Question about Kenwood KCA-BT100 Wireless Headset
Kenwood Bluetooth HF Error 104
I have a Kenwood KDC-MP438U head unit with KCA-BT200 Bluetooth adapter. I use a Samsung M300 wireless handset. I have been able to successfully pair, but unable to call recently. When I look at the properties of the KCA-BT200 on my phone, the Supported Profiles say "NOT TRUSTED".
I also have gotten "HF ERROR 104".
The system has worked once before, but failed after I tried to set up presets for phone numbers on the head unit.
  • anton735 Feb 16, 2009
    I have same poroblem.
  • joopapa Apr 15, 2009
    I have a very similar problem if not the same one. My iphone used to connect fine. But after I tried to add presset number or quik dial numbers it stopped working. First I noticed it did not save the numbers correctly. It only took some of the digits. I think it stopped working after trying to dial one of the corrupted preset numbers.
    Now my iphone says it is paired but the "Tel" icon is yellow on the bottom of my DNX7320 screen. In the bluetooth preferences I can not find any devices and the HFP Device is not connected and I have no "set button" displayed next to it.
    Any one have any ideas how I might fix all this. I can't even seem to find out how to repair the deivce from the stereo.
2 Suggested Answers
SOURCE: Have a new KCA-BT200 and
ok first u have reset the KCA-BT200,to do that remove your car battery cables for 3mins and reconnect your battery cables,
by lil_ti2002@yahoo.com
Posted on Apr 06, 2009
How do I make my kdc-mp242 bluetooth discoverable?
In order to use bluetooth with your receiver, you need to purchase the Kenwood KCA-BT200 Bootooth Interface. These are readily available online and can be had for $100-$150: Kenwood KDCMP635 KDC MP635 KDC MP635 50W 4 MP3 WMA AAC CD Receiver cheers
Mar 15, 2011 | Kenwood KDC-MP242
How do I set this deck to use my iphone to make calls trough the stereo?
You will need to purchase the KCA-BT200 bluetooth unit and connect it to your head unit. Then you can even connect up to five bluetooth phones. dreamsystems.
Feb 21, 2011 | Kenwood KDC-MP2035 CD Player
Quiero conectar el bluetooth
Este es el modelo que Ud. necesita comprar para que funcione el bluetooth en su radio y este es el link con todas las indicaciones necesarias
http://inform3.kenwoodusa.com/Manuals/kca-bt200.pdf.
Jan 30, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
People can't hear me clearly on my KCA-BT200.
Bluetooth originally had a limitation of about 30 feet +/-, however that doesn't mean great clarity until it reaches its peak distance range. With that said, I would suggest trying to move your phone around in the vehicle to get the shortest distance possible to the receiving Bluetooth device (KCA-BT200).
May 30, 2009 | Kenwood KCA-BT100 Wireless Headset
How to use bluetooth
as far as i'm aware i think you need this device to get this to work. http://www.kenwood-electronics.co.uk/products/car/functions/bluetooth/KCA-BT200/
May 14, 2009 | Kenwood KDC-MP435U CD Player
Have a new KCA-BT200 and when I try to connect the bluetooth it keeps disconnecting. If it helps, the Navigation system is KNA-G510
Jan 20, 2009 | Kenwood KCA-BT100 Wireless Headset
Bluetooth XM not meshing
does xm adapter have a pass thru port on it as in mine is sirius and i have radio changer output pluged up to the sirius unit then from sir changer output i have the bt100 plugged up and mine works great
Jan 06, 2009 | Kenwood KCA-BT100 Wireless Headset
Connecting Bluetooth to Kenwood KDC X590
you need a kenwood kca-bt200 which is a bluetooth plugin for your head unit. when you have installed this here is a check to see if its recognised.
1 Select the STANDBY
Press the [SRC] button.
Select the "STANDBY" display.   2 Enter Menu mode
D-1:Press the [MENU] button for at least 1 second.
D-2:Press the [MENU] button.
D-3:Press the [FNC] button.Turn the Control knob to select "MENU", and then press the Control knob.
"MENU" is displayed.   3 Select Bluetooth device selection mode
Push the Control knob towards up or down.
Select the "Phone Selection"/"PHONE SEL"/"PHN-SEL" display.   4 Enter the selected Bluetooth device selection mode
Press the Control knob for at least 1 second.   5 Select the KCA-BT200 Firmware
Select the "BT200 FW ***" display.   6 Exit the Bluetooth device selection mode
D-1/D-2:Press the [MENU] button.
after this you should be able to pair from the headunits menu
Nov 27, 2008 | Car Audio & Video
Kenwood KCA-BT100 Wireless Headset Logo
345 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
