Question about Sunbeam Heating & Cooling
Sunbeam air conditioner
We have a sunbeam window air conditioner and it is blowing water out the front
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
if this helps please give me a fix ya
Posted on Jul 14, 2008
Air conditioner will not cool bedroom
It sounds like the unit is failing to refrigerate, the cracking noise is most likely a compressor fault (trying to run) it may be stalled or have suffered a motor failure. The noise may also be an electrical short but unlikely as this would trip the safety trips in the house.
If you still have warranty i would return it or demand a HVAC engineer to inspect and repair faults.
all the best
Jul 05, 2010 | Sunbeam SCA052MWC1 Air Conditioner
Blowing water
Window Air conditioners need to tip back just a bit in the window...if they are flat or tipped front you will have the water problem...
Here also is a tip that will help you to keep you Air Conditioner running well...
Window Air Conditioners - Clean them every year
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
heatman101
May 07, 2010 | Haier hwr10xc6 Air Conditioner
Why isn't my Sunbeam Window A/C blowing hard on high?
If the air doesn't seem cool enough it is necessary to use a thermometer to check the difference in temperature between the air going into the unit and the air being blown into the room. Ideally, the temperature difference should be more than 15 degrees. For example, if the temperature going into the air conditioner is 80 degrees, the temperature coming out of the unit should be at least 65 degrees or less. If the difference is 15 degrees or more there is probably no cause for concern. If the temperature difference is less than 15 degrees you should check the following:
  • Air damper
Check to make sure the air damper is closed. If it's open, it will bring in outside air and reduce the efficiency of the unit.
  • Back cover
During the winter season many people cover their air conditioners to protect the unit from the weather. In the spring or summer they will sometimes forget to remove the cover. If your unit has a cover on the outside portion of the air conditioner remove the cover first.
  • Condensing coils
The condensing coils will always be on the "warm" side of the air conditioner. That is, on the side that faces outside of the room to be cooled. Air is drawn into the back of the air conditioner on the sides through vent slots and is blown directly out through the condenser coils. If the coils get clogged with lint, dust and dirt the cooling system cannot provide the cooling necessary. To clean the coils it will be necessary to remove the entire cover of the air conditioner or pull it out of the wall to gain access to the coils. They can be cleaned by blowing compressed air at them or by using a soft bristle brush to wipe the dirt off. It is important to also clean any dirt or lint build-up in the bottom of the air conditioner so the condensate water will be picked up by the condensing fan slinger properly.
Aug 16, 2009 | Sunbeam SCA052MWB1 Thru-Wall/Window Air...
I have a sunbeam 12000 btu window unit air conditioner. I can't seem to change the fan speed when it is in cool mode. When I put it on fan only it blows extremely cold air and i can change the fan speed. ...
Sounds like the switch is wired wrong.
When you put the switch on fan only the compressor should not run at all, therefore their shouldn't be any cold air.
Check the switch to see if it's wired right.
Jul 29, 2009 | GE Profile ASM10AA Air Conditioner
Goldstar 10000 blows water out front
Two possible problems.
1. High humidity in the space being cooled
2. Drain line that runs from the front (where the water is blowing out) to the back where it is sent to evaporate. Clean out the drain line and condensate pan under the fins where the water is blowing out.
Jul 10, 2009 | LG Goldstar GWHD5000 wall/window Air...
Our air conditioner seems to be working fine yet t won't blow cold air. Its just room temp air actually feels like you're standing in front of a small fan.
check outside unit large pipe should be cool or even very cold small pipe should be warm to touch that will eliminate some questions in order to solve problem also check circuit breaker for outdoor unit see if fan on outdooor unit is running and listen for compressor hum
Jul 02, 2009 | Sunbeam Heating & Cooling
Heating & Cooling Logo
693 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
