My laptop hasn't been giving me correct reading for my battery. the screen icon is reading 1% plugged in not charging where as the outer icon reads it has a full charge. the laptop has also been cutting out unexpectantly.
    Sergeant:
    Champion:
  • 327 Answers
You might have to go in to the power mangment area and see if that might be the problem set it to the middle setting if not it could be a bad battery ..
Posted on Jul 14, 2008
Battery Icon reads. Plugged in but not charging. What's the fix?
Confirm that the charger is plugged into the electrical wall socket and the light on the charging unit is on. Ensura all connections are secure and not loose.
  1. If all is in order and the laptop is still not charging, the battery OR the charger may be defective.
  2. Shut off the computer.
  3. Remove the battery for 10 seconds
  4. Reinstall it.
  5. Try charging it with the charger again. If that works, good. If not, call customer support.
Aug 25, 2014 | Computers & Internet
Laptop will not charge battery. Issue with internal power converter, etc.
The motherboard has charging circuits built in to regulate the charge to the main battery, in rare causes it fails leaving a choice to attempt a repair or replace the motherboard. I suspect this is what has happened to your system.
Apr 05, 2012 | Lenovo IdeaPad U550 (374955U) PC Notebook
It not charging fully
Stan Issue is probably batteries. If you are charging overnite and never get a full charge then I would suspect batteries. If you have a voltmeter set it to 200 vdc and plug the leads into the two outer holes of the charger port located under the front of the joystick. When fully charged you should read 25-27 volts. If you are reading a lower voltage then I would check the charger. you will have to read the voltage at the battery posts with the charger plugged into the charger port You should read 27-30 volts. If you are not getting that reading replace the charger. Try borrowing a charger from someone that also has a chair If it charges the batteries then you need a new charger if it doesn't then you need new batteries Hope this helps
Feb 07, 2011 | Ctm HS-2800 Power Wheelchair
I can not see my battery light, How do I know the battery is charging or not?
You can monitor remaining charge with the software (for example go to control panel on XP, power options, power meter and advanced and choose to display on taskbar). The light however should be on, have you tries a different power supply?
Jan 27, 2011 | Dell Latitude D600 Notebook
Laptop battery is dead and it will not run on DC power
Sounds like your power supply unit (PSU) is broken, do you get any lights come on when you plug in the DC cable and try to switch on?
Jan 09, 2011 | IBM ThinkPad T20 2647 Notebook
When I switch on my Acer 5551a laptop, the charger amber light flashes off & on, when I click on the plug icon it reads, 1% available (plugged in not charging) why is it not holding a charge? Thank...
Either the battery is exhausted or the adapter is faulty. You didn't say whether the laptop was working with the adapter, if it is then you require a new battery.
Ebay!
Hope that helps.
Jan 02, 2011 | Computers & Internet
My Dell Laptop syas that my battery is charged. But when I remove the ac power cord the computer immediately shuts down.
I repair laptops professionally and work on many Dells. Here are the possibilities.
1. The plugin connection where the battery meets the charging contacts in its bay where it seats are malfucntioning and the software is reading it incorrectly. To see if this is so, push the small round black button on the battery next to the 5 little dots at one end. If none of those dots light up green, the battery has no charge and the connection I spoke of above is damaged or malfunctioning beyond where you can see. If all the dots light up green, the battery is likely fine but the laptop can;t connect to its charge at the plugin.
2. The basic software (BIOS) is reading the charger/adapter incorrectly and although saying it is charging or charged, the actual charger is ruined inside in the compartment for charging the battery. Dell chargers can actually be incapable of charging the battery but still run the computer on direct current while plugged in.
3. The battery is no longer able to be charged, but is giving a false reading.
4. The DC Power Jack (into which you plug the charger) is only partially damaged and while able to power the laptop directky, cannot charge the battery. (Check to see if it is loose and woobly when you plug in the charger.
The easiest and least expensive way to troubleshoot and fix this yourself is to start with the charger. They can be had on eBay for about $20. Keep in mind that if no green lights show up on the battery, it might be your first choice and it's about the same price.
I hope I've given you enough info the help you determine your true problem.
Regards,
The Selkie
Aug 29, 2010 | Dell Inspiron 6000 Notebook
Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Apr 07, 2010 | Coby MP-610 MP3 Player
Hunged-up iPod
this is what i just did with my daugthers ipod, that did not charge nor read hers either, turn on ipod if not still on (kill the battery totally)....later on tonight or when its dead...power up the pc / laptop, bring up itunes then connect the ipod to pc (two things should happen 1 - do not disconnect shoud pop on ipod screen and 2 - the ipod icon should pop on itunes) when updating itunes make sure ipod is not connected.
Apr 09, 2009 | Apple iPod MA446LL/A MP3 Player
HP Compaq plugged in & blue light on but icon says NOT plugged in
Check power out put of the adapter is it giving you the correct readings
Try to remove the battery and run it from adapter itself check to see if its working
Reset the battery ..by removing it from the system
Nov 10, 2008 | Compaq Presario Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
