhaps it time for a new machine than ,prob cheaper in the long run cheers!
    Problem Solver:
  • 10 Answers
A E90 fault code means the main pcb board is faulty and i'm afraid to say, they are a expensive item and not always easy to replace, some come pre programmed and just swap across and others have to be programmed using the code on the white sticker on the board housing. either way it normally better to get a engineer to replace it because you don't get the programming instructions with the new pcb. I hope this helps
Posted on Jul 18, 2008
What does it mean when E90 flashes on my Simpson front loader 7kg washing machine and it's stopped working?
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer as this will be the only way to know for sure...
Nov 13, 2016 | Simpson Washing Machines
Dishwasher does not dry
First, make sure you are using Jet-Dry (or equivalent) rinse-aid. As part of this "green", ecological, environmentalist-wacko movement, dishwasher makers have cut down on the amount of heat generated by the heating element, and as a consequence, it is now imperitive that you use rinse-aid to help with the drying. Note: Finish Corp (the makers of Jet-Dry) now make a version called "Turbo-Dry". Try that (if you can find it).
Jun 07, 2014 | Samsung Dishwashers
Machine flashing E90 and not working.
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer.
Jan 16, 2011 | Washing Machines
I have a electrolux front loader ewf 1087 that shows the code e90 on start up...i have cleaned the plug that the blue wires go in to & still flashes e90 con soneone help..thanks
Jan 10, 2011 | Washing Machines
Jet 3 flashes "code 7".
The VSI joystick controller of the Jet 3 with a flash code of 7 LEDs flashing on the battery condition display indicates a possible joystick fault.
The most likely problem is with the joystick gimble. You can also get a 7 bar flash if the joystick is out of the neutral position at start-up.
Run the joystick in a circle and back and forth feeling for any sticky or broken/dead spots. Check to see if the spring and gimble come back to center when you release it. Turn off the VSI and try centering the joystick. Turn the VSI back on and see if you can get the fault to clear.
The only recourse is to have the unit rebuilt or replaced . A rebuilt VSI will run about $500 and a new one about $1600. For this reason it is best to check with your insurance before performing the work to see if its a covered item. Hope this helps
Nov 30, 2010 | Jet 3 Ultra Power Chair
Laser jet 1600 printer high pitched squeal
It proberly has dust in the printer near the spool (the picture below)
Sep 11, 2009 | HP Hewlett Packard LaserJet 1600 Printer
Zanussi jet system 1000
Jul 09, 2008 | Zanussi FJS1225W Front Load Washer
Zanusi zwf 1631 w wont work
all of the e50 codes indicate motor check your brushes. if you still have problems email me
Feb 10, 2008 | Zanussi ZWF1630 Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
331 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
