Question about Motorola Talkabout FR50 (14 Channels) 2-Way Radio
Talkabouts not communicating
I have a set of fr50's, and one T5600. The 5600 will communicate with ONE of the fr50's, but the fr50 cannot transmit back for some reason. The two fr50's cannot communicate with each other, and I cannot even get the channel to change on one of them. One of the fr50's will transmit a signal to the other, but will not carry a verbal message. The other won't even transmit a signal to the first one. Can someone help me to at least get 2 of my talkabouts to communicate with each other?
  • Motorola Master
  • 1,654 Answers
What you have described is typical of the radios not being on the same frequency and/or code. If you know how to put your radios in programming mode, set all the frequencies and codes to the same number, then they will work together. If you still have the owners manual it will describe this process. Usually with a TalkAbout radio it consists of holding in the PTT while turning the radio on.
As you are probably aware, the radio will have approx. 14 frequencies installed. You can usually select these easily from the front panel. The second number you see in the corner of the screen when you turn on the radio is the "code". This is an interference eliminator. All of your radios need to be set to the same code to work correctly together. If you find one or more of your radios does not have "code", simply set those that have "code" to zero.
Posted on Jul 15, 2008
How do you transmit from a cb radio to a talkabout fr60 and vice versa
CB radios and TalkAbout FR60 radios will not communicate together. CBs are 26-27.5 MHz and TalkAbout radios operate on FRS and GMRS frequencies between 462-467 MHz.
Best regards.
Oct 10, 2014 | Motorola Talkabout FR60 (14 Channels)...
TalkAbout MR350 not hear Talk About MD200
Check your CODE settings. From your description you likely have the CODE set to a different number on the MR350 than the MD200. I would guess the MD200 is set to zero since you can hear the MR350 when it transmits. Set your codes to match one another, and turn off any special features such as call alert or Qt filtering.
Ordinarily I would post links to the user guides, but FixYa seems to be having a problem with this feature today. If you need the user guides visit giantintl dot com website.
Best regards.
May 22, 2013 | Motorola MR350 Two Way Radio
Motorola fr50 red flight flashing quickly
Hi Kenny,
While the red light is blinking, is there someone else talking on the 2-way?
If the answer is yes, that's the reason it's blinking, because it's telling you that the channel is in use...
I hope this answers your query.
Cheers,
Peter
Jul 19, 2012 | Motorola Talkabout FR50 (14 Channels)...
One works the other does not broadcast
The FR50 is a pretty basic radio, where you set the channel select to one of 14 frequencies. The freq number will display on the screen, both radios must be on the same freq to communicate. This being said, if you have known-good batteries and the freq number is the same, your raidos should work together. If not, you have a radio which is defective and will need to be replaced.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/fr50_User_Manual_E.pdf
Best regards.
Dec 30, 2009 | Motorola Talkabout FR50 (14 Channels)...
I can not get my radios to communicate. they are on the same channal and have they same code and are the same models. why?
Check your Qt filter. Set it to the off position (the minus symbol) on both radios. Once you have your Frequency, Interference Code Eliminator and Qt Filter set identical, the radios should communicate. If not, you have a radio with a problem. Or a bad battery. (Bad batteries can also cause some user problems, such as no transmit or intermittent transmit.)
Here is a link to the user's guide, the Qt filter is on page 21: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
Another test of the radios would be to put both Codes to zero and see if you can communicate without the code turned on.
Oct 08, 2009 | Motorola Talkabout T5500 (7 Channels)...
I recieved a talkabout 250 and i have no clue how to use it please help
You would need two or more radios to be able to communicate with others. Then you simply press the push-to-talk (PTT) button when you want to talk (transmit) and release it so others can reply (receive). The radios must be set to the same settings to be able to communicate.
Apr 11, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Motorola Talkabout FV700 not transmitting nor receiving
had the same problem...took out nimh...replaced with triple A...works great!!
Thank you!!
Dec 26, 2008 | Radio Communications
Fr50 beep
Hello mtnrvr,
The Motorola TalkAbout radios, especially the FR50 and FR60, are notorious for making a variety of beeps when you push buttons and activate various functions of the radio.
The beeps can be helpful when you are trying to operate the radio in low-light situations. But they can also be mildly irritating.
Sadly most models of TalkAbout do not provide any way to disable the beeps. I'd suggest not using this particular radio for covert surveillance missions.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 12, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Neither radio will receive or send
The radio probably needs reprogrammed to match the other units. Check your owners manual for instructions.
Oct 18, 2007 | Motorola Talkabout FR50 (14 Channels)...
Motorola Talkabout FR50 (14 Channels) 2-Way Radio Logo
256 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
